View Full Version : Clutch Squeak
dj.stains
11-05-2004, 03:15 PM
Hello everybody I just got a new Sunlight Silver RX8 about a month ago and a couple of weeks after I got it when I push on the clutch it squeaks like when a door starts to squeak and I brought it to the dealer hoping they could just maybe lube it but turns out there is something wrong with my clutch master has any of this stuff happen to any you guys I have almost 5000 miles on my car now it runs great but just clutch is annoying making squeakins noise
sferrett
11-06-2004, 12:41 AM
Interesting - I noticed my clutch squeaking a little today. The squek seems to be coming from the pedal area though so I didn't think much of it. I have 19,000 miles on it.
dj.stains
11-06-2004, 02:52 AM
Yeah it seems it is coming from the pedal im still waiting for the dealership to call me when they get the part :mad:
Tigster
02-16-2005, 08:32 PM
I have noticed a squeak in my clutch to, it happens when it is pressed down the last 1/4 of the way down as well as on the way up. It happens when the car is both on and off. Anyone have any ideas? or has anyone had this fixed by the dealer?
hagar852
02-16-2005, 08:40 PM
My 2004 maxima did the same thing... It was like the spring rubbing on whatever is was hooked on. Making like a squeaky noise. Never had it checked and had 28K on it. I haven't noticed that on the RX-8 yet.
Come to think of it, my old truck did the same thing. That had over 100K on the clutch. Just sounded like it need to have the spring lubed up.
I could be way off since I am not a mechanic, but that is what it felt and sounded like. The end of a spring rubbing on the inside of the hole it is connected to. I could be wrong though.
irish8
02-16-2005, 09:07 PM
The clutch is not supposed to squeak!! The dealer should fix/replace/repair whatever is causing the problem. Talk to the service Manager. Explain how the problem is not acceptable! If the problem continues, demand the clutch be replaced under warranty. After all, it is a $30k car!!
Good luck!!
- Irish :cool:
Mr M
02-17-2005, 03:39 AM
Let us know exactly what part the dealer replaced and whether it indeed solved the problem.
The reason I say this is that I can't imaging how a master cylinder (that you say is supposed to be causing the problem) can produced this type of sound. Maybe the rubber dust boot at the end of the cylinder is making the noise?
Wankeler
02-17-2005, 10:40 AM
Can you tell if it is coming from the clutch pedal itself (inside the car) or is the noise coming from outside the cabin (under hood or under car). I've had two older Hondas with squeaky clutch pedals. One car was a cable operated clutch and the other hydraulic, both turned out to be the return spring sheaths on the pedals themselves. Post back whenever they give you an answer. Good luck.
abbid
02-17-2005, 11:04 AM
Mine does this too.
Tigster
02-17-2005, 11:39 AM
Mine seems to be coming from down by the firewall, but I can't tell if it is inside or out. I am taking it to the dealer when I need my next oil change, and I will have them fix this and I will post what they say. I have a few other issues they need to attend to as well.
RXP33D
09-18-2005, 10:15 AM
BUMP.
Getting this problem aswell. My clutch compared to other 8's feel really mushy.
Can anyone explain why. Mine also squeaks last quarter of the way. Can dealer
do anything about it?
Go48
09-18-2005, 01:12 PM
BUMP.
Replace the "clutch" fluid with a quality brake fluid like ATE Super Blue and bleed the system.
Tigster
09-18-2005, 08:57 PM
My dealer lubrictaed the slave cylinder and the squeak is gone. At least that is what they said they did.
Jabberwock
09-18-2005, 10:25 PM
I have the same problem and the dealer tried to fix it 3 times.
The dealer lubed the slave cylinder first, but it didn't work, so they told me to come a week later and they will replace the whole pedal assembly.
When they replaced the clutch pedal, the squeek was gone for 1000 miles and returned with a louder squeek. The service manager had it lubed again, but the problem still existed and he told me he doesn't know what to do anymore.
The service manager then told me that a TSB might come out on a new clutch pedal, but he also told me not keep my hopes up because he was just speculating since so many people have this problem.
**To note: My service manager had a RX8 with the same squeek problem so he was real helpful and he couldn't get it fixed either.
Go48
09-19-2005, 07:01 AM
Buy a can of ATE Super Blue, take it to your service manager and tell him to replace the fluid in the clutch hydraulic system. This took care of that same problem on my RX-7. It may not work on your car, but it won't cost you much to try.
dgrx8
10-25-2006, 10:36 AM
i recently speed bled my entire fluid including the clutch. i replaced it w/ ATE super blue. it did nothing for my squeaky pedal. it's driving me crazy! can anyone help???
timhopkins
10-25-2006, 05:06 PM
dear all,
new to the forum, but ive checked it out in the past to see just how impressed people are with the rx8.
i bought mine 18 months ago now, and ive been real pleased with it. i use my car for work which sees me driving about - hence ive covered 28k miles in these 18 months.
the car has been driven enthusiastically, but never thrashed.
earlier this week, the cluch gave up the ghost and i've had to have it replaced. mazda did not warrant this part - hence i'm hit with a £610 bill!!!!!!!!!!
I'm just wondering if any of you guys have had similar clutch related problem - ie, wearing out in 28k miles/18 months. personally, i think this is obscene - i've had other sporty cars that have done 80k miles plus without even a sniff of clutch problems.
mazda uk basically laughed at my problem - stating that it is outside of the warranty period of 9k miles or 1 year.
let me know what you think i should do - do i have a case, and should i fight mazda?
cheers,
tim
no dice
10-25-2006, 05:12 PM
The squeeky pedal is just because you need lube on the spring.. Just stick yer head under there, find your clutch and follow it up. Get a can of silicone lube and give it a quick spray. Ive been squeek free for 25k miles now..Dont use WD40, it attracts dust.
Magsz
11-15-2006, 11:27 PM
My brand new 06 mazda has this problem. I bought it with 11 miles on it and it started to squeak after only 75 additional miles. I am bringing it to the dealership tomorrow to have it looked at.
corners
11-16-2006, 03:51 PM
I had the same problem after about 500 miles on my '06 GT. The dealer replaced the clutch pedal assembly and the problem has not come back.
03mazda05
01-18-2007, 11:29 PM
I have a 03 protege5 and i was having thye same problem. i went to home depot and got silacone lube in a spray can. and spraied the clutch pedal but be sure to cover the gas and break pedal because if you get it on them you will slide right off. this has fixed the problem and no more squeak.
shaunv74
01-19-2007, 12:22 AM
dear all,
cheers,
tim
Do a search on DMP. He has a thread here where his clutch springs failed and broke.
Here it is:
http://www.rx8club.com/showthread.php?t=72243&page=1&pp=15&highlight=clutch
Since this was not wear but catastrophic failure they replaced it free under warranty. Did they show you the clutch after they pulled it? Were the springs broken? did they show you what the wear thickness was on the clutch vs. the min spec? If not and you've already paid you may be SOL. Let us know what you've got and maybe you can bring that info. to Mazda UK.
Advice for the next time: Anything they tell you is not under warranty come out here and search for TSB's and other existing threads first to ask for advice before you give the okay. It's much easier to fight before they have your money.
For the other folks here is a link to a TSB on squeaky clutches.
http://www.finishlineperformance.co...011-06-1724.pdf
CarAndDriver
04-13-2007, 01:17 AM
Debating--take into dealer or spray silicone lube?
rowteree
05-02-2007, 01:49 AM
having this same problem, I open the door of my car and i hear the squeak. I can 1) take to the dealer or 2) i can spray silicone lube on the spring, which option is better people? Any help?
corners
05-02-2007, 03:40 AM
Followup- I now have 9500 miles on my new, replaced clutch pedal. The squeak has not returned.
konradk
06-27-2007, 03:20 PM
well, after about 6K miles, i am a proud member of the squeaky clutch crew! :lol2:
i will try the silicone lube spray. and call the dealer. if anyone has had any experiences other than the above, please share!
terretsboy
06-27-2007, 03:30 PM
me too. I need to bring that up when I go in next time!
HERO
06-27-2007, 04:10 PM
Ive had this for quite some time. New pedal = no change. Lube = no change. New slave cylinder = no change. Pedal adjustment = no change.
ricepoweredrotaryengine
10-21-2008, 03:47 AM
yea...mine just started to squeak over the past weeekend and its getting freakin annoying. I sprayed some lubricant on all the moving parts except the spring and it still squeaks. maybe i gotta spray on the spring too? what do you guys think?
RX8SaxMan
10-23-2008, 02:40 PM
I've had the problem for a long time now (>30,000 miles) and still haven't found a solution. I've lubed my bracket and slave cylinder, and I even installed the bracket reinforcement from Mazsport. So if anyone knows a secret fix, speak up!
coastie08
10-24-2008, 01:55 PM
I've had this issue as well since about 5000 miles, i notice it's really bad for the first day or two when i haven't driven my car in 2 months and then it's gone. I'm at 20000 miles now.
Bumble_Bee
10-24-2008, 02:46 PM
I've had it for a whiiiiiiiiiiiiiiiiile, as well. I've never sprayed anything on it... It comes and goes...!
Loud music = problem solved! :D
ferg
01-26-2009, 11:48 AM
quick question, my cluch is making a chirping sound when i letoff, it will stop when i put a little pressur on to the cluch or wiggle it, i dont know what it is but you can hear it from the out side of the car, its like chirp,chirp,chirp,chirp,chirp....
the car has about 16500 miles on it, am i gonig to have to get a new cluch?
ferg
01-26-2009, 08:59 PM
i guess im the only one lol
Ryan2008
01-26-2009, 09:08 PM
I know exactly what you're talking about. You definitely do not need a new clutch at 16500 miles. Someone told me once that you have to lube a bearing or seal in the transmission. I'd talk to Mazda as you're still under warranty and ask them what the problem is. I'm not too sure much more about it, sorry. But fill me in as to what you find out about it.
ferg
01-26-2009, 09:13 PM
ill send my car in this saturday and tell them, but any dealer? because i didnt get it from a dealer
9krpmrx8
02-16-2009, 05:49 PM
The link to the TSB is broke does anyone have the info on that TSB?
9krpmrx8
02-16-2009, 05:57 PM
never mind.
ferg
02-16-2009, 06:13 PM
well i sent it in and it didnt do it lol, chirp chirp chirp chirp, after i left, i took it back and it stop wtf, i think if i put the cluch back a little it will stop, is that safe? because i see a nut that i can set how much its in or out
willnordacgreen1211
05-02-2010, 10:47 PM
my clutch just started squeeking a little bit as well and it fells rough when pressing the pedal in. it has sat in the hardcore rain we had for three days. i didnt drive due to flooding. but i drove it tonight and its doing this. never happened before. im right at 45k any help? please!
Tamas
05-03-2010, 01:14 AM
It's possible that if it squeaks, it's gonna break: http://www.rx8club.com/showthread.php?t=132912
