My RX-8 Bites!
Old Nov 3, 2004 | 06:02 PM
philodox's Avatar
Rangers Lead The Way!
My RX-8 Bites!
Literally... now that winter is closing in, I am started to get shocked every time I get out of my 8 after a drive! Damn it stings.. I have to hold onto the top part of the door while I get out to ground myself to the car otherwise I get a nice little shock.
This is my first winter with my 8. Is this the norm with the 8? Anyone else have this happen in cold weather?
Old Nov 3, 2004 | 06:11 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Yes it happens to me as well. I don't live in the cold but the nice warmth of the AZ sun. This happens to us ALL year. Dosen't matter what car, it deals with the relative humidity.
Old Nov 3, 2004 | 06:45 PM
StewC625's Avatar
Insanely Yellow
Actually, this is the norm with most cars, especially those with low-rolling resistance tires - they build up static in them, the charge gets transferred to you, you step out of the car, and ZAP.
I find that if I put my hand on the door frame (the metal) as my foot contacts the ground getting out of the car, that I don't get shocked as much. If I don't contact metal, step out to the ground, and touch the car, KAPOW!
FYI, don't feel bad. Every Honda or Acura I've had since 1985 has done this as well. Not an -8 idiosyncracy.
Stew
Old Nov 3, 2004 | 06:51 PM
philodox's Avatar
Yup, that's what I end up having to do. My last car was a Honda Civic and it had the same problem.. Just that here in NJ, it only happens in the winter.
Old Nov 3, 2004 | 07:27 PM
truemagellen's Avatar
Attracts tree branches
tell your girlfriend it is an exotic sex toy
Old Nov 3, 2004 | 08:17 PM
RUmble's Avatar
THat's what I think of my gf.
Old Nov 3, 2004 | 08:44 PM
so do I, my girlfriend is Asian
Old Nov 3, 2004 | 08:45 PM
VmanX's Avatar
it's typical on a very dry day. your butt slides across the seat building up an electric charge. it doesn't help to be wearing fabrics that attract electricity either, as with the windbreaker pants that ppl normally wear to break dance. ouchies..
i just close my door by pressing against the window... but often times, i forget and "zap"!
Old Nov 3, 2004 | 09:22 PM
rotten42's Avatar
Mentalhealth is overrated
its never happened to me
Old Nov 3, 2004 | 09:58 PM
MadDashRX8's Avatar
Resu Deretsiger
Be careful "zapping" yourself after getting back out of your 8 while fueling. Don't zap yourself on the pump handle; gas fumes and static electricity are B.A.D. Vapors only have to be between 1.4 and 7.6% in the area of the handle to ignite. There's videos out there that tend to indicate women are more susseptible to this, as they are more apt to get in and out while fueling up. Guys apparently stand there and take it. Be safe!
Old Nov 3, 2004 | 10:05 PM
StewC625's Avatar
Insanely Yellow
Answer to all of it is to touch metal parts of the car - even the painted metal will transfer the static ... I always discharge myself prior to engaging a fuel hose by putting my hand on the rear fender for a few seconds first.
Old Nov 3, 2004 | 10:14 PM
RXE16T's Avatar
'RX-EIGHT'
Originally Posted by StewC625
I always discharge myself prior to engaging a fuel hose.
:D :D :D Well worded..... sorry couldn't help myself.
Old Nov 3, 2004 | 11:08 PM
MazdaManiac's Avatar
My MX-3 had a great little feature - an inch-long button on the back edge of the inside of the door trim near the latch and just below the window that said "touch" on it.
If you did as instructed as you got out, you were treated to a wonderful ZAP-free exit.
Internally, this button was grounded on the door frame, but the button itself was only a semiconductor so the charge was discharged over a 3 dozen milliseconds or so rather than all at once. If you REALLY built up a big charge, the button would feel "fuzzy" as it took down the 20k volts or so.
Want to have a real good time? Get out of the car real carefully and then touch one of the metal buttons on your cell phone and then the phone to the car.
You can repeat the experiment with your laptop if you so choose.
Old Nov 4, 2004 | 09:01 AM
Chrisbert's Avatar
Don't know about winter here. 82 and raining all the time lately.
Old Nov 4, 2004 | 09:07 AM
8's enough's Avatar
my other car does that all the time i have cloth seats in it ,just spray some static guard on the seats and it will go away. i have leather in my 8 so no static as of yet.
Old Nov 4, 2004 | 09:28 AM
Stone's Avatar
Stone
You use to be able to buy a grounding strap that hangs under the car from the frame that will eliminate the static build up and the shocking results, prob was that they wear out from contact with the road after awhile.
Old Nov 4, 2004 | 10:20 AM
shazusa's Avatar
No longer a wannabe
Arm Discharge Instead of the Finger Variety
I also live in AZ. I have learned to always touch my arm to the door before I close it. The zap on the arm does not hurt. The fingers are much more sensitive.
If you're a masochist, try kissing the door first! :D
Actually, my wife and I discharge ourselves before we kiss.
Static is just a constant reality in the dry southwest.
Old Nov 10, 2004 | 11:15 PM
f1 tech's Avatar
best thing to do is to hold on to the metal part of your door as you're getting out to neutralize yourself. works everytime!
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
Chapsy
Sep 22, 2015 09:57 AM
Frosty8
Sep 11, 2015 10:27 PM
Tsurugi
Sep 7, 2015 08:27 PM
