View Full Version : 2004 Rx-8 issues data poll
samsonite1 11-01-2004, 12:08 PM All,
In an attempt to trend the issues with the 8's I will be compiling a list and publish the results once we have a sampling. Please provide the following data for the poll.
Build date
Current mileage
ecu flash level
Any issues with the previous level?
Any issues with the current level?
MT or AT
Any issues with the transmission? If so, what?
Issue with gears?
Issue with the clutch?
Issue with the T/O bearing?
Issue with noise?
Issue with flywheel
Issue with harmonic balance?
Tires on the car
Issues with alignment?
Issues with balance
Issues with cupping on the inside?
Any aftermarket mods
Did the mods effect stock components? If so what was the mod and what did it affect?
Driving style normal or aggressive
Driving cycle - %city % highway
Issues the car has been in for
Outstanding issues
Engine oil - dino or synth
Any issues with the motor?
Transmission oil - Dino or synth
Did any issues with the transmission get better with the fluid change?
Diff oil - dino or synth
Did any issues with the diff get better with the fluid change?
Body - Any issues?
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc
Brakes - any issues? Noise? Premature wear?
samsonite1 11-01-2004, 12:17 PM I'll start
Build date Aug 2003
Current mileage 24617
ecu flash level L
Any issues with the previous level? no
Any issues with the current level? no
MT or AT MT
Issue with gears? hard shift to 6th
Issue with the clutch? noisy
Issue with the T/O bearing? noisy
Issue with noise? i seems to have a lot of drive line rattles.
Issue with flywheel no
Issue with harmonic balance? no
Tires on the car Bridgestone
Issues with alignment? yes. It wanders on the freeway. It has been checked
Issues with balance no
Issues with cupping on the inside? yes
Any aftermarket mods no
Driving style normal or aggressive normal with typical shifts between 4 and 5 k
Driving cycle - %city % highway 90% highway 10 % coty
Issues the car has been in for: Recalls and normal maintenance
Outstanding issues drive seat creaks.
Engine oil - dino or synth dino
Any issues with the motor? no
Transmission oil - Dino or synth dino
Did any issues with the transmission get better with the fluid change? have not changed
Did any issues with the diff get better with the fluid change? have not changed
Body - Any issues? no
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc drive seat creaks, window lifts make a lot of noise, center console had to be replaced twice, rattle coming from the rear speaker area, rattle coming from the center console behind the radio/vent area - no Nav. Brushed aliminum accent pieces scratch easy. floor mats look ratty now.
Brakes - any issues? Noise? Premature wear? a lot of noise. I will get addressed with the tsb
RotorGeek 11-01-2004, 12:43 PM All,
Build date 01/2004
Current mileage 4560
ecu flash level M
Any issues with the previous level? No
Any issues with the current level? No
MT or AT = MT
Any issues with the transmission? If so, what? No
Issue with gears? No
Issue with the clutch? No
Issue with the T/O bearing? No
Issue with noise? Normal noise
Issue with flywheel No
Issue with harmonic balance? NO
Tires on the car
Issues with alignment? No
Issues with balance No
Issues with cupping on the inside? No
Driving style normal or aggressive None that effect this
Driving cycle - %city % highway 60 hwy, 40str
Outstanding issues
Engine oil - dino or synth Dino
Any issues with the motor? Nope
Transmission oil - Dino or synth Dino for now
Did any issues with the transmission get better with the fluid change? No
Diff oil - dino or synth Dino
Did any issues with the diff get better with the fluid change? No
Body - Any issues? Nope
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Noise coming from map light
Brakes - any issues? Noise? Premature wear? Lots of brake dust
I have had a very toublr-free ownership so far. My MPG has gone from 14 to 18 so i am very happy with that.
Slims8 11-01-2004, 12:52 PM Build date Aug 2003
Current mileage 13100
ecu flash level "M"
MT or AT - MT
Any issues with the transmission? Yes
If so, what?
Issue with gears? yes - 2nd, 3rd, 6th
Issue with the clutch? - Yes - "Exploded"
Issue with noise? - Yes
Issue with flywheel
Tires on the car - Factory
Issues with balance
Any aftermarket mods - No
Driving style normal or aggressive - Normal
Driving cycle - %city % highway - 65% Highway, 35% city
Transmission Failure (Gear problems - 40 days in Shop)
Transmission Problems (Gear Failures - 12 days in Shop)
Clutch Exploded (9 days in shop... 12 days in my driveway)
Outstanding issues
Clutch
Engine oil - dino or synth - Dino
Brakes - any issues? Noise? Premature wear? - Noise
Gaels22 11-01-2004, 12:57 PM Build date: June 2003
Current mileage: 19434 kms
ecu flash level: M
Any issues with the previous level? Poorer Gas mileage, flooding
MT or AT: AT
Any issues with the transmission? If so, what? None
Issue with gears?None
Issue with the clutch?None
Issue with the T/O bearing?None
Issue with noise?None
Issue with flywheel: None
Issue with harmonic balance?None
Tires on the car: Bridgestone Potenza's
Issues with alignment?: None
Issues with balance: None
Issues with cupping on the inside? Yes, cupping very badly; Mazda Eastern District Service Manager looking into problem : Causing way too much road noise in car
Any aftermarket mods: None
Did the mods effect stock components? If so what was the mod and what did it affect?None
Driving style normal or aggressive: Not normal but not aggressive : I like speed
Driving cycle - 80 city 20 highway
Replace Oil Pan
Replace Spark Plugs
Replace Battery
Upgrade ECM
Replace Center Column 3M Tape
Replace Climate Control Knob
Outstanding issues: Tire Cupping Problem and Front Brakes Squeeling
Engine oil - dino
Any issues with the motor? None
Diff oil - dino
Body - Any issues? Yes
3M Tape had to be replaced on Center Column of both sides of car due to chipping - under warranty
Something rattles on dashboard by Steering wheel - no clue what it is
Finish on the ceiling poor around the airbags
Truck finish is very poor - it doesn't connect to the truck and has a 1/2 inch gap
Big problem with front brakes squeeling - Mazda will hopefully replace
th1rd3y3 11-01-2004, 05:15 PM Here is my information
Build date: 08/03
Current mileage: 10800
ecu flash level: M
Any issues with the previous level? Yes, loss of power, oil light flashing, CEL
Any issues with the current level? Occasional oil light
MT or AT: MT
Issue with gears? Yes
Issue with the T/O bearing? Unsure
Issue with flywheel? No
Issue with harmonic balance? No
Tires on the car: Stock and winter tires on 17" wheels
Issues with balance? No
Any aftermarket mods: Yes, GReddy Exhaust, Vivid Racing SS Clutch Hose
Did the mods effect stock components? No
Driving style normal or aggressive: Mostly normal
Driving cycle - %city % highway 80%City, 20%Highway
1. Grinding
2. ECU Flash
3. Recalls
Outstanding issues
Grinding just fixed hopefully will remain fixed.
Engine oil - dino or synth: Dino
Transmission oil - Dino or synth: Synth
Did any issues with the transmission get better with the fluid change? Barely but problem was alreay very bad
Diff oil - dino or synth: Synth
Did any issues with the diff get better with the fluid change? Barely but problem was alreay very bad
Random rattles and creaks when slow cornering
Squeaky brakes fixed by TSB so far
epitrochoid 11-01-2004, 08:57 PM Build date 11/03
Current mileage 16500
ecu flash level M
Any issues with the previous level? Low power, poor MPG, engine bucking
Any issues with the current level? Idle is a little rough
MT or AT MT
Issue with gears? None
Issue with the clutch? None
Issue with the T/O bearing? Just the noise everyone gets
Issue with noise? Synchros are a little loud, but normal
Issue with flywheel None
Issue with harmonic balance? None
Tires on the car OEM Potenzas
Issues with alignment? Tires tramline alot due to 10% tread remaining
Issues with balance None (I even halfway expected there to be)
Issues with cupping on the inside? None
Any aftermarket mods CZ Stage 1.1, HKS Legamax Exhaust
Did the mods effect stock components? If so what was the mod and what did it affect? Coilpacks may be damaged by earlier stage 1 design, otherwise none
Driving style normal or aggressive aggressive
Driving cycle - %city % highway 30/70
Issues the car has been in for Recalls and flashes only
Outstanding issues None
Engine oil - dino or synth Castrol 5w-20 Dino Poop
Transmission oil - Dino or synth Redline Mt-90 Synth
Did any issues with the transmission get better with the fluid change? Yes!
Diff oil - dino or synth Redline 75W-90
Did any issues with the diff get better with the fluid change? Hard to tell (changed at the same time as tranny)
Body - Any issues? None
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc NAV screen rattles at times in the heat
Brakes - any issues? Noise? Premature wear? Standard noise, I really don't care about it though
rkostolni 11-02-2004, 10:22 AM Build date 11/03
Current mileage 6k
ecu flash level M
Any issues with the previous level? yes, repeated check engine light, cat clogged
MT or AT MT
Issue with the T/O bearing? Normal noise
Issue with noise? Just normal T/O noise
Any aftermarket mods No
Did the mods effect stock components? If so what was the mod and what did it affect? N/A
Driving style normal or aggressive Fairly Normal considering this is a sports car
Driving cycle - %city % highway 60% 40%
Issues the car has been in for Check engine light, replace cat, shock sensor to sensitive, rattle, will be going in soon for rusted rotors,
Outstanding issues
Diff oil - dino or synth dino
Interior is good, no probs
Brakes - any issues? Noise? Premature wear? no issues
Slims8 11-02-2004, 10:27 AM Very interesting start... Notic 3 transmission failures, all with a build date of August of '03?
abbid 11-02-2004, 10:31 AM Build date 08/03
Current mileage 15500
ecu flash level M
MT or AT MT
Any issues with the transmission? If so, what? Yes, cannot shift into 2nd at higher RPMS.
Issue with gears? I suppose second?
Issue with the T/O bearing? Just the noise everyone gets, sounds like a hamster on a wheel
Issues with alignment? Perfect.
Any aftermarket mods Currently stock, previous K&N
Did the mods effect stock components? If so what was the mod and what did it affect? K&N, lower torque feel, worse idle, engine would stall out during stops.
Driving cycle - %city % highway 20/80
Issues the car has been in for Recalls and flashes, Tranny probs.
Outstanding issuesBrake Squeel
Transmission oil - Dino or synth Stock
Did any issues with the transmission get better with the fluid change? -
Diff oil - dino or synth Stock
Did any issues with the diff get better with the fluid change? -
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc When NAV screen opens, it sounds like a spring is comming loose. At times, when rolling the window down or up, when it is fully open, it pops comming out of the door sill, and it pops on its way down
Brakes - any issues? Noise? Premature wear? brake squeel
abbid 11-02-2004, 10:35 AM Very interesting start... Notic 3 transmission failures, all with a build date of August of '03?
make that 4, with mine
Slims8 11-02-2004, 10:42 AM August, September... This trend may be useful. I wish some people would post about their "exploding clutches"
RX8SpdDmn 11-02-2004, 11:00 AM I have a late build '04, M Flash.
I have rattles and buzzes.
Yesterday, the tranny stopped allowing me to get into 6th gear. About 15 minutes later, I got it in again. I've had it not let me go in a couple times before, but then went in on the next attempts. This time, I tried over and over and over before finally getting it in. I'll be going to visit the dealer the next time this happens.
Slight brake squeal, but it's not consistant.
RX8SpdDmn 11-02-2004, 11:06 AM Build date - Not sure, but late '04
Current mileage 1200
ecu flash level M
Any issues with the previous level? N/A
Any issues with the current level? Poor mpg.
MT or AT MT
Any issues with the transmission? If so, what? Requires a lot of attention to shift smoothly
Issue with gears? I get locked out of 6th gear sometimes. Yesterday it wouldn't let me back in for ~15 minutes
Issue with noise? in neutral, clutch released, it's noisy
Issues with alignment? no
Issues with cupping on the inside? no
Any aftermarket mods N/A
Driving cycle - %city % highway 50/50
Issues the car has been in for - none yet.
Outstanding issues
Engine oil - dino or synth not changed yet
Transmission oil - Dino or synth stock
Diff oil - dino or synth stock
Body - Any issues?
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc - rattles between driver's side A Pillar and dash, and in driver's door.
Brakes - any issues? Noise? Premature wear? some light sqeal, inconsistant
smoothrx8 11-02-2004, 12:28 PM All,
Build date: 06/03
Current mileage: 8400
ecu flash level: M
Any issues with the previous level?: ?
Any issues with the current level?: NO
MT or AT: MT
Any issues with the transmission? If so, what?: NO
Issue with gears?: NO
Issue with the clutch?: NO
Issue with the T/O bearing?: NO
Issue with noise?: NO
Issue with flywheel: NO
Issue with harmonic balance?: NO
Tires on the car: OEM
Issues with alignment?: NO
Issues with balance: NO
Issues with cupping on the inside?: NO
Any aftermarket mods: NO
Driving style normal or aggressive: Normal
Driving cycle - %city % highway: 95% city/5% highway
Issues the car has been in for: None
Outstanding issues
Any issues with the motor?: Nope
Transmission oil - Dino or synth: Dino
Did any issues with the transmission get better with the fluid change?: N/A
Diff oil - dino or synth: Dino
Did any issues with the diff get better with the fluid change?: N/A
Body - Any issues?: Orange Peel!!!
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: Rattle near rear right speaker is driving me crazy!!!
Brakes - any issues? Noise? Premature wear?: Brake dust everywhere
samsonite1 11-02-2004, 01:15 PM Once we have a sample of 20 cars, We can start trending.
I have noticed as well about the 8-03 build date and transmissions......
Nemesis8 11-02-2004, 02:12 PM Build Date: 09/03
Current mileage 30K
ECU flash level R
Any issues with the previous level? None
Any issues with the current level? None
MT or AT? MT
Any issues with the transmission? If so, what? Noisey
Issue with gears? Second Gear Grinds
Issue with the clutch? None, after I replaced the hose with the MS part
Issue with flywheel? None
Tires on the car: Pirelli P-Zero
Issues with alignment? None
Issues with balance? None
Any aftermarket mods? Click Here (http://www.rx8club.com/vbgarage.php?do=view&id=10660)
Did the mods effect stock components? Yes
If so, what was the mod and what did it affect? MS Suspension - handles better than my buddies Porsche 911 Carrera now!
Driving style normal or aggressive? Aggressive
Driving cycle - %city % highway: 30/70
Issues the car has been in for: Recalls and flashes
Outstanding issues: None
Engine oil - dino or synth 5W-20 Dino
Transmission oil: Redline MT-90 Synthetic
Diff oil: Redline 75W-90 Synthetic
Did any issues with the diff get better with the fluid change? Can't tell
Body - Any issues? Cheap Paint and Orange Pealed Clearcoat
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: Rear passenger side rattle
Brakes - any issues? Noise? Premature wear? Brakedust Everywhere, and Wheel Hubs Rusted
NomisR 11-02-2004, 02:54 PM Build date 11/03
Current mileage 7500
ecu flash level M
MT or AT MT
Tires on the car: Potenza
Driving style normal or aggressive: semi agressive
Driving cycle - %city % highway 35% city 65% Highway
Issues the car has been in for: Recall, M Flash, Maintainance
Outstanding issues: Rattle in rear door
Transmission oil - Dino or synth Whatever they put in at the factory
Did any issues with the transmission get better with the fluid change? No changes
Diff oil - dino or synth No idea
Did any issues with the diff get better with the fluid change? No clue
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Rattle on rear driver side door and mirror
Brakes - any issues? Noise? Premature wear? None yet, no noise, but excessive brake dust.
beachdog 11-04-2004, 11:43 PM Build date 09/03
Current mileage 8000
ecu flash level M
Any issues with the current level? Y (the drive by wire is more sensitive at low speed than previous levels. harder to creep at low speed - manual trans)
MT or AT
Issue with gears? crunchy 1-2 shift occasionally - plan to fix with synth trans oil
Issue with noise? Y loud in neutral (again, plan to fix w/synth)
Tires on the car
Driving cycle - %city % highway 30c 70h
trans input shaft noise
1-2 shift crunchiness
a/c fast cycling
abs pump failure
Any issues with the motor? rough idle
Transmission oil - Dino or synth currently d
Diff oil - dino or synth currently d
peterlemonjello 11-05-2004, 08:09 AM Build date: June 2003
Current mileage: 16200 miles
ecu flash level: M
MT or AT: MT
Driving cycle - 90%city 10%highway
Upgrade ECM
All Recalls
Replace Door Sills
Outstanding issues:
Engine oil - Castrol 5w20
Transmission oil - dino
Diff oil - dino
Small problem with front brakes squeeling. After 14,000 miles squeaks aren't near as bad.
Slims8 11-06-2004, 02:54 PM Samsonite, How's everything looking. It looks like there are plenty of people with tranny problems for the car to only be about a year old. I wish more people had posted which had major problems or Mazda's refusal to fix.. Oh well.
zoom_zoom33 11-06-2004, 05:58 PM It sounds like most problems with the tranny on the MT's only saw one AT reply
samsonite1 11-06-2004, 08:12 PM Samsonite, How's everything looking. It looks like there are plenty of people with tranny problems for the car to only be about a year old. I wish more people had posted which had major problems or Mazda's refusal to fix.. Oh well.
So far it is showing issues with Transmissions and fit and finish. I will show the compiled data on Monday
N5TEV 11-07-2004, 03:04 PM Build date Nov 03
Current mileage 15000
ecu flash level M
MT or AT
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car Stock
Driving style normal or aggressive Moderately Aggressive
Driving cycle - 60%city 40% highway
Outstanding issues
Did any issues with the transmission get better with the fluid change? N/A
Did any issues with the diff get better with the fluid change? N/A
Body - Any issues?
Replaced outside loose pass side window guide/molding
Replaced center console latch button, TWICE. (Pops out of alignment)
Replaced Ashtray door (tensioner/spring gave out)
Jeff
QuarterMile 11-08-2004, 11:39 AM Build date Aug 2003
Current mileage 14500
ecu flash level "M"
MT or AT - MT
If so, what?
Issue with gears? yes - 2nd grinding
Issue with the clutch? - Yes "Exploded"
Issue with flywheel
Issues with balance
Driving cycle - %city % highway - 75% Highway, 25% city
1. Transmission grinding
2. Clutch Exploded
Brakes - any issues? Noise? Premature wear? - Very squeaky
Build date 9/2003
Current mileage 4300
ecu flash level M
Any issues with the previous level? Poor fuel economy
MT or AT MT
Issue with gears? Poor synchro action on 1-2 shift when cold
Issue with the clutch? Clutch burned easily when new - pressure plate loose
Issue with noise? Consistently noisy since new
Tires on the car Bridgestone Potenzas
Any aftermarket mods None except cosmetic mods
Driving style normal or aggressive Mix: 50% normal/50% aggressive
Driving cycle - %city % highway 80%city 20%highway
1. Clutch burning caused by loose pressure plate
2. Various reflashes and all relevant recalls
Outstanding issues
None
Transmission oil - Dino or synth synth
Synthetic (RedLine) oil improved general shift quality when warm, but did not affect 1-2 shift when cold
Diff oil - dino or synth dino - stock
Did any issues with the diff get better with the fluid change? Not applicable
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc None
JMD RX-8 11-08-2004, 05:25 PM Build date - June 2004
Current mileage - 4,500
ecu flash level - M
Any issues with the previous level? - n/a
Any issues with the current level? - n/a
MT or AT - MT
Any issues with the transmission? If so, what? - None
Issue with gears? - None
Issue with the clutch? - None
Issue with the T/O bearing? - None
Issue with noise? - None
Issue with flywheel - Plan to swap out for RB lightweight one
Issue with harmonic balance? - None
Tires on the car - OEM Dunlop 8090
Issues with alignment? - No
Issues with balance - No
Issues with cupping on the inside? - No
Driving style normal or aggressive - 50% aggressive
Driving cycle - %city % highway - 50/50
Issues the car has been in for - Re-program alarm for new key. Dealer couldn't do it and I found instructions posted on here. Thanks much...saved me a 4 hour appointment to flash immobilizer.
Outstanding issues - None
Engine oil - dino or synth - Castrol GTX
Transmission oil - Dino or synth - OEM - Synth in a month
Diff oil - dino or synth - OEM - Synth in a month
Body - Any issues? - Too many women admiring it (not an issue by any means)
Brakes - any issues? Noise? Premature wear? - Excessive dusting from front rotors only.
All,
Build date: Summer 2003. Early Built
Current mileage: 15000 kms
ecu flash level: M
Any issues with the previous level?: Pool Gas mileage
Any issues with the current level?: Still pool gas mileage
MT or AT: MT
Any issues with the transmission? If so, what?: Grinds shifting from 1st to 2nd
Issue with gears?: 1 to 2
Issue with the clutch?: No
Issue with the T/O bearing?: No
Issue with noise?: No
Issue with harmonic balance?: No
Tires on the car: stock summer tires
Issues with cupping on the inside?: No
Any aftermarket mods: CZ 1.1
Did the mods effect stock components? If so what was the mod and what did it affect?: No
Driving cycle - %city % highway: 70% city, 30% highway
Outstanding issues
Engine oil - dino or synth: dino
Transmission oil - Dino or synth: Synth - RP
Did any issues with the transmission get better with the fluid change?: a bit better
Diff oil - dino or synth: synth
Did any issues with the diff get better with the fluid change?: No issue
Body - Any issues?: No
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: No
Brakes - any issues? Noise? Premature wear? Noise - will take it in for recall pads
samsonite1 11-09-2004, 08:50 AM Sorry for not posting yesterday.
I will have the results to date later today.
But there is a obvious issue with the MT with build dates on or about 8/2003
Slims8 11-09-2004, 06:51 PM hmmmm... Sorry... I seemed to have my build date wrong. I don't know what I was thinking, must be the Mustang. My build date was 2/04
Build date 01/04
Current mileage 12200
ecu flash level M
MT or AT MT
Issue with gears? Fails to enter reverse on occasion. Not hard shift, literal half shift into reverse, feels like the car is in gear but if you let the clutch out, the synchro just spins.
Issue with the clutch? Sometimes feels like there is resistance in the pedal. Disabling DSC and or TCS removes it usually.
Issue with the T/O bearing? Dont think so.
Issue with noise? Noisey idle.
Driving cycle - %city % highway 50% highway 50 % city
Issues the car has been in for: Recalls, center console lid replaced, failure to shift into reverse (not fixed yet)
Outstanding issues: Still have problems getting into reverse sometimes. Rear view mirror vibrates (homelink mirror)
Body - Any issues? paint chips easily.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Rear view mirror rattles.
Brakes - any issues? Noise? Premature wear? Starting to squeal.
Feras 11-10-2004, 07:19 PM Build date 5/03 (first boat?)
Current mileage 9500
ecu flash level M
Any issues with the previous level? sluggish starts (J flash)
Any issues with the current level? none
MT or AT: MT
Any issues with the transmission? If so, what? none smooth as silk
Issue with gears? 6th is sometimes hard to get into if jumping from 4th to 6th
Issue with the clutch? none
Issue with noise? a little noise when idling
Issue with flywheel none
Issue with harmonic balance? none
Tires on the car RE040s were done at 9000 miles, got Blizzak LM22 for the winter
Issues with alignment? none pulls both left and right, tramlining
Issues with balance none
Issues with cupping on the inside? none
Any aftermarket mods none
Driving style normal or aggressive: very aggressive (see tire life above)
Driving cycle - %city % highway 80% city 20% highway
Issues the car has been in for: oil pan TSB, M flash, replaced headlights (scratched on shipment), repainted rusty rotors, nuts tightened
Outstanding issues
Engine oil - dino or synth: castrol GTX 5w20
Any issues with the motor? none it rocks
Did any issues with the transmission get better with the fluid change? mechanic told me not to touch transmission oil till 20k miles lest i get a problem
Did any issues with the diff get better with the fluid change? same as above mechanic advised against
Body - Any issues? tail light fogging
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc center console broken
Brakes - any issues? Noise? Premature wear? noise, replaced with TSB
army_rx8 11-10-2004, 10:35 PM Build date 06/03
Current mileage 26271
ecu flash level M
MT or AT MT
Issue with gears? none
Issue with the clutch?none
Issue with the T/O bearing? none
Issue with noise? none
Tires on the car Bridgestone potenza re040
Any aftermarket mods racing beat exhaust/racing beat spark plug wires
Did the mods effect stock components? If so what was the mod and what did it affect? none
Driving style normal or aggressive normal with typical shifts between 4 and 5 k 50/50
Issues the car has been in for: Recalls, evap system replaced (dealer f'd it up during service), oil pan replaced due to faulty sensor
Outstanding issues: single bushing makes noise dependent on the temperature (only when warm)
Body - Any issues? none
Interior - Fit and finish. none
Brakes - any issues? Noise? Premature wear? rear right brack slight sqeel when lightly pushing the brack
expo1 11-12-2004, 11:30 PM Build date 5/2003
Current mileage 20,100
ecu flash level M-Flash
Any issues with the previous level? NO
Any issues with the current level? NO
MT or AT MT
Issue with gears? NO
Issue with the clutch? NO
Issue with the T/O bearing? NO
Issue with noise? NO
Issue with flywheel NO
Tires on the car RE040 with 20,000 miles + still room for more
Issues with alignment? NO
Issues with balance NO
Issues with cupping on the inside? NO
Any aftermarket mods YES
RACING BEAT SWAY BARS (FT & RR) CAR TAKES TURNS BETTER
Driving style normal or aggressive NORMAL
Driving cycle - %city % highway 25% 75%
OIL PAN REPLACED PER TSB => OIL LIGHT WOULD COME ON
REPALCED SPARK PLUGS AFTER LOSS OF POWER DURING A TRACK DAY
Outstanding issues
Engine oil - dino or synth DINO
Any issues with the motor? NO
Transmission oil - Dino or synth SYNTH
Diff oil - dino or synth SYNTH
Body - Any issues? NO
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc NO
Brakes - any issues? Noise? Premature wear? SQUEEL SOMETIMES / NO
Howard 11-13-2004, 12:33 AM Build date 08/03
Current mileage 2500
ecu flash level not sure
MT or AT MT
Any issues with the transmission? If so, what? NO
Tires on the car NO
Any aftermarket mods NONE
Driving style normal or aggressive Aggressive
Driving cycle - %city % highway 90 - 10
Issues the car has been in for gas milage - nail in tire - broken fuse box latch
Outstanding issues Gas Milage as low as 10
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Exellent
Brakes - any issues? Noise? Premature wear? rusty rotors
MELRX8 11-13-2004, 01:14 PM Build date 09/03
Current mileage 7,500
ecu flash level M
MT or AT MT
Issue with the T/O bearing? None
Issue with noise? None
Tires on the car
Any aftermarket mods Yes
Did the mods effect stock components? If so what was the mod and what did it affect? aFe air filter, better air flow, improved mileage
Driving cycle - %city % highway 60/40
Issues the car has been in for drivers side door lock, window not functioning (electrically)
Did any issues with the transmission get better with the fluid change? quieter, smoother operation
Diff oil - dino or synth synth
Did any issues with the diff get better with the fluid change? No issues to begin with
Body - Any issues? poor front bumper fit and color match
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc clicking sound in drivers seat during turns
Build date: 06-03
Current mileage 9894
ecu flash level M
MT or AT AT
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car
Issues with balance? NO
Any aftermarket mods? NO
Driving style normal or aggressive MIX
Driving cycle - %city % highway 90/10
Issues the car has been in for SMOG PUMP FAILURE
Outstanding issues NO
Transmission oil - Dino or synth OEM
Diff oil - dino or synth OEM
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc A FEW SQUEAKS
Brakes - any issues? Noise? Premature wear? NO
intakedrotary 11-15-2004, 03:06 PM Build date - Not sure, early '04
Current mileage 13500
ecu flash level-none
MT or AT -MT
Any issues with the transmission? If so, what? lost of all gears and clutch and flywheel are gone, blew up clutch
Issue with gears? lost all gears except for 1st.
Issue with the clutch? blew out clutch
Issue with noise? in neutral, clutch released, it's noisy, hampster on wheel!!
Issue with flywheel won't engage with clutch, whinning noise
Any aftermarket mods K&N intake, Tein S-tech springs, borla exhaust
Did the mods effect stock components? If so what was the mod and what did it affect? did not affect anything
Driving style normal or aggressive- normal except for getting onto the interstate then normal again.
Driving cycle - %city % highway 70/30
Outstanding issues
Engine oil - dino or synth - synthetic
Transmission oil - Dino or synth- stock
Diff oil - dino or synth -stock
Body - Any issues?
Interior - Fit and finish. Rattles and squeaks.- driver side window is out of track and driver door handle outside rattles because of soundsystem.
Brakes - any issues? Noise? Premature wear? excessive brake dust
houstonrx8er 11-18-2004, 11:43 AM Build date: 10/03
Current mileage 27000
ecu flash level M
MT or AT AT
Issue with gears? 4th gear i shard to go into at high RPM's (happened with another driver also)
Issue with flywheel ? no
Tires on the car- Potenza
Any aftermarket mods? Replaced stock filter w/K&N
Driving cycle - %city % highway 20%/80%
Engine oil - dino or synth OEM
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc I have 4 rattles back window speaker, center speaker, sun roof when in tilt, both door speakers (or handles)
Slims8 11-18-2004, 11:55 AM Any luck with the trending?
Landon_Starr 12-29-2004, 12:43 PM Any luck with the trending?
This would not be a "statistically sound" sample to trend from. Response to a posting such as this would be significantly biased to people with "problems". There's not a proper control population or a large enough sample size to determine ANY trending here. You'd need data from Mazda to do this appropriately.
--Landon
rotten42 12-29-2004, 12:54 PM Build date Not sure - I'll ad it later
Current mileage 7200 miles
ecu flash level M
MT or AT MT
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car Stock for Summer - Bridgestone LM-22 winter
Issues with cupping on the inside? B
Did the mods effect stock components? If so what was the mod and what did it affect? Just added side strakes for appearance
Driving style normal or aggressive Normal
Driving cycle - %city % highway 80 city 20 highway
Issues the car has been in for Replace the engine @ 2400 miles
Any issues with the motor? yes, replaced - no compression
Omicron 12-29-2004, 01:12 PM Build date: 08/03
Current mileage: 7700
ecu flash level: "N" (one flash past M)
Any issues with the current level? Recalled, but have not myself had any issues
MT or AT: MT
Tires on the car: Pirelli PZero Nero M+S 245/40-18
Any aftermarket mods: Too many to list here. Click the pic in my signature. :D
Driving style normal or aggressive: Normal mostly, sometimes agressive :D.
Driving cycle - %city % highway 20% city, 60% rural roads, 20% highway
Issues the car has been in for: None except 2 recalls (tranny damper and airbag) and reflashes as they come out.
Transmission oil - Dino or synth: Synth (Redline)
Did any issues with the transmission get better with the fluid change? None. No mileage gain noted either.
Diff oil - dino or synth: Synth (Redline)
Did any issues with the diff get better with the fluid change? Smoother.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc No problems.
Brakes - any issues? Noise? Premature wear? No noise, no premature wear
Love my car! :D
Build Date August 2003
Current Mileage 21,000
Flash Level: Original M
Previous issue with prior flash levels: At K the car was fouling its plugs all over the place which caused poor mileage and severe deposits on plugs. The car was misfiring so I had the dealer compression test. They replaced the plugs with the hotter plug range and reflashed to L.
L worked OK, but I got reflashed to M anyway, which has been generally more satisfactory than L.
Manual Trans. The throwout bearing is extremely loud when cold and getting worse. Gears are hard to engage when cold, which I consider pretty normal for any car. Trans works fine other than the throwout bearing which I don't expect to live forever. Other than that, this is a very good transmission.
Running stock Bridgestones in Summer and Bridgestone Winter tires in Winter with an extra set of wheels. The stock Bridgestones started out catching every groove in the road, but have worn very well to become very good tires. The handle well and no longer wander.
No Mods
Driving generally normal; sometimes quite agressive.
40% highway; 60% city
It's been to the dealer for two recalls: tranny damper and airvag wiring; it has been in to be reflashed twice; oil changes; plug replacement due to misfire.
Needs to go in for a clunk out of the front left wheel that sounds like an under torqued sway bar bushing.
Have not repaired the broken sliding compartment in the armrest, which just sucks.
Engine oil: Castrol 5-20. Tried Pennzoil, which was horrible in the car.
Change the oil every 3,750 miles with new filter every time.
Trans and Diff oil are original.
Body solid as a church.
Interior fit and finish are excellent (with the exception of compartment lid)! No rattles, and the car is the quitest car that I have ever driven. Love it!
Brakes have squeaked, mostly in summer, but by applying the brakes with a little more force than normal, they clean up well. They are wearing fine. I will not replace, unless the dealer does it without asking.
Slims8 12-30-2004, 11:02 AM This would not be a "statistically sound" sample to trend from. Response to a posting such as this would be significantly biased to people with "problems". There's not a proper control population or a large enough sample size to determine ANY trending here. You'd need data from Mazda to do this appropriately.
--Landon
First, good luck getting anything from Mazda. Second, this isn't seeing what % of people are having problems. Sure there are more people with problems going to post here than those without problems. This is mainly to see if there is a trend in Builds, Mods, or anything like that in the problems we do see. After recently reading a post which said Mazda admitted to having a "bad batch" of transmissions, it would be nice to see if we can see the same trend. This is especially helping me since I have been paying for a $30,000 that I have driven for 12 days since August 9th due to transmission issues :mad: . I am interested in the kind of data that shows up here.
RX8-TX 12-30-2004, 11:10 AM Build date: Mid '03
Current mileage: 20,600
ecu flash level: M
MT
Issue with gears? Tricky to get out of 1st Gear.
Issue with noise? Noisy with clutch released, quiet when depressed.
Tires on the car Stock: Bridgestone Potenza RE-040
Driving style normal or aggressive: Agressive
Driving cycle - %city % highway: 70/30
Issues the car has been in for: 2 Recalls / Quiet front brake pads / Steering cover insulated for rattles / Shift knob changed for unusual wear
Outstanding issues
Transmission oil - Dino or synth: Never Changed
Diff oil - dino or synth Never Changed
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: some unidentified rattles & squeaks, center console lid is dying.
Brakes - any issues? Noise? Premature wear? Front brake pads replaced for "quiet" version per TSB.
Labop 12-30-2004, 11:23 AM Build date: I'll get back to ya
Current mileage: 9160
ecu flash level: M
MT
Any issues with the transmission: no
Issue with gears: no
Issue with the clutch: no
Issue with the T/O bearing: no
Issue with noise: no
Issue with flywheel: no
Issue with harmonic balanc: no
Tires on the car: OEM Potenzas
Issues with alignment: no
Issues with balance: no
Issues with cupping on the inside: no
Any aftermarket mods: tinting, clear corners, no performance mods
Did the mods effect stock components? no
Driving style normal or aggressive: normal to moderatly aggressive
Driving cycle - 70% city, 30% highway
- Squeeling Brakes
- Fouled Plugs, one plug was bent
- M Flash
Outstanding issues:
- latch on center console is loose
Engine oil - dino
Any issues with the motor: no
Transmission oil - OEM, don't think it's been changed yet
Diff oil - OEM, don't think it's been changed yet
Body - Any issues: swirls on the paint when under flourescent lights.
some rattles on the dash when cornering or over bumps.
yup, see above. since repair action, noise is zero, and there is a dramatic reduction in brake dust.
Rotor 8 01-17-2005, 10:08 PM Hey im thinking of buying a 2005 m/t rx-8 is there anything i need to know about it...problems...need to do's......etc...whats all this reflash stuff im reading...someone explain please....thanks
valpac 01-18-2005, 09:29 PM man, you have alot of reading to do.:)
ProToolsKid 01-24-2005, 12:08 PM Build date Mid '03-Arrived to dealer Aug 1st '03
Current mileage 28,500 Houston's a Big Place and I love to drive..
ecu flash level D/K one level past M
Any issues with the previous level? Car was sluggish
Any issues with the current level? Flooding
MT or AT
Any issues with the transmission? If so, what? YES
Issue with gears? 1st & 2nd Grinding on upshift until dealer changed oil now 2nd & 3rd Grind in upshift horrible and loud grind on any gear downshift to 2nd at any speed even if below 50Mph. Took to dealer and Refused to repair said it was normal Wear and Tear and the service Director was rude and loud about the whole thing. I thingk he influanced the decision w/ the regional rep to over turn the warranty claim. Also after they changed gear oil they frogot to tighten Diff fill plug and oil drained out and burned on muffler. The Same Director denied that it happened there and was a really rude to me about the whole thing
Issue with the clutch? Dealer Said it's worn out but I do nothing but normal Driving very little hard clutching
Issue with the T/O bearing? D/K
Issue with noise? Weird wirring sound in Nuetral
Issue with flywheel D/K
Issue with harmonic balance? D/K
Tires on the car Front= Factory Potenza RE040---Rear=Potenza S03 Factory Size
Issues with alignment? YES
Issues with balance D/K
Issues with cupping on the inside? D/K
Any aftermarket mods Not Really just corner lights and other bulbs, & strakes
Driving cycle - %city % highway 60% City, 40% Highway
Issues the car has been in for Seats Creeking and lack of padding in seat back, Brakes Squeel, Flooding, Center Console Lid 2 times, Door Sills, Rattilng in Rear doors, CAT Ratteling, Vibration Mount on Tranny, Air Bag Rattle, Metallic Ratteling sound 4 times ended up being rotor shields hitting rotors when crossing over Lane markers, Rear Cup Holder Lid Broke on first use, Front Bumper Sag, Ignition switch Loud when shut of car, Dealer forgot to tighten oil fill plug on differential, Water Pupm Leaking and more.
Outstanding issues
Engine oil - dino or synth Castrol GTX
Any issues with the motor? Feels Sluggish and weird in Idle
Transmission oil - Dino or synth Dealer replaced
Did any issues with the transmission get better with the fluid change? Hell No They got worse
Diff oil - dino or synth Dealer Installed
Did any issues with the diff get better with the fluid change? Hell No, Dealer forgot to tighten fill plug sprayed gear oil all over muffler and exhaust, very stinky
Body - Any issues? Front Bumper Sag, Fog Lights keep cracking not hitting anything I think is the heat and Glass.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Yes Center Console broke twice, Seats Squeek, Also there was an issue with Driver seat and a seat frame protruding too far forward and hurtng my lower back over time got worse and lots of other squeeks and rattles
Brakes - any issues? Noise? Premature wear? Already Replaced but lots of origional issues included Rotor Warping 3 time. Brakes Squeeled really bad, and pads wore down too quickly I changed at 18,000 probably coz of rotors warping
Build date March 2004
Current mileage 10,252
ecu flash level M
Any issues with the previous level? Always had M
MT or AT
Any issues with the transmission? No
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car Toyo Garit HT 215-55-17
Driving style normal or aggressive Aggresive
Driving cycle - %city % highway 40 / 60
- condensation in rear taillight
Outstanding issues
Brakes - any issues? Noise? Premature wear? Noise in front
ProToolsKid 01-24-2005, 12:40 PM First, good luck getting anything from Mazda. Second, this isn't seeing what % of people are having problems. Sure there are more people with problems going to post here than those without problems. This is mainly to see if there is a trend in Builds, Mods, or anything like that in the problems we do see. After recently reading a post which said Mazda admitted to having a "bad batch" of transmissions, it would be nice to see if we can see the same trend. This is especially helping me since I have been paying for a $30,000 that I have driven for 12 days since August 9th due to transmission issues :mad: . I am interested in the kind of data that shows up here.
What post is it talking about Mazda admitting a bad batch of transmissions?
Slims8 01-24-2005, 12:48 PM http://www.rx8club.com/showthread.php?t=49193
I don't know if this is the only one or even how reliable it is, but that is the link. I finally got mine replaced after months of problems.
airboss 01-30-2005, 02:50 AM antbody have problems with the stearing? Mine is funcky the first 5 minute of driving.
zoom44 01-30-2005, 12:19 PM Hey im thinking of buying a 2005 m/t rx-8 is there anything i need to know about it...problems...need to do's......etc...whats all this reflash stuff im reading...someone explain please....thanks
hey welcome aboard.
first you are buying a 2005 - there havent been any 2005 specific problems yet that i know of so your good to go since all of the 2004 problems should be absent from your car
second- time for you to do some reading. i dont mean to sound harsh but i have expained MANY TIMES ALREADY thank you. I(and several others) have spent a considerable amount of my time making sure i understand the flash situations and then posting about it here so that my fellow 8 owners know whats going. so go back to reading those flash threads then if you still need some questions asked- ASK IN THOSE THREADS.
rx8pilot 02-01-2005, 11:22 AM Build date: Aug 2003
Current mileage 25,000
ecu flash level: M
Any issues with the current level? rough idle maybe? other than that..no
MT or AT: MT
Issue with the clutch? sometimes have it pressed in all the way and it still grinds...
Issue with the T/O bearing? unknown
Issue with flywheel? no
Issue with harmonic balance? unknown
Tires on the car: Stock size Potenza S-03 Pole Positions (stocks worn out after 21k)
Issues with balance? no
Any aftermarket mods: yes
Did the mods effect stock components? If so what was the mod and what did it affect? mazdaspeed strut tower brace....handling..and brake pedal feel better
Driving style normal or aggressive....aggressive most of the time.
Driving cycle - 65%city 35% highway
Issues the car has been in for: just normal tsbs and and minor fixes..(replaced console cover, replaced both rear tailights.(condensation)..replaced right passenger headlamp assy.. (hid housing rubbing against frot lense)
Outstanding issues
Engine oil - dino or synth: Synthetic..(castrol)
Transmission oil - Dino or synth: unknown.. whatever the dealer used
Did any issues with the transmission get better with the fluid change? unkown
Diff oil - dino or synth: unknown
Did any issues with the diff get better with the fluid change? unknown
Body - Any issues? only in the paint dept. brilliant black..and it's very easy to scratch..chip..and has a disgusting orange peel effect to it.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc : Starting to rattle a little..squeek a little... normal wear for 25,000miles...the heater dial broke..was replaced under warranty. the emergency brake does not want to go down in the cold.. after it's been parked all night... the seat heater switches are very hard to toggle in the cold also... the left edge of the seat on the hip where the plastic meets the leather...it digs into my hip sometimes...could have added more padding to the seats there.. also the center strips along the transmission tunnel (silver) scratch really easily..especially on the passenger side where they try to put the seat belt buckles in and bang it against the strip. do not like the positioning or styling of the e-brake..
Brakes - any issues? Noise? Premature wear?[/QUOTE]...oh yeah..lots of high pitched squeels at continuous slow stops..but was fixed by the tsb...does seem to take a little longer to stop now though...not much..but a little noticeable.
abbid 03-28-2005, 11:54 AM This thread needs a BUMP
RX8Mama 03-29-2005, 01:38 PM Build date: Puchased 11/03 (not sure of build date)
Current mileage: 14000
AT
Issue with the clutch? n/a
Issue with noise? that's an understatement
Tires on the car Stock: Not sure, its been living at the dealership.
Issues the car has been in for: Recalls, check engine light coming on, ABS and Traction light coming on, hesitation and losing power between 2nd and 3rd, 4 PCM updates or replacements,you name it. Right now getting a new engine and new injectors. Trying to get mazda to buy back the POS.
Outstanding issues
Any issues with the motor? Getting a new one as we speak
Interior - Fit and finish. Rattles and squeaks, glove box broke, rattle in driver side door.
Brakes - any issues? none
Akisan2 04-20-2005, 12:08 AM Build date 9/2003
Current mileage 3090
ecu flash level M i think, but it write over N, is there N flash? I didn't see it in the explanation...
Any issues with the current level? not yet
MT or AT MT
Any issues with the transmission? If so, what? Slightly
Issue with gears?2nd seems a bit loud when down shift
Issue with noise? not yet
Tires on the car dunlop(cheaper ones)
Issues with alignment?not yet
Issues with balance not yet
Issues with cupping on the inside? nope
Any aftermarket mods no, definitly coming though heh :)
Driving style normal or aggressive slightly aggressive
Driving cycle - %city % highway 50% city 50% HWY
Issues the car has been in for brakes
Outstanding issues rattles on driver side door
Any issues with the motor? not yet
Body - Any issues? so far ok
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Driver side window rattles a bit
Brakes - any issues? Noise? Premature wear? so far ok, but again the car only has 3090 miles.
My 1st post! lol Glad to be a part of a club!
Ray
khoney 05-07-2005, 05:52 PM Build date 5/30/03
Current mileage 36,150
ecu flash level N
Any issues with the previous level?No
Any issues with the current level?Started out smelling sulphur, but it's gone now.
MT or AT [/b]MT[/b]
Issue with noise? Only with the ridiculously looud throwout bearing noise
Tires on the car OEM Bridgestone
Driving style normal or aggressive Normal with moments of aggression - redline when possible
Driving cycle - %city % highway 40/60
Recalls
Reflashes
Poor A/C performance
Creaking seat
Excessive vibration at idle
Outstanding issues
Poor A/C performance - don't think they replace d the Amplifier with a newer version
Creaking seat (replaced seat rails, creaking was gone for a few weeks, now it's back)
Excessive vibration at idle ("could not duplicate"
Engine oil - dino or synth Synth
Any issues with the motor?No
Body - Any issues? Orange peel
No issues, other than having 3-year-old maps for the nav system
Brakes - any issues? Noise? Premature wear?Excessive brake dust
loco4rx8 05-07-2005, 07:51 PM Build date - June 23, 2003
Current mileage - 35,250
ecu flash level - N
Any issues with the previous level? - no
Any issues with the current level? - none so far (just got it last week)
MT or AT - MT
Any issues with the transmission? If so, what? - no
Issue with gears? - no
Issue with the clutch? - no
Issue with the T/O bearing? - no
Issue with noise? - gear rollover noise with foot off clutch (normal)
Issue with flywheel - no
Issue with harmonic balance? - no
Tires on the car - Potenza RE040 (originals still going strong), Dunlop Winter Sport M3's for winter months
Issues with alignment? - no
Issues with balance - no
Issues with cupping on the inside? - no
Any aftermarket mods - Borla exhaust
Did the mods effect stock components? If so what was the mod and what did it affect? - no
Driving style normal or aggressive - normal, but I do redline it often
Driving cycle - %city % highway - 85% highway
-The two recalls
-Squealing brakes TSB
-New A/C amplifier TSB
Outstanding issues
-Has been slow to start up lately, got N-flash and new spark plugs at last dealer visit (35,000 mi svc), still evaluating if it made any difference, asked for new spec battery but they didn't think it needed it
Engine oil - dino or synth - dino
Any issues with the motor? - no
Transmission oil - Dino or synth - Redline
Did any issues with the transmission get better with the fluid change? - no issues, no change
Did any issues with the diff get better with the fluid change? - no issues
Body - Any issues? - no
-Couple occasional rattles (driver door, passenger seat headrest rotor), but they do not happen all the time so I just ignore them when they do
Squealing brakes - got new brakes from Mazda and they've been quiet since - and the great brakes have saved my butt several times
xabjw4 05-26-2005, 11:46 AM Build date- July 03, purchased May 04 with 16 miles on it. Morries Mazda, Minneapolis
Current mileage- 6,500
ecu flash level- N
Any issues with the previous level? none, thought it was at J or K
Any issues with the current level?- none, better milage and flatter response when passing 6250 rpm, I think thats better
MT or AT- MT - Touring
Issue with noise? - normally noted Gear rollover sound at idle with clutch pedal up
Tires on the car - factory Bridgestones
Any aftermarket mods - None
Driving style normal or aggressive - normal, few times above 7 k and a 25 minute cruise at 105 mph. getting 19.5 to 23 mpg on every tank
Driving cycle - %city % highway - 20% city & 80% Hwy
Issues the car has been in for - No problem, reflash to "N" in Apr. 05
Engine oil - dino or synth - Valvoline 5W-20 & 5W-30 , Dino
Any issues with the motor? - None
Transmission oil - Dino or synth - Synth, Amsoil - 75-90
Did any issues with the transmission get better with the fluid change? - Changed to Synth at 800 miles, didn't note any difference but @ -35 F northern Minnesota winters the trans. is smooth even at start-up. Has to help anytime.
Diff oil - dino or synth - Synth, Amsoil , 80-90
Did any issues with the diff get better with the fluid change? - same as above
Body - Any issues? - little water in fog lights housings
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc - No issues to date
Brakes - any issues? Noise? Premature wear? - Seems to be fine.
Reply With Quote - I changed the engine oil at 200 miles, 800 miles, 2500 miles & 6k so far. Went to the 5w-30 at 6k in mid Apr. normal oil usage noted
Razz1 05-28-2005, 12:38 AM Build date July 2003
Current mileage 18300
ecu flash level M
MT or AT MT
Issue with the clutch? standard noisy roller gear
Issue with the T/O bearing? NO,
Issues with alignment? NO wandering is normal for sports cars. proves a good mfg. car
Any aftermarket mods Yep
Did the mods effect stock components? NO
Driving cycle - %city % highway 90% highway 10 % city
Outstanding issues Need more HP
Engine oil - 5-20w
Any issues with the motor? Need more HP
Transmission oil - Normal
Diff oil - NO
Body - Any issues? Need BODY KIT
Interior - Fit and finish. NO problems
abbid 06-28-2005, 11:48 AM Bump, PLEASE ADD INFO!!!, all you damaged transmission people, post here!
Rotary Rasp 06-28-2005, 12:27 PM Build date 7/04
Current mileage 12500
ecu flash level M
MT or AT MT
Any aftermarket mods No Egine Mods
Issues the car has been in for Brake recall
Outstanding issues
Transmission oil - Dino or synth Stock, soon to be synth
Diff oil - dino or synth Stock, soon to be synth
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Could be better, interior plastic is cheap.
therm8 06-28-2005, 01:06 PM Build date Aug 2003
Current mileage 41578
ecu flash level L
AT
Tires on the car? Potenzas (first 25k) BFG KDW2s (last 16k)
Any aftermarket mods? catback
Driving style normal or aggressive? aggressive
Driving cycle - %city % highway? 70/30 (1st 25k) 50/50 (last 16k)
Issues the car has been in for: Recalls, normal maintenance, body repairs
Outstanding issues? no
Engine oil - dino or synth? Dino
Transmission oil - Dino or synth? Dino
Body - Any issues? idiot's running into it
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts, etc? Driver's seat creaks occasionally (probably needs tightened again), steering wheel airbag/horn cover rattles occasionally.
Brakes - any issues? Noise? Premature wear? Squeak when cold out, and sometimes after hard use.
dwill9578 06-28-2005, 04:32 PM Build date 11/03
Current mileage 10.000
ecu flash level-M
Any issues with the previous level?-NO
Any issues with the current level?-NO
MT or AT-MT
Any issues with the transmission? If so, what?-NO
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car-NO issues
Issues with balance
Any aftermarket mods-NOT YET
Driving style normal or aggressive-NORMAL
Issues the car has been in for-NONE
Outstanding issues
Engine oil - dino or synth-DINO
Any issues with the motor?-NO
Transmission oil - Dino or synth-DINO
Diff oil - dino or synth-DINO
Body - Any issues?-NO
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc-RATTLES IN DOOR WHEN COLD
Brakes - any issues? Noise? Premature wear?-THEY SQUEAK FOR NOW GETTING REPAIRED 7-5-05
abbid 07-07-2005, 02:14 PM bump
agoodcave 07-08-2005, 04:08 PM Build date 12/03
Current mileage 10.100
ecu flash level-N
MT or AT-MT
Issue with gears?
Issue with noise?
Issue with flywheel
Issues with balance
Driving cycle - %city % highway 80/20
Issues the car has been in for-flash per Mazda request (not my request)
Outstanding issues none
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? none
Brakes - any issues? Noise? Premature wear? none
zevans 07-14-2005, 09:41 AM Build date - delivered UK August 04
Current mileage - 23785
ecu flash level M+
MT or AT
Issue with gears?
Issue with noise? -- Release bearing noisy but always has been, think this is normal
Issue with flywheel
Tires on the car - Now on PZeros, Bridgestone RE040 were awful in every way and lost sidewall strength before tread fully worn. Replaced at 12k ish
-- Had K&N Typhoon for about 10000 miles. Removed again for noise and suspected higher intake temps. Car had slightly more top-end but was more prone to bog on hard launches and less torque below ~5k. Car seemed to have more heat issues - felt ignition retard on several occasions, has not happened again since removal.
-- mix including track use. Car usually unhappy queueing, never had problem when driving hard.
Totally varies from day to day, couldn't put figure on it, sorry.
Issues the car has been in for - NONE
Outstanding issues - NONE but headlight levelling warning appeared once or twice over last 500 miles
Engine oil - dino or synth - Mazda at changes, topped up with Fuchs or Esso semi-synth
Any issues with the motor? NONE
Did any issues with the transmission get better with the fluid change? - Will know RSN
Did any issues with the diff get better with the fluid change? - Will know RSN - occasionally snatchy after very sustained hard use
Body - Any issues? Lost occasional bolts from undertray - plan to put threadlock on next time
Central round piano black piece on audio console rattles
Rear speaker rattle
- SLIGHT suspect front right piston occasionally getting stiff, only problem when car cold
Don't consider dust an issue IMHO, all brakes this good will be dusty
beachdog 07-14-2005, 02:51 PM You can all stop posting into this thread. Samsonite sold his 8 and doesn't come around anymore. He never did the promised analysis.
Anyone else know statistics?
Fritz the Cat 07-14-2005, 03:25 PM Build date: January 2004
Current mileage: roughly 26,000 kilometres, or 15,600 miles
ecu flash level
Any issues with the previous level?: No
Any issues with the current level?: No
MT or AT: MT
Any issues with the transmission? If so, what?: No
Issue with gears?: No
Tires on the car: See my signature
Any aftermarket mods: Window tinting, clear bra
Did the mods effect stock components? If so what was the mod and what did it affect?: No effect on stock components
Driving style normal or aggressive: Aggressive
Driving cycle - %city % highway 80% city, 20% highway
Issues the car has been in for: brake squeal, floor mat pin
Outstanding issues: Need the R flash at some point
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: None
Brakes - any issues? Noise? Premature wear?: Brake noise, as per the TSB. Fixed twice before they got it right.
QwikSlvr 08-11-2005, 09:10 AM All,
Build date 04
Current mileage 9,400
ecu flash level unsure, a whole different issue with my dealer
Any issues with the previous level? n/a
Any issues with the current level? not really
MT or AT 6spd MT
Any issues with the transmission? If so, what? Yes rear gear cluster loud when clutch not depressed.
Issue with gears? see above could be gear bearing
Issue with the clutch? slips to easy smells rotten when parked
Issue with the T/O bearing? could be not so sure
Issue with noise?sounds like an old Ford drivlne
Issue with flywheel could be, clutch slips
Tires on the car dunlop.
Issues with balanceno
Issues with cupping on the inside?no
Any aftermarket mods mazda speed voltage stabalizer
Did the mods effect stock components? If so what was the mod and what did it affect? Lights got brighter, Radio became clearer and throttle is crisper.
Driving style normal or aggressive semi aggressive
Driving cycle - %city % highway 80 city 20 hwy
Issues the car has been in for Ecu flash update but still don't know what update and blow back soiling air filter seriously
Outstanding issues havn't checked oil filter in 2,500 k
Any issues with the motor?none
Body - Any issues? creaks like a 67 nova
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc when every I start rolling after its been parked it's like it pulls it's self out of a hole
Brakes - any issues? Noise? Premature wear? high dust factor
delrmx01 12-16-2005, 01:22 PM What ever happened to this?
swoope 12-17-2005, 03:02 AM Build date 10/03
Current mileage 37500miles
ecu flash level r
MT or AT mt
Issue with noise? makes rollover noise with clutch out
Tires on the car bridgesones for 27m miles. now kumho spt
Any aftermarket mods revi + duct, corksport exhaust
Issues the car has been in for mop replaced
Engine oil - dino or synth dino castrol 5/20
Transmission oil - Dino or synth synth at 30k miles
Did any issues with the transmission get better with the fluid change? YES THIS IS ONE OF THE BEST MODS I HAVE DONE.
Diff oil - dino or synth synth at 30kmiles
Did any issues with the diff get better with the fluid change? unchanged
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc no
VOODOO8 12-17-2005, 02:18 PM Build date: June 2003
Current mileage: %9285
ecu flash level: Factory Suggested as of 09/05
Any issues with the previous level?: None
Any issues with the current level?: None
MT or AT: MT
Any issues with the transmission? If so, what?: None
Issue with gears?: None
Issue with the clutch?: None
Issue with the T/O bearing?: None
Issue with noise?: None
Issue with harmonic balance?: None
Tires on the car: Goodrich g-Force KDW2 Summer; Blizzaks Winter
Issues with cupping on the inside?: None
Any aftermarket mods: Mazdaspeed Rear Wing and Front Bra in winter
Did the mods effect stock components? If so what was the mod and what did it affect?: None
Driving style normal or aggressive: Average
Driving cycle - %city % highway: 50/50
Issues the car has been in for: Other than warranty work - Engine replacement, sunroof rattles, Defective tire pressure sensor, early demise of the factory Bridgestone tires with 13K miles.
Outstanding issues: Engine replacement, tire pressure sensor
Engine oil - dino or synth: Standard petro based 5-30W
Any issues with the motor? Yes (see above and past thread on 'Blown Motor' on this web site)
Transmission oil - Dino or synth: NA
Did any issues with the transmission get better with the fluid change?: NA
Diff oil - dino or synth: Factory
Did any issues with the diff get better with the fluid change?: NA
Body - Any issues?: None
Brakes - any issues? Noise? Premature wear?: Factory pads squealed at high ambient temps and were very dusty. Factory spec'd repalcement pads eliminated both issues.
VOODOO8 12-17-2005, 02:21 PM CORRECTION OF MILEAGE IN FIRST POST - (operator error)
Current mileage: 59,285
ecu flash level: Factory Recommended as of 09/05
MT or AT: MT
nedor 12-23-2005, 09:43 AM Build date: July 2004
Current mileage: 1011
ecu flash level: N/A
Any issues with the previous level?: N/A
Any issues with the current level?: N/A
MT or AT: MT
Any issues with the transmission? If so, what?: Yes. Yesterday, when coming to complete stop with gear in first with clutch all the way down, as I was about to put the gear in neutral, I felt a very big bump as if someone rear ended me. Immediately, I checked the gauge and it was slowly climbing down from around 1500 rmp. After this incident, I am noticing gear problems and when coming to a full stop, somethhing is moving around. It is making thumping noises.
Issue with gears?: 1st, 2nd, 3rd(after above incident). Something underneath the car is rattling.
Issue with the clutch?: Does not grip well. Will not pickup speed unless gas pedal is pressed down quite a bit.(after above incident)
Issue with the T/O bearing?: I am mechanically challenged. :spank:
Issue with noise?: Yes, 1st and 2nd whinning and grinding noise
Issue with flywheel: I am mechanically challenged. :spank:
Issue with harmonic balance?: I am mechanically challenged. :spank:
Issues with alignment?: Car vibrates when breaking hard(alignment issue?)
Issues with cupping on the inside?: I am mechanically challenged. :spank:
Driving cycle - %city % highway: 20 City / 80 HW
Issues the car has been in for: Rear passenger seat belt buckle, Damges on shift knob, rusted rear rotors, door dents, bad window tinting.
Outstanding issues: Door dents, bad tinting, factory paint drips, transmission problem, oil foams, average 15 mpg fuel consumption
Engine oil - dino or synth: I forget the number. Using oil that is suggested in the manual.
Body - Any issues?: About 5 paint drips size of dime through out the top of the car. Door dents before picking up the car from dealer. Fine lines on hood, spoiler and trunk. About 8 stone chips and tons of stone chips in windshield.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: Rattles on passenger side. Sounds like seat belt. When coming to full stop, something is moving around. I can hear thumping noises from the rear. This happened yesterday right after the transmission problem.
Brakes - any issues? Noise? Premature wear?: Car vibrates when hard breaking.
zenmoused 02-27-2006, 10:54 AM All,
In an attempt to trend the issues with the 8's I will be compiling a list and publish the results once we have a sampling. Please provide the following data for the poll.
Build date
Current mileage: 1290
ecu flash level: L
Any issues with the current level? Not that I can tell.
MT or AT: Manual
Issue with gears? Yes. Brand New car. First to second sometimes fails at high rpm. No matter how carefully I shift.
Issue with the clutch? No.
Issue with the T/O bearing? Don't know.
Issue with noise? Tranny/servo seem overly noisy. Granted I never had an RX-8 before, so maybe this is normal. Downshifting creates a loud whirring.
Issue with flywheel? No.
Issue with harmonic balance? Not that I can tell.
Tires on the car
Issues with alignment? No, that's fine.
Issues with balance? No, that's good.
Issues with cupping on the inside? Not yet.
Any aftermarket mods: Not yet.
Driving style normal or aggressive: Usually normal. Aggressive maybe 5% of the time.
Issues the car has been in for: Headlight levels were off when I bought the car.
Outstanding issues
Engine oil - dino or synth: Castrol semi-synth
Any issues with the motor? No, she purrs beautifully.
Transmission oil - Dino or synth: Whatever is in there stock.
Diff oil - dino or synth: Stock
Body - Any issues?: None thus far.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Rattling noise at high rpms on the passenger side.
Brakes - any issues? Noise? Premature wear?[/QUOTE] Squeak sometimes. I expected this brand new, to wear them in, but it's been a thousand miles. You'd think they'd be done.
suzuki_rider22 09-21-2006, 01:02 AM Build date Aug 2003
Current mileage 13100
ecu flash level "M"
MT or AT - MT
Any issues with the transmission? Yes
If so, what?
Issue with gears? yes - 2nd, 3rd, 6th
Issue with the clutch? - Yes - "Exploded"
Issue with noise? - Yes
Issue with flywheel
Tires on the car - Factory
Issues with balance
Driving style normal or aggressive - Normal
Driving cycle - %city % highway - 65% Highway, 35% city
Transmission Failure (Gear problems - 40 days in Shop)
Transmission Problems (Gear Failures - 12 days in Shop)
Clutch Exploded (9 days in shop... 12 days in my driveway)
Outstanding issues
Clutch
Engine oil - dino or synth - Dino
Brakes - any issues? Noise? Premature wear? - Noise
did you change the clutch yourself? if so how complicated was it?
BLACKOUT 10-08-2007, 10:29 AM In an attempt to trend the issues with the 8's I will be compiling a list and publish the results once we have a sampling. Please provide the following data for the poll.
Build date-2004
Current mileage-34,000 (however had trans issues since 10k)
ecu flash level
MT or AT. MT
Issue with gears? 5th gear not engaging clean and grindingon high RPM downshift.
Issue with noise? YES
Issue with flywheel
Tires on the car
Issues with balance
Did the mods effect stock components? If so what was the mod and what did it affect? Aftermarket mods but none that affect any of the problems i have.
Driving style normal or aggressive- normal to spirited at times. take it to redline periodicly however usually keep it from 3k-5k range for driving.
Driving cycle - %city % highway- 40%city 60%highway
Outstanding issues
Any issues with the motor? syncro. RoyalPurple
Did any issues with the transmission get better with the fluid change? Noise was getting gradually worse and grinding more and more shifting to 5th so about 5k ago i drained the trans and put Royal Purple in and the noise and shift issue dissipated. Until oct.5th and goin from reverse to first box turned to sludge feeling and when put into gear started hearing a loud metalic swirling from the gearbox. Still waiting for the reply to this from mazda
Did any issues with the diff get better with the fluid change?- synth
BostonSE3P 11-07-2007, 04:30 PM Current mileage- 22780
ecu flash level- not sure just bought the car a couple months ago and i dont know how to check
MT or AT
Any issues with the transmission? If so, what? yes it grinds in second, forth and sixth
Issue with gears?2nd 4th and 6th
Issue with the clutch?makes noise when in neutral and clutch pedal isnt down
Issue with the T/O bearing? A grinding sound when clutch pedal isnt pressed
Issue with noise?
Issue with flywheel
Tires on the car
Issues with balance
Did the mods effect stock components? If so what was the mod and what did it affect? I have a cat-back exhaust, it doesnt effect anything
Driving style normal or aggressive- normal driving
Driving cycle - %city % highway-75% city and 25% highway
Issues the car has been in for CEL
Outstanding issues-None
Engine oil - dino or synth-Dino
Any issues with the motor? No but i found out there is going to be a recall on all 04 and 05 engine
Transmission oil - Dino or synth-Stock oil
Did any issues with the transmission get better with the fluid change?I didn't cause i dont want to void my warranty
Body - Any issues? bent in the door
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? My seat squeaks
Brakes - any issues? Noise? Premature wear?I have a lot of brake squeakl
Soravia 12-01-2007, 10:22 PM Build date - 2003 Nov
Current mileage - 50K
ecu flash level - Dec 2006
Any issues with the previous level? - None on record
Any issues with the current level? - None so far. Can start from stalled engine stop.
MT
Any issues with the transmission? If so, what? - 3rd grinds when shifting up at 30MPH to 40MPH. Doesn't not grind above 40MPH. 4th gear has similar issue.
Issue with gears? - Yes
Issue with the clutch? - Not sure, clutch seems fine on all other gears.
Issue with the T/O bearing? - Not sure. Seems to work on all other gears.
Issue with noise? - No noise.
Issue with flywheel - No issue.
Issue with harmonic balance? - WTF is that?:eyetwitch
Tires on the car - Stock size replacement Yokohama/Kumho tires.
Issues with alignment? - None.
Issues with balance - None.
Issues with cupping on the inside? - None.
Did the mods effect stock components? If so what was the mod and what did it affect? - N/A
Driving style normal or aggressive - Normal. 3000- 7000 rpm.
Driving cycle - 30%city 70% highway
Issues the car has been in for - Most Recalls including Ball-Joint, Damper Heat-Shield, ECU flash. Fuel Tank repair.
Outstanding issues - Tire Pressure sensor
Engine oil - Castrol GTX 5w-30
Any issues with the motor? None so far.
Transmission oil - Possibly stock.
Did any issues with the transmission get better with the fluid change? - No change so far.
Diff oil - Possibly stock.
Did any issues with the diff get better with the fluid change? - No change so far.
Body - No Issues.
Interior - Only my key chain rattles.
Brakes - Time fro another pad replacement. No noise.
thered1996 01-15-2008, 08:58 PM Build date 07/03
Current mileage 60,200
ecu flash level not sure, was done in Jan 2007
MT or AT - MT
Any issues with the transmission? If so, what? None
Issue with gears? None
Issue with noise? Some, in neutral clutch out
Issue with flywheel None
Issue with harmonic balance? None
Tires on the car Pirelli P-Zero Nero
Any aftermarket mods Not really - KN air filter
Did the mods effect stock components? If so what was the mod and what did it affect? No
Driving style normal or aggressive - somewhat agressive
Issues the car has been in for - water pump, tires, failed coil packs, burned out catalytic converter
Outstanding issues - none
Engine oil - dino
Any issues with the motor? slightly rough idle
Did any issues with the transmission get better with the fluid change? Not yet changed
Diff oil - dino
Did any issues with the diff get better with the fluid change? Not yet changed
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? door sill clips never fit properly, front two center console slide parts failed by 30K miles, minor rattles all around
Brakes - any issues? Noise? Premature wear? had to replace at 35K (used Hawk pads), rotors slightly warped by 25K miles but not yet bad enough to replace
staticlag 01-15-2008, 09:31 PM Build date Aug 2003
Current mileage 39K
ecu flash level - Racing Beat
Any issues with the current level? - No engine immobilizer, CEL
MT
Yes, broken :(
Issue with the clutch? Chatter
Issue with noise? Whine from rebuild
Tires on the car
Issues with balance? balance weights came off at track day
Driving style normal or aggressive aggressive
leaky windshield
transmission rebuild
Outstanding issues
Engine oil - dino or synth 90% synth, 10% dino
No
Diff oil - dino or synth Synth
No
Body - Any issues?
Climate Control cracked
No
Q121825 01-16-2008, 09:40 PM Build date 11/03
Current mileage 120,000
ecu flash level? Unknown, last flash Nov 2006
MT or AT - MT
Tires on the car:: General Exclaim UHP
Any aftermarket mods? None
Driving cycle - %city % highway 15/85
Issues the car has been in for - Replaced failed O2 sensor at 9k miles and that's been it
Outstanding issues - SSV stuck open CEL
Engine oil - dino
Transmission oil - Synth, changed ever 60k
Did any issues with the transmission get better with the fluid change? No issues
Diff oil - Synth, changed every 60k
Body - Any issues? None except for idiots in parking lots, one minor dent on front passenger wheel well.
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? The center console slide never really held well, minor rattle somewhere in the dash.
Brakes - any issues? Noise? Premature wear? Pads replaced at 35k, new RacingBrake discs installed at 70k with Hawk pads. Checked pad wear/disc wear at 120k miles and everything is "green".
Beren682 06-03-2008, 04:14 PM Build date - 2005
Current mileage - 47000
ecu flash level - Never
MT
Issue with noise? With clutch pedal not being touched, bearings whine. If you applied any pressure to clutch pedal, noise disappeared. At 36931 miles, had trans front countershaft bearing, input shaft bearing and pilot bearing (due to abnormal pattern on input shaft) replaced. Noise completely gone. Everything much quieter. At 45487 miles, had all 3 bearing replaced again for same noise, after beginning to hear it again approximately 3000 miles before. I'm at 47000 miles, and am hearing it again but a little worse than before. I have no problems shifting, my clutch is operating great (still a solid 50-60% left). Basically, nothing wrong with the car at all, but this irritating noise. Something makes me think there is something unfixed causing the bearings to go bad. But also, the above statement of changing the pilot bearing the 1st time due to abnormal wear on input shaft, makes me think that the abnormal wear is still on input shaft, and it's forcing the bearings to go bad the 2nd two times.
Tires on the car - all purpose bridgestone 225/45ZR18
Driving style normal. Recommended shifts in heavy traffic and residential zones. Open highway or 1st car at light, 5000-6000 rpm shifts. Occasional red line when feeling spirited.
Driving cycle - 50%city 50% highway
Issues the car has been in for: see above trans
Engine oil - dino
Any issues with the motor? Had recall tweeks made (but no repairs, just reconfigs)
Transmission oil - whatever mazda is using these days. They've switched it up on me.
Body - No issues
Interior - Fit and finish. Quiet.
Brakes - Normal wear
Bishop 07-09-2008, 09:04 PM It sounds like most problems with the tranny on the MT's only saw one AT reply
Actually, I have an AT and I just started getting this weird "stutter" between 2nd and 3rd today. Scared the crap outta me. 2nd revs way to slow and high before switching and the same with 3rd into 4th. I have NO idea whats wrong but recently the check engine light came on and the service guy at Burlington Mazda told me it's likely that the gas cap was loose and it'll take about 71 turn overs to reset the computer to turn off the warning light. It's still on but not flashing which I'm told is the "get to a service bay ASAP!" warning.
fedno5 10-03-2009, 02:19 PM Build date cars in the shop dont know the build date this second
Current mileage 31500
ecu flash level ? dont know
MT or AT - MT
If so, what?
Issue with the clutch? - Yes makes noise
Issue with the T/O bearing? yes makes noise
Issue with flywheel: replaced once
Tires on the car - potenzas in the front falken ziex in the back (LOVE THEM)
2. O2 sensor went bad at 27000 miles
Brakes - any issues? Noise? Premature wear? - switched to ceramics no squeaks but the car has always pulled a little when coming to a dead stop. About to put on drillled and slotted rotors
fire_wing95 11-17-2010, 03:09 AM Build date: 05/03
Current mileage: 105k but has a brand new engine with 5k mi on it.
ecu flash level: L
Any issues with the previous level?: ?
Any issues with the current level?: NO
MT or AT: MT
Any issues with the transmission? If so, what?: Replaced pin and needle bearings inside bearing housing of tranny
Issue with gears?: grinds 2nd gear from 1st above 5k rpm @ NOT
Issue with the clutch?: No. New clutch installed recently
Issue with the T/O bearing?: NO
Issue with noise?: Squealing sound from somewhere but goes away has the clutch pedal is pushed in. Squealing noise comes back as clutch pedal is released.
Issue with flywheel: NO
Issue with harmonic balance?: NO
Issues with alignment?: NO
Issues with balance: NO
Issues with cupping on the inside?: NO
Any aftermarket mods: NO
Driving style normal or aggressive: Aggressive but highest shifting occurs no more than 8k rpm
Driving cycle - %city % highway: 30% city/70% highway
Issues the car has been in for: Noted above.
Outstanding issues: When turning through sharp turns at high speeds, the brakes seem to apply themselves and slow down the car, (while turning right, seems the right side brakes are being applied and vice versa for left turning.) Rotors have been recently replaced and new brakes.
Engine oil - dino or synth: Dino
Any issues with the motor?: Nope
Transmission oil - Dino or synth: Dino
Did any issues with the transmission get better with the fluid change?: N/A
Diff oil - dino or synth: Dino
Did any issues with the diff get better with the fluid change?: N/A
Body - Any issues?:
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? NO
Brakes - any issues? Noise? Premature wear?: NO
terrypk1 06-21-2011, 04:57 PM Build date 2003 August
Current mileage 56286 km
ecu flash level not sure maybe still at the original level.
Any issues with the previous le NA
Any issues with the current level? NA
MT or AT MT
Yes, recently, it started to be harder to shift into gear under high load (acceleration)
Tires on the car No problem.
Issues with balance
BHR Flywheel, Agency Power pully system, Agency power stainless steel brake line (which is too short)
Driving style normal or aggressive Agrressive
Driving cycle - %city % highway 20/80
Bad gas cap providing little seal. Dealer mistakenly replaced gas pump while damanging the car causing the one way valve to be stock and gas will not go in to the tank easily unless time is taken.
Outstanding issues
Broken key remote receiver, tail light condenstation.
Engine oil - dino or synth synth
Transmission oil - Dino or synth Redline MT90
Did any issues with the transmission get better with the fluid change? NOPE
Diff oil - dino or synth Racing Purple forgot which one
some rattle here and there. nothing important
No
