Does anyone know if the RX-8 needs premium gas?
Old Oct 29, 2004 | 07:43 AM
Gambit's Avatar
Screw gas mileage
Just got my 8 last week and i was lookin through the manual, and it said it required 91 octane gas...every review/dealer says that it needs 93 though. Does anyone know if they're all bs-ing me, or is the manual wrong?
Old Oct 29, 2004 | 07:56 AM
ArvinC's Avatar
The manual isn't wrong...
...it's just that 91 octane may not be a common grade of fuel in your (or other owner's) area. As an example, where I live, the only stations that offer a 91 grade are Sunnoco, which they call "Premuim" (93 is their "Super"). Every other gas company only offers 87, 89 or 93.
Do a search on octane and you will definately find more on this topic. Many owners have taken to using 89-grade and have been driving well with it for a while. The definate consensus is that the most important aspect of the fuel you use is it's quality...stay with the big boys like Shell (I only use their V-Power), Mobil, Exxon, etc. "Generic" gasolines have not gotten very favorable responses from many owners.
Arvin
Old Oct 29, 2004 | 08:02 AM
Gambit's Avatar
Screw gas mileage
Ok, thanks...around me they usually sell 87, 91 and 93. I tried searching for octane but didn't really find anything applicable...guess I looked in the wrong place
Old Oct 29, 2004 | 08:43 AM
ArvinC's Avatar
No problem...
...and BTW, crongrats on getting the 8! :D
You'll love it...and, as many have taken to calling us owners, welcome to the cult!
Arvin
Old Oct 29, 2004 | 10:13 AM
NomisR's Avatar
You can even you regular 87 if you wish, no prob there.
Old Oct 29, 2004 | 10:15 AM
Nubo's Avatar
Lubricious
Where are you? My manual (usa) says 87 is ok, and that's what I use.
Old Oct 29, 2004 | 10:21 AM
bryrx804's Avatar
Yes but its RECEMMENDED to use "Premuim" Some Rx8 will develop a squeaking sound that is caused by the low octane......
THIS HAS BEEN COVRED WAY TO MUCH>>>>>
NUF SAID... :p
Also theres 94-95 down in indy.. :D
Old Oct 29, 2004 | 10:27 AM
Gord96BRG's Avatar
91 IS premium! Regular is 87, mid-grade is 89, and 91 and up are premium octane grades. In many areas of the country, there is no 93 even available, so it could hardly be required. I haven't seen ANY reviews claiming that 93 is required... but it isn't.
Regards,
Gordon
Old Oct 29, 2004 | 10:54 AM
StewC625's Avatar
Insanely Yellow
Mine runs like a champ on 87 Octane from Shell.
Old Oct 29, 2004 | 12:30 PM
sti_eric's Avatar
Funny, I've seen many STi owners (Californians who can't get 93 octane) call 91 "monkey ****".
Old Oct 29, 2004 | 01:10 PM
sjt's Avatar
sjt
look MA! No PISTONS!!!!
cuz they don't own rotaries.
rotaries can drink nearly ANYTHING.
EJ25 wants higher octane. the higher the better.
Old Oct 29, 2004 | 01:15 PM
mysql101's Avatar
depends on your car. Mine uses 87 just fine. Other people report pinging with low grade. Fill it up and see what happens. I found about 2-3 mpg increase in mileage when using low grade.
Old Oct 29, 2004 | 01:44 PM
kantonm's Avatar
I was told by the service guy and the salesman that they "recommend" premium but that not to waste my money and to run mid grade...I also notice that I get better mileage with mid grade!
Old Oct 29, 2004 | 01:52 PM
Overport's Avatar
Overport
Rotary cars can use damn near anything, I always put Premium in my baby though...
Old Oct 29, 2004 | 04:58 PM
Johnnyma45's Avatar
I just started using 87, and gained about 1.5 mpg. Why pay extra?
Old Oct 29, 2004 | 05:48 PM
Icemastr's Avatar
The older naturally aspirated rotaries were lower compression 9:1, 9:2 and 9:7 so they could run lower octanes just fine, however the RX-8 is 10:1 so you want to run 91 and above. Turbo rotaries need to have 91 or above as well. Engines octane requirements whether it be piston or rotary is mostly affected by the compression ratio and forced induction.
Old Oct 30, 2004 | 02:00 AM
sjt's Avatar
sjt
91 octane = slower/harder to burn vs. 87 octane hence the improved mileage with 87 oct vs. 91... unless it's that Shell V-Power.
The RX-8 does NOT need 91 oct. it's merely recommended.
Old Oct 30, 2004 | 02:18 AM
GiN's Avatar
GiN
ロンリードライバー
I use Jack Daniels in my RX-8 because I can get whiskey cheaper per gallon in comparison to gasoline.
...but seriously...
When ambient temps are high, your car will perform better under high load when using premium. For example, while climbing the mountains between LA and Vegas during the summer months, the motor runs much smoother and accelerates fine uphill with premium. Using lower grade gasoline tends to cause your knock sensors to go wild and thus limit your revving.
Old Oct 31, 2004 | 03:45 PM
markd's Avatar
Lawyer in training :)
My answer to the question has to be a resouding YES. My 8 has about 5,500 miles on it and I switched between 87 and 93 octane. While using 87, my engine made some horrible noises and high-speed acceleration was compromised. There have also not been any long-term studies on the effects of lower octane fuel use on our rotaries. From my limited experience, then, I would strongly advise sticking to 91+ octane fuel.
https://www.rx8club.com/showthread.p...772#post578772
Old Oct 31, 2004 | 03:53 PM
blitzkriegs's Avatar
Nowhere in the manual does Mazda REQUIRE 91 octane. The manual only RECOMMENDS.
Old Oct 31, 2004 | 03:56 PM
Rupes's Avatar
Everyone here seems to talk about how the "quality" of the gas; IE. Shell, Mobile, ect, has a bigger effect than the octane rating. Well along those lines, is BP a good quality place to get gas? I fill up with BP gas each and every fillup.
-Rupes
Old Oct 31, 2004 | 03:57 PM
Um...the salesman has a degree in auto engineering?
Old Oct 31, 2004 | 04:13 PM
jrknu's Avatar
no, Mazda states 87 octane is o.k. and now it seems they say 10w-30 oil to boot also
things are a changing.
Old Nov 1, 2004 | 11:22 AM
-Rupes
Read along...Marketing has it's advantages...
http://www.jsonline.com/wheels/peak/feb03/119491.asp
http://www.energy.ca.gov/gasoline/gasoline_q-and-a.html
What are the various costs associated with producing gasoline?
There are four main areas associated with the costs of gasoline:
Crude oil cost
Taxes
Refinery costs and profit margin
Dealer costs and profit margin
Old Nov 1, 2004 | 11:57 AM
bean438's Avatar
The owners manual says you can use regular fuel.
However premium is recommended.
It really is that simple.
