Redline Beep..
Old Oct 28, 2004 | 10:15 PM
freakshow's Avatar
Redline Beep..
You cant hardly hear the redline beep when I tact my car out.. and some cars you can hear it very loudly... any way to turn it up????
Old Oct 28, 2004 | 11:25 PM
bryrx804's Avatar
you would have know some elec work and it could be done.
Old Oct 28, 2004 | 11:37 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
It's really quiet... I can't hear mine if my stereo is on. Instead of an audible alert, I'd love to put an LED somewhere in my line of sight that would catch my attention.
Old Oct 28, 2004 | 11:45 PM
bryrx804's Avatar
Could be done.. the beep could be changed to a light.. Simple mod with someone that knew what they were doing.
Old Oct 28, 2004 | 11:51 PM
G8rboy's Avatar
I've got the shop manual and wiring diagram manual... I suppose I should do some homework
Old Oct 29, 2004 | 12:02 AM
truemagellen's Avatar
Attracts tree branches
so what it you don't hear it, eventually you will learn when that point is by feel and sound of engine, even though it runs up the revs so smoothly
running it to the cut off point is fun anyhow youstill have 300 more RPM you can play with
Old Oct 29, 2004 | 12:16 AM
RX-GR8's Avatar
i hear it everytime.
Old Oct 29, 2004 | 01:33 AM
bryrx804's Avatar
yah, I hear it also.. I think a well designed light mod would be cool,.. have to fab it up real nice..
Old Oct 29, 2004 | 01:37 AM
StealthTL's Avatar
Metatron
I'm in.....
I'm in for a well made LED....
Any 'electro-types' willing to take my money? :p
S
Old Oct 29, 2004 | 01:47 AM
bryrx804's Avatar
I think its goin be my project tmw... as iv been out of work since last friday(SICK) and cant take one more day layin in bed....
To the garage I go..
Old Oct 29, 2004 | 12:58 PM
Frank Patrick's Avatar
not to easy to do
The beep comes from behind the dash- it is part of the PC board/instrument cluster-and responds to multi-facet commands- such as (lights on/keys in ignition, and is factory programed to red line notification. The part is located directly in the middle- if you look at the cluster from behind- look for the "speaker grill " effect- thats where the noise comes out- you will note it faces the fire walll- so it's not at all suprising that you can not really hear it with radio on/windows open. The actual noise is a low frequency eltrical pulse, responding to pre-loaded data in the control module. Having the proper wire diagrams might give rise to some potential on interception and re-directing/splinter the message, however, I would not recommend attempting to wire an LED off it, as it would need a little boost to light even the smallest of visual effect lighting.
Old Oct 29, 2004 | 01:23 PM
bryrx804's Avatar
yes.. I was thinkin of some kind of relay... that would send to off and switch on a light.. ?
OfficerFarva
Dec 5, 2015 10:53 AM
XianUnix
Sep 29, 2015 03:48 PM
