Flywheel Choices?
Old Oct 28, 2004 | 08:24 PM
juikster's Avatar
Im 8 drifting on a budget
Flywheel Choices?
Need some help on picking the right flywheel kit for my 8. What Weight choices do I have and sources to get them? Not looking for the lightest because I still want it driveable.Your expertise is greatly apprieciated.
Old Oct 29, 2004 | 08:03 AM
philodox's Avatar
Rangers Lead The Way!
I have the SR Motorsports flywheel. It weights about 12lbs'ish with the flywheel, counterweight, and bolts.. Compare that to the stock flywheel that weighs 17lbs and change.. I love it. Though, I do wish I would have gotten the Racing Beat flywheel and saved a bit of money.
I swear by Racing Beat products, go with their flywheel. You won't be disappointed at all. And it's on the cheap compared to some of their competitors.
Here's a pic of the SR Motorsports flywheel next to the stock one.
Old Oct 29, 2004 | 12:51 PM
juikster's Avatar
Thanks Philodox for the heads up by expeirence. I just like to know whats out their so I don't get something I might not like.This is a great website for the novice builder, but trial & error is what its all about.
Old Oct 29, 2004 | 02:37 PM
Jaguar_MBA's Avatar
This should help some:
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/light-weight-flywheels-points-interest-40514/
I bought the Racing Beat one.
Old Oct 29, 2004 | 06:22 PM
RoTaryStYleZ's Avatar
Racing Beat, once broken in a little bit gives u a bit more power from the 5 to 9rpm range
Old Oct 30, 2004 | 09:40 AM
mlx8's Avatar
Somewhere around here I posted a set of before (i.e. stock) and after (in this case the RacingBeat LWF) 2nd, 3rd & 4th gear torque curves. Could provide the bhp curves as well.
Found the missing "link" with the LWF torque curves:
https://www.rx8club.com/showpost.php...9&postcount=31
Old Oct 31, 2004 | 06:21 AM
rx8sportscar's Avatar
What about Mazdaspeeds fly wheel?
Old Oct 31, 2004 | 09:42 AM
tems900's Avatar
Installed the ATS & Across carbon clutch with flywheeel(4.5 kg), total weight of the assembly + mazda counter weight around 11 kg , overall drive feeling much better than the oem, but loud rattling noise from the clutch when accelerationg from 3300 rpm to 3700 rpm from third gear onward.
Old Nov 3, 2004 | 01:11 PM
MadDog's Avatar
Consiglieri
A flywheel replacement SHOULDN'T cause rattling! I'd take it back ASAP. Maybe they forgot to tighten a bolt!!
Old Nov 3, 2004 | 02:58 PM
rotarenvy's Avatar
it is a shame you have to change the clutch with this one (not sure if it's fit for the 8 ether)
http://www.gurumotorsports.com/products/flywheel.htm
with the clutch it's 16lbs.
Old Nov 3, 2004 | 09:26 PM
breezy_rx8's Avatar
Got the MS flywheel installed last week. I am extremely impressed. Drivability is not a problem at all. I was worried more engine vibration, stallling with A/C on, etc from all the ***** stories I heard. But nothing like that, the car is still as smooth as ever, A/C on full blast hasn't stalled yet.
Only now, I can actually peel out from a dead start, burning rubber like they do on HorsePower TV. I can do donoughts in a parking lot without even trying. The car is a lot more responsive. The sluggishness that I used to experience in the low RPM range has disappeared and now there's whiplash all the way through the gauge. 1st gear redline beep occurs almost too quickly. Chirping out in 3rd used to require a lot of momemtum, now it requires none. I am eager to race and beat a 350Z. I have entire confidence that I could beat a stock Z. I have not done a 0-60 on it, but I know acceleration has noticeably improved. All that talk about "yeah, rpms go up faster but also drop faster" is bunk. I can not feel a difference in deceleration increase. With all the momentum that's put into the car and being that the car is accelerating 90% of the time, I imagine any deceleration side effects are minuscule.
If any stock RX-8s would like to race to put the flywheel to the test, please lets make arrangements. Its a shame the car didn't come with the MS flywheel to begin with!
Old Nov 3, 2004 | 09:33 PM
Cam's Avatar
Cam
this space for rent
Nice review. I want the MS flywheel as well.
Feffman
SE RX-8 Forum
Oct 7, 2015 06:58 AM
GranTouTou
Sep 30, 2015 06:11 AM
Feffman
RX-8 Racing
Sep 30, 2015 05:56 AM
xAgyex
Sep 28, 2015 08:54 AM
TotalAutoPerformance
RX-8 Racing
Sep 21, 2015 08:05 PM
