Beeper warning
Old Oct 11, 2004 | 02:52 PM
Frank Patrick's Avatar
Beeper warning
How do I adjust my (what appears to be High Rev beeper warning). Mine currently goes off at 75 MPH. (Which equates to about 3100rpm (at). However, I can bring the car up to 3100 in neutral/park and no beep warning--- somehow this came out of adjustment from the factory set 9000rpm- anyone know anything about this?
Old Oct 11, 2004 | 03:29 PM
samsonite1's Avatar
uh.....
dealer
Old Oct 11, 2004 | 04:26 PM
zoom44's Avatar
AT or MT? are you talking about a quiet steady "beeeeeeeeeep" until you shift or something else?
Old Oct 11, 2004 | 04:29 PM
Just a beep--beep- I guess I have to go back to dealer for fix
Old Oct 11, 2004 | 04:31 PM
zoom44's Avatar
beep-beep is not the red line warning. that could be tpms or dsc. anything lit on your dash?
Old Oct 11, 2004 | 09:07 PM
Morgan's Avatar
Lounge Sweetheart
sounds weird to me....must be an AT?? i'd vote to take it to the dealer.
Old Oct 14, 2004 | 08:41 PM
snap-on's Avatar
BEEPING FROM INSTRUMENT CLUSTER AT ABOVE 75 MPH
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
A beeping sound may be heard from the instrument cluster at N above 75 MPH. The concern most likely occured after the instrument cluster was replaced. If the instrument cluster was replaced N not programmed (configured) by performing the WDS PMI procedure then the speed warning alarm will sound. This feature is used in other countries N willoperate when a ICM has been replaced N not configured for the US specification. If a new ICM was installed N not programmed (configured) by performing PMI, then follow the directions below. 1. Install vehicle's original ICM in vehicle. 2. Using WDS, select "MODULE REPROGRAMMING". 3. Select "PROGRAMMABLE MODULE INSTALLATION". 4. Follow on-screen menu prompts to inhale AS-BUILT DATA from old ICM. 5. Install new ICM when prompted N exhale AS-BUILT DATA into new ICM. 6. Verify repair. IMPORTANT! In some cases the AS-BUILT DATA cannot be retreived from the vehicle's original ICM. If this occurs you need to contact the National Technical Assistance Hotline for AS-BUILT DATA N procedure for configuring new ICM
Old Oct 15, 2004 | 10:05 PM
irish8's Avatar
Get in ma belly!!
dealer
- Irish
Old Oct 15, 2004 | 10:08 PM
snap-on's Avatar
dealer
Old Oct 19, 2004 | 12:14 PM
Wds
WDS- dealer only
Old Oct 19, 2004 | 06:44 PM
DOMINION's Avatar
I don't buy Kool-Aid
From what I know you cant adjust it?
SUKIEE
Oct 9, 2017 09:41 PM
drlubell
Sep 26, 2015 11:58 PM
Rx8_412
Sep 24, 2015 08:51 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
