View Full Version : Best way to clean pop off a keyboard.
BlueEyes 10-08-2004, 11:35 AM I got sprite on my keyboard. I wiped it off, but I know there is lots inbetween the buttons, what is the best way to get rid of it all. I don't want my keys sticking tomorrow. :mad:
Thanks MadRonin!
Tayninh 10-08-2004, 11:40 AM You will need a spray can cleaner specific for keyboards like from OfficeMax. Perhaps a damp papertowel will do to get the pop off or diluted in the meantime.
Genom 10-08-2004, 11:52 AM Your gonna have suger under the keys now. The only way to get rid of it is to take apart the keyboard and wash it. Frankly, I'd just go buy a new cheap KB and be done with it. Your gonna spend under 20 bucks and not have to mess with it for a couple hours.
abbid 10-08-2004, 11:53 AM thats not the best way.
Take the keyboard apart, pull all the buttons off, and soak em in warm water with a few drops of bleach. Dry em, and replace. Voila, good as new.
Or you can just take it into the shower, wash the keyboard and dry it out and youll be fine.
MadRonin 10-08-2004, 11:58 AM Sorry about that BlueEyes. If it makes you feel any better, I have a couple of keyboards with AT connectors laying around here that I can send you. :D
Morgan 10-08-2004, 12:03 PM i got really confused when you called it pop! i was like...wtf is that...then i realized you people dont call it soda...weirdo's...:D i did that to mine like 3 years ago...fried the hell out of it...just buy a new one :)
Razpewton 10-08-2004, 12:05 PM I've had this problem before. Using rubber gloves, gently lift the largest masses off and place in the toilet. Then, using a hairdryer, dry the remaining..............wait.............that's poop, not pop............nevermind. :D :D
Tayninh 10-08-2004, 12:25 PM Yeah I used the word "soda" too. Raised on the East Coast. Then visited West Virgina and asked for a soda and they pointed me to the baking soda on the shelf. Dumb Duh!!!!!!!!!
Its pop or soda depending where you live I guess
MadRonin 10-08-2004, 12:33 PM Yeah I used the word "soda" too. Raised on the East Coast. Then visited West Virgina and asked for a soda and they pointed me to the baking soda on the shelf. Dumb Duh!!!!!!!!!
Most of PA says "soda" including Philly. However Pittsburg and the surrounding area says "pop." Go figure.
Morgan 10-08-2004, 12:38 PM yea...soda, supper, the way those northerns say "a" it sounds like an "e" ummm...there are a bunch of differences..and you guys don't say ya'll...there is something seriously wrong with that..lol.
Tayninh 10-08-2004, 12:42 PM From Baltimore but live in Colorado. Ppl ask me where I am from cause they know I am not from around here and they can't figure. Ppl in Boston talk ah different while those from the South yet more different and then they use Soda and Pop too. LOL
MadRonin 10-08-2004, 12:43 PM ^^^(Morgan) No we say yous as in "How yous guys doin'?"
Supper in PA Dutch country is actually lunch...;)
Also most people don't say 'water', they pronounce it 'wooter'.
Feras 10-08-2004, 12:47 PM ^^^(Morgan) No we say yous as in "How yous guys doin'?"
philly truly rules
MadRonin 10-08-2004, 01:00 PM philly truly rules
It has its moments. :)
guy321 10-08-2004, 01:00 PM I popped on my keyboard, it wouldn't come out.
rotten42 10-08-2004, 01:02 PM I've ssen that happen before...the best solution is to get a new one. Keyboards are cheap anyway.
Tayninh 10-08-2004, 01:03 PM switch yours with someone elses.
Ok..
Let me say i have the best technique for keyboard cleaning:
1, take the circuit board out of the keyboard (plastic or whatnot, but do it carefully)
2, put the plastic button part in the dishwasher and set it to rinse and dry and run it (no soap)
3, clean the contact pads on the keyboard with a non amonia based cleanser like rubbing alcohol
4, dry everything and reassemble
Labop 10-08-2004, 01:15 PM Another way to do this, assuming you have a day or so of dry time..., after disconnecting it from the computer (crucial step), run it through the shower. I'm not kidding, it works. I had a buddy in IT at my last command. If someone had a problem with somethinng spilled in the keyboard, they would swap it with a new one, then put the old one in a shower. Actually tried it myself once (had a spare in case it didn't work).
You just have to make sure you get all the water out..., otherwise it's fried. I actually blow dried mine so no water would be on the circuts for an extended period of time. Good luck.
MadRonin 10-08-2004, 01:20 PM If you do decide to clean your keyboard, DO NOT use bleach. It will corrode the contacts leaving you with nothing more than a big plastic poundy thing. :p
I've found that the best way to clean a keyboard is to either use a pressure washer (make sure you get REAL close to the keys) or try hydrofluoric acid. I guarantee if you try the above methods you will have no more keyboard...
....problems. :D
EyeBall Fixer...(o)(x) 10-08-2004, 01:28 PM I got sprite on my keyboard. I wiped it off, but I know there is lots inbetween the buttons, what is the best way to get rid of it all. I don't want my keys sticking tomorrow. :mad:
Thanks MadRonin!
Hope your keyboard wasn't on your laptop....
I spilled coffee on my laptop and it was never quite the same...
Perhaps I'll put it in the dishwasher with bleach... :rolleyes:
MadRonin 10-08-2004, 01:35 PM Hope your keyboard wasn't on your laptop....
What kind of laptop? I just replaced a Dell laptop keyboard that someone spilled soda on. I bought the replacement off of ebay for $20. Five screws later it was good as new.
EyeBall Fixer...(o)(x) 10-08-2004, 01:38 PM i got really confused when you called it pop! i was like...wtf is that...then i realized you people dont call it soda...weirdo's...:D i did that to mine like 3 years ago...fried the hell out of it...just buy a new one :)
I up in grew up in Massachusetts calling it soda....
My Texan step-sister called everything "Coke"....
She'd say:
Q: "want a coke...?"
A: "sure..!"
Q: "what kind?"
S: "we have orange and Pepsi...."
Go figure!
EyeBall Fixer...(o)(x) 10-08-2004, 01:43 PM What kind of laptop? I just replaced a Dell laptop keyboard that someone spilled soda on. I bought the replacement off of ebay for $20. Five screws later it was good as new.
Thanks for the info MR! ....or shall I call you "Betty" .... :D
(I see we both are Kung~Pow fans)
Sony TR3a...
It leaked through to the motherboard or HD...
Wouldn't boot up, I replaced it with a TR5...
Thanks again!
BlueEyes 10-08-2004, 02:15 PM you guys are hilarious, tahnks for all the help though.
I am super lazy so I went and bought a wireless keyboard and mouse!
Thanks MadRonin! :D
EyeBall Fixer...(o)(x) 10-08-2004, 02:28 PM you guys are hilarious, tahnks for all the help though.
Thanks MadRonin! :D
Good choice...
Wireless is great...
Did you get the wireless mouse too?
Tayninh 10-08-2004, 02:36 PM RX MD - that a dr or are you from good old Maryland?
Is that Sprite on your keyboard or are you just happy to.... oh, nevermind!
Seeing as how this has already been hijacked into the "pop" vs. "soda" thread... :)
