What's the best CAN Scan tool?
Old Oct 7, 2004 | 11:19 AM
TORacing's Avatar
I know losts of people use CAN Scan tools on here, so what is the best CAN Scan tool that I can get to log and store what the ECU is doing, codes it's sending out, and at the same time other diagnoastics like airflow, air temp, speed, rpm, CAT temp, oil pressure, brake pressure, etc.? If there's not one that can do this what are the best two, one that reads code and one that reads Diagnostics?
Old Oct 7, 2004 | 12:13 PM
epitrochoid's Avatar
Riot Controller
the canzoomer or dan harrison canscan. theyre the same thing
Old Oct 7, 2004 | 12:14 PM
mysql101's Avatar
canzoomer is a repackaged harrison canscan from what i understand. anyone know for sure?
Old Oct 7, 2004 | 12:45 PM
RX8-TX's Avatar
Senior Geek
Check this one as well...
www.autoenginuity.com
Is it on the expensive side of things...but, well, I'll never know. I got the Dan Harrison package.
Once thing I know, the AE software has a much better looking interface :D
Old Oct 7, 2004 | 01:12 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Correct. I bought one of the first CanSCANs from DHarrison... it's great. I plan on building a carputer interface in .NET with it eventually...
Old Oct 7, 2004 | 03:06 PM
devoid's Avatar
My doctor prescribed RX-8
canzoomer is an updated version of the harrison R&D CanScan. New chip and software. I originally bought the Harrison R&D canscan, but than purchased the upgrade chip and sofware from CanZoomer. Just go straight CanZoomer.
Old Oct 7, 2004 | 03:18 PM
G8rboy's Avatar
Interesting... what benefits does his upgraded chip add?
Old Oct 7, 2004 | 03:24 PM
mysql101's Avatar
according to harrison, all the units run at 115k.
Old Oct 7, 2004 | 09:37 PM
DaveT's Avatar
I have the AutoEnginuity unit and am totally pleased with their system. No fooling around trying to figure out what your looking at. System is auto-ranging and everything in realtime with broader and more readable scaling than what I have seen elsewhere.
Old Oct 9, 2004 | 12:31 AM
TORacing's Avatar
I have two questions does the Canzoomer one actually log and record OBDs and ECU codes? And does the AutoEnqinuity, which looks very nice, actually allow you to tune the ECU?
Old Oct 9, 2004 | 07:43 AM
mysql101's Avatar
What do you mean by tune the ECU?
Old Oct 9, 2004 | 03:23 PM
Riot Controller
neither allow you to tune the PCM(ecu), theyre just can bus readers. you'll need a fuel and ignition controller to tune
Old Oct 9, 2004 | 04:00 PM
TORacing's Avatar
so I can't do things like tweak air flow, and another questions does it log all ECU codes, I thought that tweaking things like air flow is exactly what the Canzoomer device did and with the proper equipment you could do your own tweaking. It also says on the autoenginuity site you can tune the ECU.
Old Oct 9, 2004 | 06:29 PM
Gomez's Avatar
Shifty Bastard.
If you'd ever bought any of Hymee's stuff....you'd realise it's worth waiting for. Hymee's CanScan is coming, do a search, there are threads on it.
Regards, Gomez.
Old Oct 9, 2004 | 09:32 PM
TORacing's Avatar
well, I didn't know he was releasing one. I thaught that in the write up polak did on the canzoomer device he said he tuned his? But if niether of these can "tune" the what device would you recommend to use to "tune" the ECU, and does it have it's own OBD scan or should I also purchase on of these OBD scan tools? Will Hymees be able to do the tuning I have spoken of or is it just another reader?
Old Oct 9, 2004 | 09:34 PM
mysql101's Avatar
Read here: http://tyrannical.org/page-15
Old Oct 9, 2004 | 09:56 PM
TORacing's Avatar
so if I read this correctly with the CZ unit, canscan, and a usb connector form CZ I can read, log, and edit my maps? And by maps they mean fuel/air maps, if so this is what I meant by tuning and tweaking?
Old Oct 10, 2004 | 04:36 AM
Gomez's Avatar
Shifty Bastard.
Okaaaaaay, I'll do the search for you....
Here is the thread. Read Hymee's posts about what he plans for his CanScan tool.
Go"Golden Retriever"mez. .
Old Oct 10, 2004 | 09:34 AM
crossbow's Avatar
http://www.autoxray.com
It can't do nearly as much stuff as the autoengutity (or however you spell it), but its a self contained unit, and great for diagnosis. Can also interface with the pc to pull graphs and FFD's.
(That FFD is the infamous Mazda 6 Injen CEL)
Old Oct 10, 2004 | 05:17 PM
TORacing's Avatar
is there any device that can hack an ecu, because I think it's with holding lots of hp potential
Old Oct 10, 2004 | 05:19 PM
mysql101's Avatar
Horse, read my previous post to the last time you asked that.
Old Oct 10, 2004 | 10:31 PM
TORacing's Avatar
i read the page an the info was very helpful, but I'm trying to find a way to remove things like lag or limp mde and restrictors. This equipment soundsvry promising but before I spen the $ I want to see if I can find what I'm looking for.
Old Oct 10, 2004 | 11:01 PM
takahashi's Avatar
How much does Hymee give you for advertising?
I am waiting for this as well
Old Oct 11, 2004 | 12:04 AM
Gomez's Avatar
Shifty Bastard.
I am not worthy....at the moment Hymee allows me to type his name and buy his stuff, that's enough for me .
Gomez.
Old Oct 11, 2004 | 07:44 AM
mysql101's Avatar
The cz unit tricks the car into thinking less air is coming in, thus leans the fuel. It's no where close to being able to do what you're asking. In fact, I don't think there is anything out that can do that. The computer in the RX-8 is encrypted, and it performs a lot of actions in the car. We're still struggling with leaning the car properly, and being able to do turbos without blowing up the engine.
