Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Oklahoma Law on clear corners
Old Oct 6, 2004 | 06:35 PM
w0rm's Avatar
PUSHER ROBOT
Just an FYI, i had a hell of a time finding this online.
On side blinker/illumination:
A. Every vehicle shall be equipped with turn signal lamps that flash for the purpose of indicating the intention to turn either to the left or to the right.
B. The flashing turn signal lamps required by this section:
1. Shall show to the front and rear of the vehicle;
2. On the front of the vehicle, shall be located on the same level, as widely spaced laterally as practicable, at a height of not more than seventy-two (72) inches nor less than fifteen (15) inches, and when in use shall display a white or amber light, or any shade of color between white and amber, visible from a distance of not less than five hundred (500) feet to the front in normal sunlight; and
Old Oct 7, 2004 | 11:49 AM
OKC RX-8's Avatar
hmmph, I always thought they had to be amber. I might just have to change that. THanks for the info Worm. I look forward to hanging out with everyone at the next meet-
Old Oct 7, 2004 | 12:03 PM
MELRX8's Avatar
"RX-8 my stress reliever"
Sounds to me as this refers to turn signals and not side lights. Federal law reads:
"Depending upon the year, 1968 and newer cars are required to have a side
marker light and amber reflex side reflector. If you are replacing a stock or original equipment manufacturers lens with an after-market product, make sure the after-market product meets the standard and has the side reflex reflector that the original did, if it had one"
Since Mazda has elected to combine the side light and amber reflector in one unit clear corners would be out. The question would be if Oklahoma has adopted the federal law.
Old Oct 7, 2004 | 01:22 PM
Jump120MPH's Avatar
Soccer Fan
I have had my clear corners in for a year with hyper white lights in them. I have been stopped 5 or 6 times and they never said anything about my lights. I even have some blueish-aqua color in the front lights.
Old Oct 7, 2004 | 05:28 PM
w0rm's Avatar
PUSHER ROBOT
as far as im aware, vehicle illumination and markers are a state controlled issue. That was pulled from state legislature.
I'm just waiting on my clears to ship in
Old Oct 8, 2004 | 03:42 PM
Jump120MPH's Avatar
Soccer Fan
Heres what you car would look like with the MS body kit and it has clear corners.
Attached Thumbnails Oklahoma Law on clear corners-dscn1170.jpg   Oklahoma Law on clear corners-image002.jpg   Oklahoma Law on clear corners-image044.jpg
Old Oct 8, 2004 | 05:18 PM
w0rm's Avatar
PUSHER ROBOT
so nice....
so expensive.
Old Jan 12, 2012 | 04:33 AM
Thoroughscrub's Avatar
Rollin' 7s
Originally Posted by w0rm
so nice....
so expensive.
My marker lights were 38 a piece, not too bad, but for tiny little lenses I understand.
Unless you're referring to the Mazdaspeed body kit, in which case... Yes... so freaking expensive for a body kit.
Old Jan 12, 2012 | 09:07 AM
Creto's Avatar
It's good to be the king.
Holy thread resurrection batman!
7.5 years!
Old Jan 13, 2012 | 05:09 AM
Rollin' 7s
I'm on a roll, My other post was on one from 05.
Old Jan 13, 2012 | 09:02 AM
Highspeed's Avatar
2 Tone...Low Drone
Oldie...but a goodie Glad it was revised, I had no idea
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
duworm
Oct 1, 2015 04:57 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
