It finally happened.
Old Oct 5, 2004 | 12:23 PM
guy321's Avatar
Humpin legs and takin nam
My 8 flooded. I have the M flash.
Had it towed to the dealership after repeated attempts to start it. They have it working, but say that I need an oil change because the repeated startings seem to have put gas in the oil?? Can that be true?
Old Oct 5, 2004 | 12:25 PM
Icemastr's Avatar
Not saying it isn't possible but I don't think it is and I have never heard of it happenng.
Old Oct 5, 2004 | 12:28 PM
Meowloud's Avatar
Short Bus Allstar!
I've read some posts where peeps have been complaining of the gas smell when checking their oil.
I'm sure you're also going to get posts requesting what you did (start it then shut it off immediately), so you might as well give some details :o
Old Oct 5, 2004 | 12:31 PM
guy321's Avatar
I started it while it was cold and changed my mind about going, so I immediately shut it off. Tried to start it a few hours later and it was a no go. I got on the radio and said "Houston, We have a problem" and someone yelled through my window "shuddup A-hole"! Then the aliens came..
Meowloud's Avatar
Short Bus Allstar!
But why 2 threads?? :p
One for each personality??
Old Oct 5, 2004 | 12:32 PM
guy321's Avatar
I thought i deleted one.
Old Oct 5, 2004 | 12:33 PM
guy321's Avatar
I live in FL. It was 87 out.. I used to think like you... YOU MUST RESPECT THE ROTARY!
Meow, there were 3 threads.. I habitually posted in the lounge first.. then Im like "im screwing myself on post count!"
Old Oct 5, 2004 | 03:26 PM
quack_p's Avatar
Giant Space Hamster
How did it happen? Moved the car a short distance and shut down? Stalled?
Old Oct 5, 2004 | 04:49 PM
RUmble's Avatar
No he started it cold first then changed his mind, then a few hours later it was war of the worlds in his driveway and he probably got abducted and the aliens flooded the engine.
Old Oct 5, 2004 | 04:54 PM
StewC625's Avatar
Insanely Yellow
Very common after a bad flooding to get gasoline in the crankcase - rotary or piston. The extra fuel washes down the cylindar (or rotor housing) walls, leaks past the oil seals, which are designed to hold back oil but not low-viscosity gasoline. Repeated attempts to start it without having the car in "flood clear" mode just make it worse.
FYI, if you do flood:
1) Let the car sit for 10-15 minutes
2) Get in the car, put the pedal all the way to the floor and hold it. This shuts off the fuel injectors and allows the engine to spin without more fuel spraying into it.
3) Crank the engine for 10 seconds (sing happy birthday to yourself - takes about 10 seconds). If engine doesn't start, key off, wait one minute
4) Repeat step 3. If the engine is starting to catch as you're coming up to 10 seconds, don't back off the starter!!!! Keep cranking, though I wouldn't exceed 20 seconds of total crank time.
I flooded mine once before I got the M Flash, and got it started on the third try in flood clear mode.
Old Oct 5, 2004 | 05:05 PM
zoom44's Avatar
exactly what he said- he was just repeating what guy said a few posts before- go back and read thru the thread again.
Old Oct 5, 2004 | 05:07 PM
93rdcurrent's Avatar
The Stickinator
Didn't I create a poll for post M flash floods after mine did it on Sunday night? I got my car back now and I have the hotter plugs (Foothills told me they were already in my car back in April... ). They got my car back today and it feels peppier but that could be due to the crappy old mitsu mirage they had me driving. Cars back now and it's driving good. Seems to start up faster though for the most part I didn't know there was a lag before.
Sorry to here about your car Guy.
Old Oct 5, 2004 | 05:10 PM
guy321's Avatar
Im not even sure they replaced my plugs :o My invoice just says deflooded and reflashed PCM.. I asked about this because I already had M flash.. they said it was because of the low battery.. Hmm anyway it runs just as well as before :D
Old Oct 5, 2004 | 05:14 PM
Red Devil's Avatar
I've been fairly paranoid about flooding. My FC used to flood even when it was fully warmed up. I used to have nightmares that it would be flooded one night while I was in the wrong part of town, and you can fill in the rest.
So with the 8, I have yet to turn it off cold, but as soon as it hits the running temp, then I'll do it.
Old Oct 5, 2004 | 05:16 PM
guy321's Avatar
I tried this.. DIdnt work for me.. the engine lost all compression.. I could hear the difference.
Old Oct 5, 2004 | 05:19 PM
The Stickinator
I tried it too. Didn't work for me either. And I pulled my car out of the driveway so we could pick some friends up at the airport in my wifes' car. I let it warm up to about 1/4 on the temp guage and revved it for 10 seconds at 3.5k rpms. Then I shut it down. It was about 6 or 7 hours later that I tried to start the car again.
Old Oct 5, 2004 | 05:29 PM
Red Devil's Avatar
You guys tried it, but did you sing "Happy Birthday" that really is the key. :p Just joking, I thought that was an off-the-wall example.
Anyway, that is pretty similar to my procedure with the FC. One time it took me more than half the day to get the damn thing started, but I was stubborn and refused the get it towed. The answer with that car was to have a fuel pump cut switch installed. Then whenever it flooded no more fuel would be added until the engine fired up and I flicked the switch. But with the M Flash, it was my understanding that this stopped extra fuel from going into the combustion chamber all together?
Old Oct 5, 2004 | 05:36 PM
Overport's Avatar
Overport
i am so scared of flooding my 8...to death! i hope it never happens and i feel bad for ya dude. i do everything possible to prevent flooding.
Old Oct 5, 2004 | 05:37 PM
guy321's Avatar
I tried pulling the fuel pump fuse. M flash definitely helps because i've moved it short distances before without flooding
Old Oct 5, 2004 | 05:42 PM
The Stickinator
You said flick the switch... hehehehehe :D
Old Oct 6, 2004 | 07:15 AM
Red Devil's Avatar
If only it were a **** instead of a switch, then I could have rotated and polished it.
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
Racingjunkie
Sep 29, 2015 05:05 PM
pjwermuth
Sep 28, 2015 11:36 PM
yapakanichi
Sep 25, 2015 07:55 PM
