downshifting into second -> shudder?
Old Sep 28, 2004 | 01:06 PM
silver1.3's Avatar
I only have 481 miles on the car, but I did notice this on the loaner they gave me to test drive and on this car. I hope this is norma:
If im at say 4000 rmp in third or fourth gear (may happen in 5th - havn't tried it yet) and I downshift to second, not lighting fast, but quick - I get this shudder right before it goes into 2nd. Feels like the tranny is shaking on its mounts. NO metal sound or noise just a shudder. Can someone explain for me.
I havn't been abusing the car at all, so I don't think this is my doing.
greg
Old Sep 28, 2004 | 01:10 PM
guy321's Avatar
Humpin legs and takin nam
4000 in 4th downshifting to 2nd will put you at approximately 6k rpms in second.. are you rev matching?
Old Sep 28, 2004 | 01:16 PM
silver1.3's Avatar
Well, maybe im wrong about the RPM on the new car - As I recall I was in 4th, let off the gas costed a bit (so I lost 1000 rpm maybe) then sliped it into 2nd - then shudder. It happened in third the same way, so I wasn't going fast at all, should have been 500 rpm (guessing) drop once it went into 2nd.
I didn't rev match. I do somtimes but not all. Mostly when I really on an engine I'll do that, but if Im lazy around town then not all the time. I don't force the gear either, just a slight flick of the wrist. I noticed that if I let the car slow down real slow before downshifting it wont shudder. And it never shudders upshifting.
Old Sep 28, 2004 | 01:19 PM
guy321's Avatar
When downshifting, especially 2 gears, you need to rev match... You can get away with a 1 gear upshift if you allow enough time for the syncros to catch up.. you should hear a spooling up kind of noise.. It's not good for your synchros..
try rev matching :D
Old Sep 28, 2004 | 01:24 PM
zoom44's Avatar
triple cone synchros in 1st 2nd and 3rd. probably feeling the syncros doing their job.
Old Sep 28, 2004 | 03:16 PM
SpinninAgain!'s Avatar
Not too good for the clutch either.
Match revs, that's why God gave you a heel! :D
Old Sep 29, 2004 | 03:29 AM
hotpot's Avatar
Rev matching would only be useful if you're downshifting to accelerate, rather than decelerate. In your case it seems that you're downshifting slowing down, maybe to go round a corner. I also find that the car is very jerky in 2nd at very low rev. You need to play with the clutch and gas to stop the jerking. I also find that the clutch on the 8 is not as forgiving as on other Japanese cars. The sweet spot on the clutch seems very small and needs precise clutch release. It has taken me more time to get used to the 8's clutch sweet spot than any other car I have driven.
Old Sep 29, 2004 | 03:37 AM
shaolin's Avatar
You definitely need to learn to revmatch, and it sounds like you're downshifting into 2nd where it would be at a high RPM, meaning that the synchros are definitely working hard to match engine and tranny speeds. It also sounds to me like you're popping the clutch. Learn to rev-match, and use the clutch with finnesse and you shouldn't have a prob.
Old Sep 29, 2004 | 08:50 AM
silver1.3's Avatar
I don't think it has anything to do with "poping the clutch". The shudder happens when the clutch is depressed and the I move from 3rd to 2nd. As I shift down, right before the shifter "snicks" into gear is when I get the shudder. I never "pop" the clutch, rather I ease it out to get a smooth transition.
I did try double clutching, and this seems to work, but I will need to try it more to confirm.
greg
Old Sep 29, 2004 | 08:54 AM
guy321's Avatar
I always double clutch.. I can't do it any other way .. but you don't NEED to.. you just need to match the rpm's.. you should be able to do this with the clutch engaged.
What part of Louisiana are you from? I was born and raised in the New Orleans area.
greg
Old Sep 29, 2004 | 09:04 AM
silver1.3's Avatar
Lafayette, Its cool b/c its a realitively small town and there arn't many 8's - I get a ton of looks. The other day me and my wife went to Sams, I was walking away from my car and an elderly fellow, his wife and what looked like his grandaughter (15 year old or so) stoped me and he asked if they could check out my car, they all - and I quote - "fell in love with it when they saw it". That was cool, never had anybody say THAT about a car I've owned. :D
Old Sep 29, 2004 | 09:09 AM
guy321's Avatar
Why would you need to downshift to slow down? That's what brakes are for :p
I typically downshift so that I can maintain my powerband..
Old Sep 29, 2004 | 09:10 AM
guy321's Avatar
Nice, Good food out there, I miss it!!
A buddy of mine is from Delcambre parish out that way.
MANIACman
Nov 11, 2015 10:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
teamdipngo
Sep 14, 2015 02:47 PM
Solmors
Aug 21, 2015 10:11 PM
