View Full Version : How Can I remove rear seat?
Thommino
09-17-2004, 07:31 AM
I want installa my switch in this way:
http://www.thommino.com/images/Mazda%20Rx-8/Accessori%20e%20Dettagli/NavTV.jpg
How can I remove rear seat?
WHealy
09-17-2004, 08:27 AM
I found this text from this previous post. (http://www.rx8club.com/showthread.php?t=17480&highlight=rear) Hope it helps.
Removing the rear seats is very simple. But having room to put them back in after you would put this on the seat side of the cross bar ... I don't know that there is enough room. Are you sure that whoever did this previously didni't remove their rear seats?
Genom,
Thanks for the help. Foudn that you pull the rear seat bottom right up from the two fasteners with little effort. This then exposes two bolts holding the rear seat back. Loosen these and then the seat back can be raised off to more clips near the top. Then it can be lifted out.
Of course then you can remove this trim piece.
Thanks so much.
Thommino
09-17-2004, 08:51 AM
I take the picture from your forum about 4-5 mouths ago?
I hope to be able to put my rear seat on again.
