CD stuck in CD player
Old Sep 16, 2004 | 10:12 AM
Gyro's Avatar
Rotary Abuser
Angry CD stuck in CD player
OK.......so I put a CD in (audio CD) in my stock MP3/CD player and it goes into an infinite "Reading disc" mode. It won't eject. Absolutely nothing happens when you press any function. The radio works fine, but when you press "CD" it flashes "reading disc" forever.
Before I pull it out and throw it in the river (yes I know it is under warranty....but I have anger problems )...is there any button sequence to reset it? I will try to disconnect the battery for a minute or two as a last resort.
any ideas?
Old Sep 16, 2004 | 10:36 AM
Speed Racer's Avatar
Certified track junky!!!
Gyro,
This happened to Tigger a few months ago. You may want to send him a PM and ask how he removed the CD.
Old Sep 16, 2004 | 10:42 AM
Gyro's Avatar
Rotary Abuser
thanks roy....
Its all fixed now.........the removal of the battery terminal for a few minutes did the trick.......wierd though huh?
Old Sep 16, 2004 | 10:45 AM
Gyro's Avatar
Rotary Abuser
Originally Posted by Gyro
thanks roy....
----probably should have tried this BEFORE I started a thread about it......
oh well, I'll leave this thread here in case someone needs to search for the same problem.
Old Sep 16, 2004 | 02:48 PM
huhsler's Avatar
When you disconnected the battery terminals, the CD ejected immediately and silently, didn't it?
That's how it works on mine. It was spooky the first time...caught me off guard.
Old Mar 13, 2008 | 05:12 PM
afzaldasu's Avatar
how do u disconect d battery
Old Mar 13, 2008 | 11:27 PM
Gyro's Avatar
Rotary Abuser
loosen the negative battery terminal and remove it for about ten seconds. Hope it works for you.
Old Mar 14, 2008 | 02:38 AM
afzaldasu's Avatar
defo negativ? cos sme ppl sayin positive
Old Mar 14, 2008 | 10:04 AM
Gyro's Avatar
Rotary Abuser
You can do either really. I have always pulled the neg when I needed to reset something.... habit I guess. If you pull the positive cable, just hold it away from anything metal for about ten seconds.
Old Jul 3, 2008 | 02:38 PM
Astral's Avatar
Purveyor of fine bass
I had this happen to me twice. The first time I pulled a battery cable (pulling negative recommended, cause it's safer if you drop it).
However, second time, I was in an area where I didn't have a 10mil socket handy. Instead, we figured out that we could pull the ROOM fuse (I think it's the bottom fuse in the interior fuse block on the driver side). The fuse puller is inside the fuse block in the engine compartment. Pulled the fuse, waited a bit, turned the car to ACC to make sure the radio was really dead, put the fuse back in and, BAM, CD player reset.
So recommended method now: pull the ROOM fuse, less hassle than undoing a battery terminal, plus you can do it anywhere your car is.
Old Jul 5, 2008 | 06:38 PM
amstarvid's Avatar
ZM ZM X 8
FYI. Mazda will replace this under warranty if you ever can't get it out at all - this happened to me with my protoge 5 before I had my 8, and they just switched it out with a new one.
vapor2
Jul 9, 2016 07:35 AM
TeslaMSI
Dec 10, 2015 01:10 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
iphil
Sep 21, 2015 10:49 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
