veilsidev1
09-14-2004, 05:45 PM
what up guys, I am helping my friend find a used 8. We found this car that seems like this is the one, bu we do not know if is is m-flashe and he doesen't either. How can we check if it is, with the vin# ?. And if it isin't who can we take it to get it m-flashed, how much does it cost?. And finally, i see you guys say that to prevent flooding warm up the car before shutting it off, how much is a while in warm and cold temps?. Thanks for all your help guys.
robertdot
09-14-2004, 06:30 PM
There are ways to tell if it is a later version, but the best way to do it is to take it to a Mazda dealership and ask. I'm not sure what they do about warranty on a used car, or if the ECU is an unconditional warranty. At worst, complain about flooding or rough idle, and they should upgrade the ECU because of a recall.
If you have the newest flash, this shouldn't be an issue. However, the smartass answer is "the correct length of time to let a car warm up in warmer or colder temp to prevent flooding is long enough that it prevents flooding." I've NEVER had my car flood, so I have no real answer. But I couldn't resist that.
A search might give you an answer. The owners manual will tell you want to do if you flood it.
Herkypilot
09-14-2004, 08:24 PM
You should not have any problems with the warranty. Take it in and ask. If it doesn't have M - they will (or should) do the flash - warranty or not - its a TSB that Mazda put out for ALL RX-8s.
basisguy
09-14-2004, 09:12 PM
Check this out......particulary page 2
http://www.finishlineperformance.com/rx8/docs/01-022-04.html
If the cars VIN falls within a certain range and it has the M flash, it should have an "Authorized Modification Label" placed on the inside of the hood.
