tire pressure light
Old Sep 14, 2004 | 08:39 AM
jayrob33's Avatar
tire pressure light
hello all
i have noticed that my tire pressure light has come on recently.
i placed sufficient air in my tires but it still seems to come on from time to time
has anyone else had this problem?
it might be some kind of malfunction that it comes on from time to time, but just wanted to check with everyone else
let me know
thx
Old Sep 14, 2004 | 08:51 AM
ryousuke's Avatar
same thing hapened to me a few weeks ago, ust take it to the dealer and they'll fix it.
Old Sep 14, 2004 | 09:01 AM
Mugatu's Avatar
Even My Dog Searches
My light comes exactly 10 minutes after I start the car, every time. I have the stock tires with proper inflation. The light is flashing, not steady, which I believe means there is something wrong with the sensor.
I have been to the dealer twice and they have not fixed it. I am giving it one more try before I call Mazda NA about it.
Old Sep 14, 2004 | 09:18 AM
WHealy's Avatar
Mr. Blue Man
Mugatu,
That's the same thing that happens when I chnage to snow tires. The computer needs to know the sensors have been changed. You might check this thread and look at the "Wheel Swap" section to see if this address your issue.
Old Sep 14, 2004 | 09:36 AM
Mugatu's Avatar
Originally Posted by WHealy
Mugatu,
Whealy, thanks. I'll print that out and bring it with me. The last two times I brought it I specifically told the dealer that the light comes on 10 minutes after start up, and both times I got it back with a response that they saw no light come on. now I KNOW they are bullshitting me since it happens every time I start the car up...I just know they probably turned the car on and saw no light, so their job was done.
Hopefully your highlighted thread does the trick.
Old Sep 14, 2004 | 09:41 AM
Atacdad's Avatar
Mine was coming on in the mornings..or any time it was < 74 deg. F. Typical seasonal change. I went all around one morning and checked for 32psi...had to put air in all of them. The lowest was 25
Old Sep 14, 2004 | 09:57 AM
Mugatu's Avatar
mine is definitely not pressure related. Besides the fact the both I and the dealer checked for proper inflation, the light is flashing, not steady. I believe that when pressure is off in either direction, the light will come on steady. The flashing light indicates a problem with the sensor itself.
Old Sep 14, 2004 | 10:10 AM
away_27's Avatar
away_27
I noticed mine was on the second day I had it. Checked all pressures and they were off by 3-5 psi per tire. I have a feeling that this Tire Pressure Monitor keeps you on your toes but it seemed to work ok for me.
Old Sep 14, 2004 | 02:47 PM
JimJimElf's Avatar
I had the light flashing after my 7500 maintenaince. It would flash for the first 10 minutes or so then stop. A few days later my car wouldn't start. I checked the battery cables first and it had come off. Put the negative cable back on and tightened it (since the dealership didn't do it). After that the car started light was flashing again then went away after 10 minutes or so. So then I turned it off. On the next start up did the same thing. This time I drove it for about and hour or so. On the next start up and still today, no flashing light.
Old Sep 14, 2004 | 04:14 PM
WHealy's Avatar
Mr. Blue Man
JJE,
Check the link to the TSB I posted above. It would seem that you stumbled on the same solution they have. The idea is you have to tell the system to re-register the sensors.
Old Sep 14, 2004 | 09:34 PM
r8ped8's Avatar
mine goes on steady at about 45 degrees ambient in the morning until I get on freeway then immediately turns off?
Old Sep 15, 2004 | 12:00 AM
I have a bad one. Can't get Mazda to replace it.
Sensor works but leaks air consistently.
Old Sep 15, 2004 | 04:47 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yea my light come on too and a beeping will sound when it lights up?
Old Sep 15, 2004 | 05:45 AM
rx8cited's Avatar
Senior Member
It sounds like your tires are not set to 32 PSI cold. Try checking them first thing in the morning before you start driving while the tires are still cold.
The light turns off because as you drive, the tire pressure goes up several PSI as the tires warm up.
rx8cited
Old Sep 15, 2004 | 09:17 AM
Green Thunder18's Avatar
My light keeps coming on as well. Usually after the car sits for a day, but sometimes will come on even without sitting. Took it to the dealer, they had it overnight, and just said "couldn't duplicate customer's complaint" - next day the light came on again. Haven't had a chance to deal with it again yet.
Old Sep 16, 2004 | 03:23 AM
DOMINION's Avatar
Hey when you TPL comes on, do you hear a sound like a beep?
Old Sep 16, 2004 | 07:00 AM
Mugatu's Avatar
Not me - only a flashing light. No sound whatsoever.
Old Sep 16, 2004 | 10:19 PM
DOMINION's Avatar
Wow! no way... First I see the light then I hear a beeeeeeeeeeeeeeeeeeeeeep. i dont get it???...
Old Sep 16, 2004 | 10:55 PM
VmanX's Avatar
same thing just happened to me for the first time today... i got a beep and the illumination.... it would go away after i drive for about 10 minutes, but now it always comes on when i start up the car. everything looks and feels fine and i never changed the tires or anything.. i'm really scared to drive over 50 mph and my dealership won't be able to take a look at it til the end of next week.. any suggestions?
Old Sep 20, 2004 | 04:55 PM
sean4828's Avatar
Noticed that this A.M. on the way to work the Pressure lite stayed on. The Tire Press. was fine though on the way home no lite so I guess it was just an intermittant thing.
Old Sep 20, 2004 | 06:10 PM
zoom44's Avatar
the service guys couldnt duplicate your tpms light because they kept in a place with a different, probably warmer, over night temp then where you normally keep it. check your pressures in the morning before you move the car. then add or subtract air to bring them to 32-34 psi based on that reading you took before you moved. if you have to drive to get air add or subtract the amount you needed when you checked before you moved. if you drive AND THEN check the pressures and add or subtract based on that measure your pressures will be off again in the morning.
Old Sep 20, 2004 | 06:12 PM
zoom44's Avatar
your tires were warmer on the way home. thats why no light. check the pressures in the morning and do what i said above.
also while i know mugatu sems to actually have a problem the rest of you just sound like you need to adjust your tire pressures.
please also read here
Old Sep 20, 2004 | 08:53 PM
invaliduser's Avatar
Mine came on for the first time today as well. They must be conspiring against us.
Old Sep 20, 2004 | 09:11 PM
former_s2k'r's Avatar
WOW! Mine just came on today for the first time after 4k miles and 4 months.. Started fricking out to no AVAIL. But today here in Florida it was sub 80 degrees for the first time in my ownership. Checked all 4 tires psi: 29-31. After reading this thread I believe the TPMS monitors tire air temp and not PSI....... Learn something new every day. I just hope it lets me know when the tire is really flat since I gotz no spare!
Old Sep 20, 2004 | 09:20 PM
Oh yeah, I was just thinking. What good is the TMPS if you come out to your baby in the morning and the tires flaT!?? Furreal. Good thing my GF's Z has a spare donut! MAZDA, WTF WERE YOU THINKING? AND DON'T GIVE ME THAT CRAP ABOUT SAVING WEIGHT IN "TRUE" SPORTS CARS THAT YOU PRINTED IN MY DE-BRIEF BROCHURE IN THE GLOVEBOX! HEHE
thinkabbouit.
and yes, I have a little buzz at the moment.
drebbrnator
Dec 27, 2018 07:02 PM
05TiGr8Lady
Aug 27, 2015 07:31 PM
talonhart2
Aug 26, 2015 04:14 PM
MolecularConcept
Jul 26, 2015 09:09 PM
