strange film on headlight lenses
Old Sep 13, 2004 | 12:00 PM
fredinlou's Avatar
has anyone noticed a discoloration on the upper part of the headlight lens, you can only notice it when the light hits it just right, but it wont come off. it almost looks like soapy residue on the inside of the lens above the headlight projector beam, maybe it is supposed to be there to keep the light from creeping up from the projector has anyone noticed this???? thanks
Old Sep 13, 2004 | 12:15 PM
whosyourbaba's Avatar
im assuming its suppose to be there since i have it as well since i got my car.
Old Sep 13, 2004 | 12:49 PM
StphNieuw's Avatar
I have it as well, noticed it for the first time yesterday. I tried and tried to get it to come off but its appears to be stained in the plastic.
Old Sep 13, 2004 | 02:57 PM
former_s2k'r's Avatar
WOW, I thought mine were effef up.... I scrubbed super hard with a cloth and the film still doesen't come off. I also hella-baby my exterior so I was perplexed when seeing it for the first time.. CAN YOU SAY TSB!
Old Sep 13, 2004 | 03:05 PM
ZoomZoom's Avatar
Drive it like U stole it!
Can someone please post pics.
Old Sep 13, 2004 | 03:30 PM
Art Hazebrook's Avatar
If the headlights are similar to those that came on late model Ford Contours and Taurus's (Tauri ?), that would be a UV protectant film that will eventually start to crack or "craze" with age. Try using Meguiar's #17 Clear Plastic Cleaner followed by #10 Clear Plastic Polish initially. Once the material starts to crack, not much short of wet sanding with 1500 then 2000+ grit sandpaper will remove the problem. I hope I'm wrong...
Regards, Art
Old Sep 13, 2004 | 03:35 PM
misterwilson007's Avatar
ROTARY POWERED CYBORG
there's another thread on this same issue............some people have had their headlights replaced free of charge by mazda..........some sort of warranty issue I think...............I have the same problem and it's gradually geting worse.
Old Sep 13, 2004 | 03:37 PM
here's one of the many...........
https://www.rx8club.com/showthread.p...ight=headlight
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
yankeepicker
Sep 11, 2015 05:42 PM
rxwilly8
Sep 2, 2015 02:42 PM
