Tornado with K&N Typhoon???
Old Sep 13, 2004 | 08:37 AM
SilverBullitt's Avatar
Would this work together?? I'm just curious.
http://www.tornadoair.com/index.php
Old Sep 13, 2004 | 10:05 AM
magixpuma's Avatar
they dont work but please buy 1 and be a guineua pig my thoughtsare it just adds more air restriction and ruins ur millage. but do it any way.
Old Sep 13, 2004 | 03:37 PM
bgreene's Avatar
Time of your life, kid...
I'd be amazed if that gadget did much on the renesis.
You'd pretty much have to install it right in front of the throttle body, where the butterfly valve would undo most (if not all) of the change in the airflow caused by the gadget, and it's still a long way through the manifold before you hit the injectors (which is presumably where you'd need the air swirling to see any real gains.
With that effect nullified, puma pretty much nailed it that the only net effect would be a flow restriction in your intake, which would likely diminish performance.
Old Sep 13, 2004 | 03:59 PM
DreRX8's Avatar
A guy bought one and tried it out over on the Millenia forum (I'm also a Millenia S owner) and he pretty much proved it was garbage. I believe that it would only have an increase at high speed if any. Don't waste your time.
Old Sep 15, 2004 | 02:47 AM
Icemastr's Avatar
I would be amazed if that thing did anything on any motor.
Old Sep 15, 2004 | 04:53 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yea cuz they dont...
Old Sep 15, 2004 | 05:16 AM
RXE16T's Avatar
'RX-EIGHT'
IMHO the tornado should actually prove effective and may increase fuel economy and performance in the right application.
From what I can gather from the info, it creates a "venturi effect" and research has shown that a device designed for this purpose not only aids in induction but also in exhaust applications.
Obviously the vehicle would have to be tuned correctly for the device to be successful.
Just my .02c.
Old Sep 15, 2004 | 08:42 AM
wakeech's Avatar
mostly harmless
no, they don't work. the K&N is marginal too.
search, please.
Billy Marcial
Mar 1, 2018 06:50 AM
dmengel
Feb 16, 2016 09:47 PM
cgrichie
Sep 19, 2015 07:03 PM
talonhart2
Aug 26, 2015 04:14 PM
dancingdan42
Aug 19, 2015 09:29 AM
