UK member posts dyno results showing 213.x hp and 147.x T at the wheels
it's in the canzoomer forum here . he states the low numbers on the first 2 runs are with the cz on and the igher numbers of the next 2 runs are with it off. didn't want anyone to miss this. something is squirrly here.
If he dyno'd 213 stock, that would put the engine right around the 238 hp mark or so. We all know the engine can do it. That isn't even a question. It'll exceed that easily. The question is where did he get an ecu tuned like that? I won't raise the bs flag. I think it is crap when people raise the flag before results are shown and then don't believe it when they see it. If you won't believe a dyno chart, what will you believe? I remember the same thing happeneing a year ago with Rotary Extreme and their dyno charts. Remember there are some pretty big variances between dyno readings, even here in the U.S. Some people dyno in the low 170's and others hit the mid 190's. Most stay in the mid 180's. Even the M flash is at best, pathetic. Maybe there is something to the European tuning that we don't know about. Even if we saw his a/f ratio, it wouldn't tell us anything useful. We'd also need to see his leading and trailing timing splits and advance. The stock timing is retarded below 4000 rpm. Why I have no idea. I always have mine at 25 degrees advanced at this point. Instead of saying he is lying or there is an error, why don't we figure out why his car is o powerful. Don't be so quick to dismiss results if they are better than what you expect.
thanks rg for getting us on the right track. my interest in the a/f is to see where his is at compared to what the c/z map "should" make them. thats a big drop. if he has cz 1.1 there should also be some ignition avance dialed in by the unit. i dont know how the cz changes the timing- does it say "move timing to x" or does it say "move timing by +1"? the first wouldnt change anything if that is where the timign is already set. the second way could advance the timing too far, yes? causing the "lag" he describes below a certain rpm?
ah well here is one bit of news. im glad i asked the question:
Originally Posted by mcpheeg
The HP values are adjusted by dastek computer to show what is happening at the engine not the wheels
But there will be frction losses through the wheels and the rollers
Since it is basically figuring out fwhp that seems to make more sense. See the dyno wasn't bs! We just didn't have all the info. What is strange is that the Canzoomer dyno'd less but this has happened before on certain cars.
abbid: Please don't think I was being agressive to you. I wasn't but it probably came out that way. If you were offended, I apologize.
Originally Posted by pr0ber
umm yea... bhp is brake horsepower or power at the crank
Engine manufacturers love to report flywheel HP, of course, because it's a bigger number. It's somewhat meaningless, though, because all that matters is the wheel HP. Who cares if you make 500 HP flywheel, but only 120 HP at the wheels? If I make 300 HP, I lose bragging rights, but when I get 200 HP of that 300 at the wheels, then my 300 hp car will blow away the 500 hp car. Wheel HP is all that matters, and back calculating/guessing engine HP from an inertial dyno measurement at the wheels is only an ego exercise.
Regards,
Gordon
I was just thinking about that yesterday. I really do wish everyone stated power to the wheels. Or better yet, the torque/HP curve from a wheel dyno. Even big HP numbers are decieving. And now we live in a world where people can state FALSE flywheel numbers. Cough. Cough. MAZDA. Bastards.
Kinda sux that this thread was all confusion. I wanted that car to have 213 at the wheels.
