Brake fluid
Old Aug 31, 2004 | 09:37 PM
takahashi's Avatar
Brake fluid
I remember sometime ago that we were talking about engine oil and we brushed on the topic of brake fluid. I remember Hymee talked about Shell racing and Motul but nothing specific.
I asked this question because I have a strange feeling that the brake paddle is feeling firmer than usual and I am not sure it was braking as well as it has been. Maybe I was tired and have not been driving the car for a while. I have done 2 track day with this fluid and I am wishing to change pending on price and labour.
Hymee, could you specify the brake fluid you recommanded before?
Old Aug 31, 2004 | 10:23 PM
PUR NRG's Avatar
If you had air in the lines the pedal would feel spongier, not firmer. Generally speaking firmer is better. For fluid you can either use ATE Super Blue/Typ 200 or Motul 600. The Motul will cost twice as much. I don't think it's worth it. I went to a track day at Laguna Seca in near-record heat (90 plus) on stock brakes and Super Blue. Never had brake fade.
________
XXXTUBES
Old Sep 1, 2004 | 01:41 AM
takahashi's Avatar
There is Motul 600 (which is a Dot 4 fluid) with good boiling point for dry and wet (over 200 cel). Do you know that it is DOT 3 for stock!?
How much do I need is the next question. I guess I can find that out in the owner's manual but if not - please answer this now please thank you. :p
Old Sep 1, 2004 | 09:59 AM
PUR NRG's Avatar
One can of Super Blue is more than enough. One can of Motul 600 may not be.
________
El camino
Old Sep 1, 2004 | 04:58 PM
takahashi's Avatar
How much Super Blue. We have 500ml of Motul here! enough for need a litre - I will call Mazda today
Old Jul 16, 2005 | 11:59 PM
RXP33D's Avatar
Taka you end up getting any brake fluid.
I'm reviving dead threads!
RX8 nats are coming :D
Old Jul 17, 2005 | 07:30 AM
takahashi's Avatar
I ended up using Motul RBF 600 which DOT 4 with a very high wet boiling point. I changed it last Oct and it is already dark. I think it will be good for another few months and I have to cahnge again. I think 2 bottles of $30 each.
Old Jul 17, 2005 | 07:50 AM
clydejmuggs's Avatar
If you have access to a compressor...I use one of these.
http://www.amazon.com/exec/obidos/tg...#more-pictures
You can use the "refiller" and let the brakes bleed until the fluid looks new.
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
