View Full Version : Handbrake?!!! (UK only)
Lensman
04-09-2003, 12:55 PM
Will it impede access to the gear lever?
http://homepage.ntlworld.com/phil.white1/RX8/interior.jpg
jimbobjoe
04-09-2003, 01:07 PM
That is indeed strange.
I would have thought that they would have swapped over the handbrake as well as the steering wheel for us.
Is that a Japanese model ?
Titanium Grey
04-09-2003, 01:08 PM
Do you know if that is on or off?
jimbobjoe
04-09-2003, 01:10 PM
I think that is with the hardbrake on.
But with the shape of the handbrake as it is I can't see that it will go down very far.
Lensman
04-09-2003, 01:28 PM
Japanese yes, but I doubt they'll change the configuration just for the UK. They drive on the left too so why engineer a different solution for us? I can't help thinking that I'll want to rest my wrist on the brake lever (which IS up I think - that is brake 'on' ) and that I shouldn't! That wretched handbrake has been a bone of contention (whatever that is?!) since I first saw it. They obviously let the tea-boy design that bit for a laugh!
MarkW
04-09-2003, 02:04 PM
I must admit it does look like it may be a problem, but I cant beleive the japanese would design a car with a fundemental problem like this for their own market.
Also, none of the UK mags have picked up on this as an issue and they have tested RHD cars.
Im sure it will be OK.
RobWilliams
04-09-2003, 04:39 PM
I sat in the passenger seat of the LHD drive car in Geneva and ran through all the gears. The handbrake was not a problem.
Cheers
Rob
Lensman
04-09-2003, 04:42 PM
So it IS on that side then RobWilliams?
lurcher
04-09-2003, 05:17 PM
Hmm... take a look at this thread, with scans from the Japanese accessory catalogue, some nice toys. :)
http://www.rx8forum.com/showthread.php?s=&threadid=3808
The brake lever is shown consistently on the right, looks to me like it should fold down okay though.
RobWilliams
04-10-2003, 10:33 AM
Lensman
I believe Lurcher is correct and the handbrake is in the same location for both LHD and RHD but when I played around in the passenger seat of the LHD car it did not seem to be in the way.
Cheers
Rob
Ali
04-11-2003, 01:15 PM
I wouldn't worry folks.
You guys ever tried an Alfa 75? If you were in 1st, 3rd or 5th gear you couldn't access the stereo. If you were in 2nd, 4th or reverse you couldn't engage the handbrake! Oh, and the electric window switches were on the ceiling, and the sunroof switch on the dash. After that, I can live with just about anything!
Lensman
04-11-2003, 02:14 PM
LOL. Thanks, I needed that! :)
CraziFuzzy
04-11-2003, 08:46 PM
on a somewhat similar note, i was very dissappointed when i got in the back seat of my father-in-law's PT Cruiser, and the switches for the windows are on the back end of the center console... practically on the floor... I guess some thing's I'll just never understand... I guess since every other current car out there has the switches near the windows they operate, that has somhow been deemed boring and ordinary, and somehow a bad thing... whatever... i give... PRACTICALITY BE DAMNED!!!! :-)
jimbobjoe
04-14-2003, 06:55 AM
Just had a thought about this.
Everything else on the car is switched over from left hand to right hand drive except this handbrake, right ?
Of course what I forgot is that the gear shift positions do not get moved, i.e. 1st gear is top left whether you have a left hand or right hand drive car.
So I guess that the positioning of the handbrake always to the right of the gear lever is to insure that 1st gear is not interfered with.
RobDickinson
04-14-2003, 07:10 AM
So 5th/6th/reverse is?
I think with todays tech and mazda's big brained car designers ( and I know what an agonizingly slow process car design is) cant come up with a handbrake that doesnt foul gear selection or get in the way?
Hopefully they havnt got this one wrong..
MarkW
05-02-2003, 12:09 PM
I thought the handbrake was always on the R/H side of the centre console, hence the discussion about will it be intrusive.
However, looking at some of the pics taken elsewhere, I found this.
Have we beem missing something? Howcome there are RHD cars with the hadbrake on both sides.....
MarkW
05-02-2003, 12:11 PM
And to compare Lensman's original picture....
Cylo
05-02-2003, 12:18 PM
Is it just me, or does the text look backwards leading to the thought that the picture is reversed.
Lensman
05-02-2003, 12:38 PM
Yep, it's reversed. Shame though, I thought we might have a result there.
MarkW
05-02-2003, 01:24 PM
Bugger. Thought it was too good to be true :(
It is reversed as the heater controls are on opposite sides.
Is that some clever photoshoppy thing?
Lensman
05-02-2003, 01:56 PM
Guess so...
http://homepage.ntlworld.com/phil.white1/RX8/handbrake-right.jpg
EAST MOON
05-03-2003, 11:57 AM
I often use the hand brake on load in Japan.
My elbow will become inflammation If the hand brake is in the left of a console.
That is too far for me.
My car is the right handle although you already know.
(My height is 175cm.)
thanks
mac
05-03-2003, 01:06 PM
If the hand brake is in the left of a console. That is too far for me.
That is my concern as well, it looks pretty far away (I'm so used to having it in the middle). It looks like it's going to be a stretch each time. (I'm 170 cm). I hope that it won't be too much of a problem.
