What did I break?
Old Aug 30, 2004 | 08:36 PM
CruelNewb's Avatar
What did I break?
I put a little bit too much oil in the car. I did check the stick ut was too generous when I poured the oil. My car spurted and nearly drowned, white smoke everywhere. CEL came on (Must be the O2 sensor.) Im getting it fixed asap.
Now just wondering will it ruin the seals? Or is there any kind of permanent damage to the rotary?
Old Aug 31, 2004 | 12:00 AM
ezrider55's Avatar
A lot of dealers slightly over fill the oil so unless you realy over filled I do not think that is your problem. The white smoke is a sign of flooding most of the time.
Old Aug 31, 2004 | 06:38 AM
Mr M's Avatar
Evolution of REvolution
If your spark plugs are oil fouled you may have problems with them. They should be cleaned or replaced if necessary.
Your front O2 sensor may also be contaminated with oil, but that should burn off. If you have problems there though your MIL will illuminate, so you can afford to wait and see.
If you have large amounts of oil in your catalytic convertor you risk the convertor overheating and clogging. You can only really wait and see with that too. If it does clog you will suffer from hard starting and low power.
Internally, the engine will not be damaged by over oiling.
Hope this helps.
Old Aug 31, 2004 | 11:38 AM
zoom44's Avatar
check your airbox and intake tube to see if there is any oil in there
Old Aug 31, 2004 | 11:41 AM
epitrochoid's Avatar
Riot Controller
rotarys are essentially dry sump, so you really can't overfill.
sounds like a flood to me, but did you use the right oil?
Old Aug 31, 2004 | 12:08 PM
CruelNewb's Avatar
Yes I did use the right oil but I used a little too much. Enough to drown it a little.
Old Aug 31, 2004 | 12:30 PM
CruelNewb's Avatar
Btw I would like to thank everyone, I usually dont post but when I do its usually coz I need help =p
Old Aug 31, 2004 | 07:42 PM
Gomez's Avatar
Shifty Bastard.
You'll be right, mate. Check this thread.
All the best, Gomez.
R3Dream
Mar 7, 2019 09:11 AM
R3Dream
48
Mar 12, 2016 01:44 PM
snowrydr01
Nov 23, 2015 09:40 AM
erikcamacho15
Sep 12, 2015 11:23 AM
