OZ 18 x 9 with 245 or 255? Please advice
Old Aug 30, 2004 | 08:06 PM
Everett's Avatar
Hi All:
I am planning on getting new 18 wheels.
I choose OZ Supperlegera 18 x 9
Now, My question comes to Tire Size.
This is the Miata Tire Size Calculator
This is the first alternative compared to Stock with 255 40 18
As you can see, it is almost a perfect match in terms of circumference. Also the MPH are .1 over stock.
This is the second alternative compared to Stock with 245 40 18
As you can see, it is almost a close match in terms of circumference. Also the MPH are .6 under stock.
I want to use 255 40 18 S03 with 18 x 9 wheels. My only concern is that if this setup will work in the front without rubbing. I am sure it will work in the rear.
S03
Can anyone shed some light in making my decision?
Thanks,
Everett
Old Aug 30, 2004 | 08:14 PM
shelleys_man_06's Avatar
Not anymore
Damn. Those are pretty nice. I don't think 10 mm will make a difference. What is your application? What are your wheel offset options?
Old Aug 30, 2004 | 08:22 PM
Everett's Avatar
Hi!!
The application is street use. The Offset, I am not sure. I am planning on purchasing from Tire Rack and they send the correct wheel offset according to the vehicle application.
Everett
Old Aug 30, 2004 | 09:17 PM
ScudRunner's Avatar
On time, on target
There are people who have put 275/35/18s on the front with no rubbing...but these people also have stock suspensions (i.e., not lowered at all)...if you buy the 18x9 from Tire Rack, the offset will be +55...based on that and a stock offset of +50, I'd say you'd be fine with 255s in the front...
Old Aug 30, 2004 | 10:32 PM
Everett's Avatar
Originally Posted by JeupRX-8
There will be no rubbing with 255/40-18 tires all around. Might I suggest the Michellin Pilot Sport 2? It is a better tire.
Troy J.
Thanks for the tire suggestion!!
What is the price for the Sport 2?
Thanks,
Everett
Old Sep 5, 2004 | 03:22 AM
Mikelikes2drive's Avatar
those look kinda weird on the 8... sorry
Old Sep 5, 2004 | 03:53 AM
robertdot's Avatar
That is just tirerack's just to see "photochop". I'm sure they will look alot better in real life.
Old Sep 5, 2004 | 08:24 AM
max_rx8's Avatar
after 3 months research here's what i have done to modify my cars appearence and performance
WHEELS (racing Hart,F-10)
front: 19/8.5
rear: 19/10
TIRE
front: 245/35/19
rear: 275/30/19
BRAKE
front: Rotora 6 piston caliper
rear: not available
I have also replaced the front and rear sway bar and springs and fitted a new exhaust(racingbeat) .
Old Sep 5, 2004 | 08:28 AM
Everett's Avatar
front: 19/8.5
rear: 19/10
TIRE
front: 245/35/19
rear: 275/30/19
BRAKE
rear: not available
Any Pics available?
Everett
Old Sep 5, 2004 | 08:32 AM
max_rx8's Avatar
not yet but hopefully in the next week, Rotora also wants to see pics
Old Sep 5, 2004 | 01:55 PM
Cam's Avatar
Cam
this space for rent
Originally Posted by Everett
Any Pics available?
Everett
Yes, post pics!!
I love those Racing Hart F-10's. I would love to see them on an 8.
Old Sep 5, 2004 | 02:07 PM
Fanman's Avatar
I don't know about the 255's, but they (tirerack) had a special on 245/40/18's of the PS 2's that made them essentially equal in price to the S03's, BF Goodrich Comp TA's KD's. At that point for better wet traction, tread life, & tire noise I would get the PS2's.
Old Sep 5, 2004 | 02:14 PM
mdawgx24's Avatar
Question: What's the tradeoff between 18x8.5 to 18x9.0? Is it just a matter of whether it will fit? I'm about to order the Volk Racing SF-Challenge and have decided on 18s, but apparently they don't come in 18x8.5 (what I wanted), so the decision is between 18x8 and 18x9.
Old Sep 6, 2004 | 06:04 AM
max_rx8's Avatar
18x8 & 18x9 would work great and also look good, tires for this size are 245/35/18 & 265/30/18
On the rear if you were to go any bigger up to 18x10 you would have to replace the spring and the sway bar so the wheel would not rub against the quarter panel.
the size you are after now, you dont have to make any replacements.
Old Sep 6, 2004 | 11:22 AM
max_rx8's Avatar
Pics
I've just took these photos today of my RX-8 , computers is not my thing but if you can copy this address you will be able to get the pics
http://hpphoto.com/servlet/com.hp.HP...sword=58325918
let me know if you have any problems
Old Sep 13, 2004 | 01:24 AM
eclps0's Avatar
Lol
i just got thease rims they should be in tommrow ( just in time for the SE Fl meet at towers
05rx8mazda
Nov 28, 2015 09:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Luke.s
Sep 30, 2015 05:57 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
Evan Gray
Sep 26, 2015 12:30 PM
