HELP!! My automatic shifter is stuck in park.
Old Aug 30, 2004 | 02:19 AM
oryas's Avatar
I bought a new Rx8 Sunday. I drove home with no problems. I jacked up the car to install some aftermarket wheels. I disconnected the battery to install the aluminum pedal kit. Reconected the battery, reset the DSC. The car starts fine. Accelerater works fine. But the automatic shifter is physically stuck in the park position.(the same way it doesn't move when you don't step on the brake). I tried eveything. I even put the original gas pedal back in just to make sure the problem wasn't a faulty electronic in my new one. So right know it's sitting in my garage until I can get some help from Mazda. Did I set off some sort of Anti Theft deterant? The engine starts but it won't get in gear. Does any one have any suggestions on what might be causing this?
Old Aug 30, 2004 | 06:30 AM
Black-dragon's Avatar
No the engine wouldn't start, that is the theft deterent but that only happens is you start with out the key. If you just were changing the wheels it shouldn't have anything to do with the car being in park. Put the original wheel back on if you gotta take it to Mazda just so the don't try to tell you that "These rims are not good for Mazda's and thats why your car won't come out of park". That depends on if your dealer is cool enough or not. Good luck
Old Aug 30, 2004 | 06:59 AM
mootz's Avatar
Check the fuse box. It sounds alot like a blown fuse. Also take a look at the switch that is connected to the brake. You may have damaged the wire crimp(sp?) and the connection is no good.
Old Aug 30, 2004 | 07:01 AM
mysql101's Avatar
I learned a long time ago that you do one change at a time on a car unless you're 100% sure your changes can't change anything unexpectedly. It cost me a transmission at the time
Your changes don't sound very severe though...
Old Aug 30, 2004 | 09:26 AM
wakeech's Avatar
mostly harmless
yes i cannot see how your changes would affect anything related to the transmission lock out, other than something electronic going wonky when you disconnected the battery to do your pedals.
Old Aug 30, 2004 | 09:51 AM
moRotorMotor's Avatar
Rotary eXperimental-8
Could it be possible that when he jacked the car, the wheel applied pressure on the drivetrain and maybe locked some gears or something?
Old Aug 30, 2004 | 11:17 AM
beachdog's Avatar
You might also try jacking up the rear end and getting both wheels off the ground. Take off the parking brake and try rotating the wheels back and forth by hand. You might have jammed the parking pawl when you torqued the lugs.
Alternatively, have two friends stand in front and back of the car and push it forward and back while you move the shifter out of park. They better have lots of insurance because one of them is likely to get run over.
Old Aug 30, 2004 | 11:46 AM
oryas's Avatar
I Fixed The Problem
Thanks for your help guys. I managed to unstick the shifter and it's working fine now.
Old Aug 30, 2004 | 11:50 AM
Rob Tomlin's Avatar
Did you figure out what the problem was?
Old Aug 30, 2004 | 12:09 PM
oryas's Avatar
Figured Out The Problem
Yes I figured out the problem. The shifter **** was getting caught on something internally. But I figured out how to get around the problem. Thanks.
Old Aug 30, 2004 | 07:57 PM
DOMINION's Avatar
I don't buy Kool-Aid
So... What was it that "the shifter was getting caught on internally"?
Old Aug 31, 2004 | 03:19 AM
oryas's Avatar
Don't Know Exactly
I don't know exactly what the shifter is catching on. I would have to take apart the console to see whats going on inside. It is still getting caught, but I am managing for now. However I am going to have to take it in to mazda to get it looked at.
Old Aug 31, 2004 | 05:30 AM
DOMINION's Avatar
Well hell yea that would have been the first thing I would have done...
Old Aug 31, 2004 | 06:19 AM
chad's Avatar
Is it possible that when you changed the pedals that the new ones are not hitting or releasing the appropiate button that is used to tell the transmission that it's ok to shift from park. Disconnected wire? Pinched? Hopefully you didn't "break" this safety feature??
Old Aug 31, 2004 | 02:43 PM
oryas's Avatar
Regarding the changes I made to the pedals.
The footrest was just bolted on. The Brake pedal was just a pad. The only thing that involved any wires was the accelerator pedal.
Old Aug 31, 2004 | 08:56 PM
nite crawler's Avatar
funk junky
I used to have the same problems in the automatic/sportonic 4 spd in the Eclipse. Shifter went to **** because I messed with it too much and tried unjamming it myself.
Heed my advice. If the problem recurs, tell Mazda that your shifter acts up and you want that thing fixed. That is such a "warranty" situation. They will fix it.
Old Sep 1, 2004 | 01:31 AM
oryas's Avatar
reply to nite crawler
Thanks for the advice. I intend to still take it back to mazda to get it fixed after the labor day holiday.
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
Paracleet
Feb 2, 2016 08:25 PM
