wheel specs and recommendations
Old Aug 23, 2004 | 12:37 AM
philodox's Avatar
Rangers Lead The Way!
Greets,
I am shopping around for wheels for my 8, but I need to know the specs on the stock wheels so I can get new wheels that properly fit. Can anyone tell me the correct size other than 18x8? Also, I am trying to stick to $300US and under per wheel. Any suggestions?.
Old Aug 23, 2004 | 12:48 AM
ScudRunner's Avatar
On time, on target
specs on stock wheels are 18x8, +50 offset, weight ~ 21 lbs (depends who you ask)
Old Aug 23, 2004 | 01:11 AM
IZoomZoomI's Avatar
Boost needed
also bolt pattern is 5*113.4. Do a search all this stuff have been asked and answered. Check out axis rims, they're pretty affordable and offers some great designs.
Old Aug 23, 2004 | 01:32 AM
shelleys_man_06's Avatar
Not anymore
If you want to know more about certain wheel specs, check out this webpage :
www.wheelspecs.com
Old Aug 23, 2004 | 09:51 AM
Gord96BRG's Avatar
Close! It's actually 114.3
Philodox, if you're looking to improve handling and performance - get the lightest wheels you can (lighter than the stock ~21 lbs), and stay with the same size wheels (and tires) front and rear.
Regards,
Gordon
Old Aug 23, 2004 | 06:33 PM
takahashi's Avatar
It is hard to get that under US$300.
Compare with the Enkei 9.8kg and Volks TE37 7.8kg or CE28N 7.3kg
Stock wheel is pretty light. Some good brands even heavier than stock in 18x8.5".
Good luck looking
Old Aug 27, 2004 | 02:57 PM
cortc's Avatar
The largest I would go is 8.5 and 9.5 (f/r) respectively and be careful with offsets...
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
patriotjj
Sep 13, 2015 08:09 AM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
