Covini C6W
Old Aug 19, 2004 | 01:08 AM
cgrx's Avatar
DRIVEN
Covini C6W
Kind of hurts my eyes to look at the front wheels in the first pic
ENGINE: rear, longitudinal, 8 cylinder in V formation, 4 valves per cylinder, naturally aspirated, petrol direct injection Bosch-motronic.
CAPACITY: 4200 cc
MAX POWER: 380 PS (260KW) at 6400 rpm
MAX TORQUE: circa 450 Nm (45.9 Kgm) at 2700 rpm
TRANSMISSION: rear wheel drive transaxle
GEARBOX: mechanical 6-speed + reverse. Manual and electro-hydraulic steeringwheel mounted servo
CHASSIS: steel tubular with carbon fibre reinforcements and structural parts
SUSPENSION: independent front and rear wishbones
WHEELS AND TYRES: front 15in wheels with 205/45-15 tyres; rear 20in with 345/25-20 tyres
BRAKES: front and rear vented Brembo discs. Bosch servo and electronic brake distribution
BODYWORK: glass fibre and carbon fibre
DIMENSIONS: length 4180mm; width 1990mm; height 1080mm; wheelbase 2230mm/2750mm (to foremost/middle front transaxle); front track 1540mm; rear track 1620mm ; dry weight 1150Kg
TOP SPEED: 300Kph (185mph)
Milesdrake
General Automotive
18
Dec 17, 2008 10:54 AM
