Denatured Alcohol
Old Aug 18, 2004 | 11:34 PM
shelleys_man_06's Avatar
Not anymore
Question Denatured Alcohol
Has anyone tried denatured (ethyl) alcohol on their RX-8? Does anyone know what kind of effect, if any it has on rotary engines? I hear from the FD guys that ethyl alcohol is the key to passing emissions, especially for cars that don't run a cat, or just run dirty.
Old Aug 18, 2004 | 11:51 PM
Nemesis8's Avatar
Bigus Rotus
Nope, but just when are we to be called upon the emissions carpet anyway??
Old Aug 18, 2004 | 11:57 PM
ZoomZoomH's Avatar
Mulligan User
you guys should never need it, seeing the RENESIS have side exhaust ports and expulsion of unburned fuel has been drastically cut down to almost none, plus all new emissions equipments, you should be passing emissions test with no problems.
denatured alcohol basically leans out the fuel by A LOT. Car will run like **** but assuming there is nothing else wrong with the motor, it will allow you to pass with almost NO emissions.
Old Aug 18, 2004 | 11:59 PM
ZoomZoomH's Avatar
Mulligan User
and yes, i have tried it on my FC to pass emissions, didn't pass because I had a vaccuum leak that was ******* up the idle and made the car run filthy rich.
Old Aug 19, 2004 | 12:04 AM
Not anymore
That's what I was worried about. I dread the fact that the RENESIS would have to lean out due to the use of ethyl. Is denatured alcohol just a myth, or is it actually useful? I've been getting mixed reactions from the RX-7 guys.
Old Aug 19, 2004 | 12:41 AM
ZoomZoomH's Avatar
Mulligan User
bottom line: you don't need it.
why even bother with the risk of leaning out your new motor too much and hurting it, if your car will pass emission AS IS
but yes, this trick DOES work, saw it with my own eyes when they tested it and showed me the results (everything dropped to way below passing except CO, which is indication that the car is trying to run very rich)
Old Aug 19, 2004 | 12:47 AM
Not anymore
Is the high CO just a property of rotary engines?
Oh. I actually meant if I perhaps moved up to insane forced induction, or something of that magnitude.
Old Aug 19, 2004 | 02:00 AM
robertdot's Avatar
Just because we don't need it now doesn't mean we won't. IN CA, I've got 4 years until I have to test, but I really want a high-flow cat. I've got a reason if they ask why I have one (stock puts the air sensor too close to the ground and mine got snagged) but if it doesn't pass tests, it doesn't matter anyway.
Old Aug 19, 2004 | 02:24 AM
wakeech's Avatar
mostly harmless
a high flow catalyst will work if it's hot enough.
leaning out your engine for the purposes of emissions tests is fine, it's not going to blow itself up at less than half throttle under 4k rpms. but again, not needed in most cases.
Old Aug 20, 2004 | 01:05 PM
Nubo's Avatar
Lubricious
Lots of gas around here has up to 10% ethanol already. What percentage are you talking about to significantly change emissions?
Old Aug 20, 2004 | 01:09 PM
ZoomZoomH's Avatar
Mulligan User
well, i used 1 gallons of denatured alcohol to 2 gallons of 87 gasoline when i tried to pass emissions in my FC (*just* failed even with fubar'd idle and vaccum leak), so that's like 30% more alcohol than what's already in the gasoline. no wonder it ran like crap when it's in there, heh
afterward i filled up with 93 gasoline, and all was well again
Old Aug 21, 2004 | 12:07 AM
Not anymore
Hopefully, I will have a clean modified RX-8 in which I don't have to resort to using ethyl acohol just to pass emissions.
poacherinthezoo
Aug 3, 2016 11:01 PM
MrWigggles
RX-8 Show and Shine
15
Mar 15, 2006 01:48 AM
DreamWarrior
RX-8 Show and Shine
Sep 16, 2005 11:20 PM
zoom44
Jun 21, 2004 11:01 PM
