Engine Off And the Fan Runs????
Old Aug 18, 2004 | 10:06 PM
MarthaStewart's Avatar
Is there a cooling fan in the engine after you turn of the rx8?
Yesterday evening when I got home I parked the rx8 in the garage and turned off the engine. After about 10 seconds, a fan automatically turned itself on under the hood and stayed running for approximately 5 minutes and then turned off automatically.
Anyone know what this means? I'm sure Mazda designed it that way.
By the way, I did not have my air conditioner running last night when I came home.
mysql101's Avatar
it's normal. it's to keep the car cool until the fluid temp is safe.
Old Aug 18, 2004 | 10:25 PM
Rob Tomlin's Avatar
Almost all cars do this. Be glad your fan is working correctly!
My FD's fan doesn't work well after turning the car off (many FD's have this problem) and I would have to keep the key in the "acc" position to keep the fans running for a while after shutting the car off. I would also open my hood to help the motor cool easier and faster.
Old Aug 18, 2004 | 10:51 PM
Rxdriftingaction's Avatar
i got the same confusion just as u r. it's happen in the #2 week my 8 been home. and i asked my the dealer. they told me it's normal. the cooling fan is working for taking the heat away from the engine.
i think tat's super cool. cuz i thought is a turbo timer when i just notice the fan is running.(and i know 8 is NA so i confuse. ha ha.)
Old Aug 18, 2004 | 11:27 PM
DOMINION's Avatar
I don't buy Kool-Aid
Right. One way to know something is wrong is when there is no fan thus your thermostat dont work...
Old Aug 19, 2004 | 10:06 AM
zevans's Avatar
If you've been driving it hard you ought to take it easy the last couple of miles home to get things cooling whilst the coolant and the oil are still been pumped around and air is still passing the rad... otherwise you can get uneven cooling which equals uneven contraction which equals trouble!
Especially applies if you've been on the brakes a lot - improper cooling equals warped discs (and obviously the engine fan doesn't help with that...)
This applies more to turbo cars (in fact is VITAL for turbo cars) but I treat the 8 the same way - it's so fussy about warming up it seems to me it must be the same cooling down. So for the last 3/4 miles I drive it as if it's not warm yet. (Luckily in my case either direction up the main road past my house is cruise-at-50mph territory.)
Old Aug 19, 2004 | 10:40 AM
Actually, I drive the rx8 like its not even a sports car. I've never taken my rx8 to the limit. My speeds are minimum 55 and maximum 72 Miles Per Hour.
Should I push it once in a while?
Old Aug 20, 2004 | 09:59 AM
zevans's Avatar
You don't have to drive it at high -velocity- to have fun...
I drove in within speed limits today (it was wet). It's how quick you can deal with on-ramps / off-ramps that's the challenge. Remember this badboy will go well over 60mph in 2nd...
The Mazda figure for 0-60 is 7.something isn't it? I just don't believe that - it's more like low sixes IMHO.
Old Aug 20, 2004 | 04:39 PM
Elara's Avatar
Magazines have quoted anywhere between 5.9 and 6.2 on official tests- take your pick
Old Aug 20, 2004 | 05:01 PM
cortc's Avatar
Once in a while if you drive it soft take it to redline as it helps keep the spark plugs clean...
Old Apr 5, 2013 | 03:20 PM
willgq's Avatar
Q. the fan on my 04 rx8 is running on low when the car is on and not alt all when the car is off, the smell of burnt plastic is present after i turn off the car, can anyone tell me what is the cause of this, and how can i fix it, thanks.
Old Apr 5, 2013 | 03:25 PM
RIWWP's Avatar
Closed thread. I replied to the thread you created a few minutes ago. No reason to bump a 9 year old thread as well.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
rotorocks
47
May 11, 2016 03:23 PM
Nisaja
Aug 6, 2015 01:27 AM
dbarber
Jul 25, 2015 01:34 PM
