trunk lid misaligned?
Old Aug 15, 2004 | 10:19 PM
_JL's Avatar
_JL
anyone notice that if you look closely on the lines of the trunk lid, on one of the sides there's a larger gap between the side and trunk lid than on the other? Maybe this is just on mine? Is that difficult to realign?
Old Aug 15, 2004 | 10:35 PM
cgrx's Avatar
DRIVEN
http://www.finishlineperformance.com...09-028-04.html
Old Aug 15, 2004 | 10:39 PM
_JL's Avatar
_JL
thanks
Old Aug 15, 2004 | 10:41 PM
Silver04RX8's Avatar
Respect the Yellow Line!
hope you get a resolution to this, if your vin falls into that category just print out that TSB and present it to your dealer, they should be able to fix it for you.
Old Aug 15, 2004 | 10:42 PM
cgrx's Avatar
DRIVEN
anytime - good luck
Old Aug 16, 2004 | 12:08 AM
_JL's Avatar
_JL
i'll check on that...usually with any new car you find one imperfection atleast, i've had the car for nearly a month, and i'm absolutely mesmerized by it, but i found the tiny imperfection today....so hopefully that's all that there is.
Old Aug 16, 2004 | 12:41 AM
Rxdriftingaction's Avatar
go to dealer and check they rx-8 out then u will know is that only urs problem or not :p
Old Aug 16, 2004 | 11:22 AM
zoom44's Avatar
I switched trunk lids with another8owner and we had the job done in about 1/2 an hour. getting the gaps equal was the most difficult part but that part only took like 10 minutes for both cars. the other 20 minutes were spent just removing all of the plastic screws that hold the lid liner in place and then putting them all back on. you have to move the hinges/lid connection point in the opposite direction that you want the lid to go so that the hinges "pull" the lid back to where you want it.
cliffkemp
Dec 24, 2024 10:48 AM
vapor2
May 4, 2020 03:53 AM
200.mph
Dec 10, 2018 03:49 PM
GK1707
Sep 27, 2015 07:33 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
