Good info on Brake Fluids...
Old Aug 15, 2004 | 12:44 AM
cortc's Avatar
Post Good info on Brake Fluids...
This web link has some good info on brake fluids...
http://www.shotimes.com/SHO3brakefluid.html
Check it out...
Old Aug 15, 2004 | 12:49 AM
shelleys_man_06's Avatar
Not anymore
Good find cortc. I have always wondered about Motul brake fluid.
Old Aug 15, 2004 | 01:12 AM
Dark8's Avatar
Ride Naked!
ATE TYP 200 or Blue it is. I'm going to replace my lines and needed this info. Thank you cortc for the right on time info!
Old Aug 15, 2004 | 01:41 AM
cortc's Avatar
Here is another good source, enjoy...
http://www.stoptech.com/whitepapers/brakefluid1a.htm
Old Aug 15, 2004 | 01:59 AM
ScudRunner's Avatar
On time, on target
anybody know how much fluid you need to replace what's in the car?
Old Aug 15, 2004 | 08:24 AM
Doctorr's Avatar
Ricer is Nicer.....
Exclamation Not approved....
Be careful with those brake fluid choices.......
The 'blue' fluids are for racing, look good on a spec sheet, but may not have the corrosion inhibitor package of a 'long life' type. That's why they are blue....dyed so you can tell the difference.
Any sign of blue in the reservoir is an automatic warranty denial for brake failure.
You will also notice that NONE of the 'blues' have the DOT3 approval (it may say 'exceeds all legal requirements' etc..... but no approval is still a crapshoot)
Another automatic denial in case of failure - you may be OK with that, but if you do any driving on the street, how does your insurance company feel?
I would look for a quality DOT4 fluid, like Valvoline Synpower. State of the art specs, with full approvals.
Bottom line- if it's blue, it's not for the street, not DOT legal, and not up to the specs in the manual.
doc
Old Aug 15, 2004 | 08:31 AM
cortc's Avatar
BMW uses it on their cars, and a few of my friends use it on their Porches and have never had any problems... ATE Type 200 is the same stuff and it's not blue... It is formulated the same as many others; you can use it without any problems...
Old Apr 22, 2005 | 09:55 PM
Lock & Load's Avatar
Confused i purchased vavoline heavy duty brake fluid for disc brakes drum brakes and clutch systems .
SAE JI 703 - FMVSS STANDARD NO .116 DOT3 WHICH IS RECOMMENDED IN OUR RX8 MANUAL FOR THE AUSTRALIAN CARS
reading the fine print it also says .... Not recommended for ABS systems ????
Can anyone explain whats going on .
cheers
michael
Old Apr 23, 2005 | 01:45 PM
Is it silicone based?
I use the Castrol LMA
Old Dec 10, 2006 | 03:48 PM
Bkmckay2's Avatar
Can anyone tell me how much fluid to buy in order to refill the system and if you are changing the clutch line with the brake lines what order do you bleed the system?
Old Dec 10, 2006 | 03:56 PM
expo1's Avatar
He's as bad as Can
Buy 2 liters, its better to have extra than to run out during a swap.
Old Dec 10, 2006 | 03:58 PM
Bkmckay2's Avatar
Yeah that is exactly what I am afraid of. So two liters will do the job even with changing out the clutch line?
Old Dec 10, 2006 | 03:59 PM
expo1's Avatar
He's as bad as Can
That will be more than enough, even if your sloppy at doing the purge.
Old Dec 10, 2006 | 04:03 PM
Bkmckay2's Avatar
Great!! thanxs for the fedback expo!
Old Dec 10, 2006 | 11:50 PM
lol, that site has been around for years
nothing finer than Casrtrol SRF ...
Old Feb 8, 2007 | 08:54 AM
sssuperman82's Avatar
i've had Returned
quick question, i am replacing my brake pads but was not sure of the fluid is there any difference between wet and dry?...
Old Feb 8, 2007 | 11:26 AM
RA-Eight's Avatar
Scuderia
man, for second there I thought cortc was back!
Old May 14, 2007 | 06:00 PM
I was at Rotary Reliability & Racing aka Fast Freddy's and they recommended I go with Motul. They swear by it on their race car (and I now see why) but that doesn't sound like a solid choice for my street car....that will never see the track.
Old Jun 16, 2007 | 11:23 PM
speedmaniac's Avatar
Can be created...
cortc, who is that...
UHATEIT
Mar 31, 2019 05:31 PM
BigMikeATL
May 26, 2016 12:31 AM
IamFodi
Aug 11, 2015 01:51 PM
