View Full Version : nav problem
abbid
08-13-2004, 04:32 PM
recently i have noticed that my navigation screen has rolling interference, like when you take something with a heavy electrical discharge to a monitor, like a cellphone. this happens at all times, anyone else have similar problems ?
eightboy
08-13-2004, 05:31 PM
This would be normal since cellphones do radiate about half a watt of EMF (its strong enough to light up a LED connected to a small loop of wire). It will interfere with anything not shielded, and you cant seal the entire LCD inside a metal can.
abbid
08-13-2004, 10:12 PM
this happens at all times, regardless if the cellphone is on or off, the waves vary with throttle position
truemagellen
08-15-2004, 07:43 PM
if you are still under warranty (and will be for a few months) wait to have it fixed in september...then you can get updated Nav disks and whatever else...the key is getting mad about it...
good luck
