Has anyone hard-wired Escort Radar Detector?
Old Aug 10, 2004 | 09:52 AM
Chrisbert's Avatar
If you have, where did you pick up the ground and the +12vDC?
Old Aug 10, 2004 | 10:47 AM
rotary9k's Avatar
theres a DIY for valentine 1 radar detector, i followed the instructions with my escort 8500 and it worked out perfect.
Old Aug 10, 2004 | 10:56 AM
Chrisbert's Avatar
Thanks. I have mine run along the windshield (detector mounted low on windsheild) with the wire hidden between the windshield and dash. I took power from the cigarette lighter fuse, and found a metallic grounding screw (after much frustration) under the steering wheel behind the dash.
I just wanted to be sure there was not a better place to pick up power under the dash.
Thanks again.
Old Aug 10, 2004 | 11:10 AM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
I tapped into an unused fuse location that had unswitched +12vdc in the fuse panel in the left drivers foot well. I ran the wire up the A pillar being careful of the airbag to a location just above the left side of the rear view mirror. I just attached the ground terminal to one of the screws securing the beam that runs below the steering column.
Majictoast
Jul 18, 2015 06:45 PM
doccable
Oct 12, 2005 08:33 PM
cptmorgan2000
Jan 24, 2005 07:07 AM
310Guy
West RX-8 Forum
17
Feb 25, 2004 12:35 AM
z00m-z00m
Sep 16, 2003 03:54 PM
