87 octane?
Old Aug 10, 2004 | 06:03 AM
xxdevilzeroxx's Avatar
Revin 9500k
Exclamation 87 octane?
does 87 hurt our cars? i always thought 91 was the prefered octane rating.....
Old Aug 10, 2004 | 06:18 PM
PHANTOR's Avatar
If you are running canzoomer, I know it runs the best, with 89 octane, or so I have been told by maurice. Apparentley 89 makes the best power. (always use shell as well)
However, this may not be the case with japan spec or other versions.
Old Aug 10, 2004 | 06:38 PM
robertdot's Avatar
The octane rating lets you know how well the fuel will compress without exploding due to pressure (aka knocking). Knocking is bad. High-compression cars, like the RX-8, take advantage of the higher octane fuels. However, people have been running lower octane fuels with no ill effects so far that I know of (but this might be because of the ECUs ability adjust for what the knock sensor tells it)...
http://auto.howstuffworks.com/question90.htm
RevMeHarder
Jun 1, 2026 02:30 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
CMRine04
Jul 29, 2015 02:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
