Maximum Speed per gear?
Old Aug 9, 2004 | 08:08 AM
dean2900's Avatar
Anyone know the maximum speed per gear (with drag) at 9k RPMs? If so, I would appreciate it if you post them.
I know third is around 97mph but not sure on the rest of the gears.
Dean
Old Aug 9, 2004 | 08:34 AM
RX-Dreamer's Avatar
39, 65, 89.5, 124, 147, 148.
Old Aug 9, 2004 | 08:41 AM
RX8_Buckeye's Avatar
'O' - 'H' !!! ...
Drag has nothing to do with the relationship between engine speed and vehicle translational speed. The numbers above look right to me, with the exception of 6th gear. The speed listed for 6th gear doesn't correspond to 9k RPM, rather it is probably the drag-limited max speed.
Old Aug 9, 2004 | 10:47 AM
red_rx8_red_int's Avatar
The numbers above look right for 9k, but the fuel doesn't cut out till higher. I think the fuel cut offs are around 42, 68, 94, and 128. Haven't tried 5th or 6th.
Old Aug 9, 2004 | 12:21 PM
Gord96BRG's Avatar
No, it's the electronically limited speed. Redline in 5th gear is 147 or 148 mph, but in 6th the ECU limits the car to the same 148. Without an electronic limit, the drag-limited top speed would be around 160 mph.
Regards,
Gordon
Old Aug 9, 2004 | 12:58 PM
PoorCollegeKid's Avatar
This might be useful.
Old Aug 9, 2004 | 01:41 PM
dean2900's Avatar
It is interesting that 5th and 6th are roughly the same speed. I am assuming 6th is geared higher and is basically a good gas mileage gear?
Does the ECU actually cut you off at 148 ot 155? I remember reading several that stated the cut off was at 155 but maybe than was with the original 250hp version.
Dean
Old Aug 9, 2004 | 02:48 PM
h0rde's Avatar
CVRRVS CELER
many people have reported topping out at higher than 148 in the 6 speeds. I guess they could all be lying...
Old Aug 9, 2004 | 03:38 PM
dean2900's Avatar
I have only had more car for two weeks and the fastest I have had it is 110 so far.
I had my S2000 to 146 (top up) and I had to slow down.
The S2000 pulls great up to about 130 and then it is slower going to the true top ends.
My guess is that the 8 pulls slow above 130 or so but I dont know for a fact.
Dean
Old Aug 9, 2004 | 04:12 PM
ÜberJumper's Avatar
I had the demo I was driving up to 175 (KM/h) last weekend.
Haven't had my car up past 130 or so yet.
Old Aug 10, 2004 | 01:32 AM
StealthTL's Avatar
Metatron
Airport run.....
226kph, 146mph at 'beeper' in 5th. (68*F, 2700ft elev)
Tried changing to 6th, but lost a little speed - back to 5th, but couldn't get any faster. :o
Old Aug 10, 2004 | 01:42 AM
sferrett's Avatar
Whaaaa?
Did the limit feel due to air drag or some other limit (engine power or perhaps electronic limiting) ?
Old Aug 10, 2004 | 01:46 AM
StealthTL's Avatar
Metatron
Drag.....
Really felt like drag, car was willing, but 6th was just too high, and 5th kept 'maxing out'.
S
Old Aug 10, 2004 | 03:12 AM
RX-Dreamer's Avatar
You can't do 9000RPM in 6th gear. It maxes out at 148.
Old Aug 10, 2004 | 04:00 AM
it is hp vs areo drag issue.
the best i have done is 138mph gps in 5th there was more to come, but ran out of room.
the highest speed is in 5th.
Old Aug 10, 2004 | 07:24 AM
'O' - 'H' !!! ...
Right, but the original question was: "Anyone know the maximum speed per gear (with drag) at 9k RPMs?" Without the electronic governer and assuming the engine had enough power, say with FI, one could potentially reach 9000 RPM in 6th gear. The original response didn't clarify that 148 mph in 6th gear was electronically limited, so an unknowledgeable person might conclude that 5th and 6th gears have almost identical ratios.
Old Aug 10, 2004 | 07:30 AM
dean2900's Avatar
Buckeye,
I am certain 6th is geared higher but I would be curious what the theoretical top speed would be not drag limited in 6th.
Dean
Old Aug 10, 2004 | 07:51 AM
ChrisW's Avatar
This has been dealt with in several other threads, and in none of those have I seen anyone present any evidence that the RX-8 is electronically limited to 148 mph. And many people claim to have gone faster.
I think the 148 mph limiter is a myth. Top speed is drag limited.
Old Aug 10, 2004 | 09:58 AM
Chrisbert's Avatar
Old Aug 10, 2004 | 11:31 PM
Originally Posted by Chrisbert
Click on the link (the underlined "This" in that post).
JimmyBlack
273
Feb 10, 2020 10:23 PM
nowakm99
Oct 9, 2015 07:10 AM
juicemantwon
Sep 26, 2015 12:30 PM
GARCIAC951
Sep 10, 2015 07:17 PM
titaneum_grey
Sep 6, 2015 10:21 PM
