Electric seat switch get stuck in foward & reverse!! Anyone else?
Old Aug 8, 2004 | 07:16 AM
emailists's Avatar
This has happened a few times. Moving the seat with the power switch- it get stuck in the on position- pushing me all the way forward or all the way back. Good thing I'm short or it might have crushed me knees.
ANyone else experience this?
Old Aug 8, 2004 | 07:28 AM
DOMINION's Avatar
I don't buy Kool-Aid
No not me... "Electric seat switch get stuck in foward & reverse!!" But thats why I did not get them. Me and my girl driver the car way too much and I knew that would just be our luck.
Old Aug 8, 2004 | 12:35 PM
stickman's Avatar
What is probably happening is the plastic trim piece on the outside of the driver's seat (the one the switches are on) is separating from the similiar trim piece in the front of seat. If you follow the trim around to the front you will see a snap together joint. My guess is you will also see it has come appart some. What is now happening is the switch is rubbing on the trim piece since the trim is bulging outward some. I glued mine in at the joint and the problem went away.
Old Aug 8, 2004 | 05:43 PM
RX8by's Avatar
Thanks for the info mine has done it several times. I just never looked at the problem as every time it has done it I was in a hurry.
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
Jst4fun
Mar 5, 2021 07:16 PM
