M Flash Question
Old Aug 7, 2004 | 03:12 PM
HERO's Avatar
M Flash Question
Hey guys, I'm pretty sure this has been asked before and there must be threads on it floating around, but allow me to ask it once again. How can u self-test to see if your reflash was indeed the "m" flash and not a lower version of the flash? I think it has something to do with the break pedal or something? I appreciate everyones help.
Old Aug 7, 2004 | 08:42 PM
brothervoodoo's Avatar
RainMan is Back
Visually or without diagnostic tools, you can't tell the difference between "L" or "M" because they both sweep the oil gauge when you do the "brake tap" test...
Old Aug 7, 2004 | 08:48 PM
irish8's Avatar
Get in ma belly!!
Have you taken it to your Mazda dealer recently?? If you have then your car has already had the upgrade.
Old Aug 7, 2004 | 08:51 PM
irish8's Avatar
Get in ma belly!!
Hey "brothervoodoo" is that your car in the picture? If so, where did you get the awesome grille?
Old Aug 7, 2004 | 09:30 PM
RainMan is Back
Thanks, yes that's my car. Click on the picture and then click on the billet grille link for more info.
Old Aug 7, 2004 | 10:08 PM
irish8's Avatar
Get in ma belly!!
Brothervoodoo....talk to me about the debadging. My 8 is black, about 4 months old. What di you use tool wise, any tips and how long did it take? Also, any paintwork blemishes?
Old Aug 8, 2004 | 07:53 PM
HERO's Avatar
thanks for all the input, but can someone tell me how the brake test is correctly done? Appreciate it.
Old Aug 9, 2004 | 10:23 AM
irish8's Avatar
Get in ma belly!!
Turn your ingnition key to "acc", then tap the brake pedal 20 times within an
8 second period. Look at your oil gauge...it should sweep if your car is currently update to L or M flash.
I did it last night!!! Pretty cool!!
Old Aug 9, 2004 | 02:56 PM
HERO's Avatar
Thanks alot IRISH8, i just did the test and my oil gauge did indeed sweep :D
Old Aug 9, 2004 | 03:02 PM
MEGAREDS's Avatar
Goh Mifune
The other way to see if you have the M flash is to check for a sticker under the hood. I believe there should be a "campaign" sticker there indicating a part number beginning with the letter "M". Checking for the sticker is the preferred method: the brake sweep test resets the ECU, removing any "learning" that its done regarding your particular driving style.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
