Front Grill replacement?
Old Aug 7, 2004 | 12:53 PM
fd3s777's Avatar
www.EVO-R.Net
Has anyone replace their OEM front grill with something that is more vented?
Old Aug 7, 2004 | 01:08 PM
StealthTL's Avatar
Metatron
MORE vented?
How can you get more vent area?
The rad is practically unprotected already, most people are even looking to shield it a bit.
The top half of the 'radiator inlet' is actually a crash reinforcement beam, so if you open it up you just see foam and steel. Most of the air/birds/leaves go into that huge chin scoop.
S
Old Aug 7, 2004 | 05:56 PM
robertdot's Avatar
Some people have put prettier grills on theirs. But, they also leave the stock grill behind it.
If you look at the Mazdaspeed kit, it should breathe a bit more with the wire mesh instead of the plastic mesh. But, really, I don't think it makes much of a difference. Like stealthtl said, the rebar is covered perfectly by the backing on the stock plastic mesh, and the flow through the bottom air dam and the bottom of the stock mesh is about as good as it gets.
fullsmoke
Nov 24, 2015 04:09 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
SayDfuse
Aug 3, 2015 10:41 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
