looking for lowering info
Old Aug 3, 2004 | 05:41 PM
Steve_Kidd's Avatar
I'm looking to drop my car, I just got it a couple of days ago. Some info on springs and alignment kits would be much apperciated.
Old Aug 3, 2004 | 06:29 PM
robertdot's Avatar
There is a search button at the top. Most / all the info you could ever want (that we know about) is already on the forum. But, for springs, search for Racing Beat, Tanabe, Tein, MazdaSpeed, Feed, RE Amemiya... There are more than that, but those are the ones off the top of my head.
For coilovers, look at the JIC FLTA2. There are some more, but I can't recall them. I think Tababe and Tein have them also, as well as FEED...
For future reference, search before posting, or people will e-crucify you.
Old Aug 4, 2004 | 01:03 PM
Steve_Kidd's Avatar
Thanks robertdot. I haven't seen much about the springs from Eibach. I'm just worried about the camber if I drop it. I have been looking for an alignment or camber kit, but have come up with nothing.
Old Aug 4, 2004 | 01:42 PM
Kel Rx8's Avatar
if your not 1st your last
steve how aggressive you want to go on drop is the question ?
what would you want to do with your car ? auto x ,show, daily driving etc.
dont worry about camber kits. an alignment is highly reccomended.
Old Aug 4, 2004 | 02:09 PM
Gord96BRG's Avatar
You do know that the RX-8 has a fully adjustable suspension, front and rear? (front - camber, caster, toe; rear- camber and toe). This ain't no econobox Honda or Volkswagen! Unless you really slam it (and then who cares, because the car will handle and ride like crap anyway), the stock suspension should be able to handle re-alignment without problem.
Regards,
Gordon
Old Aug 4, 2004 | 02:27 PM
Steve_Kidd's Avatar
I was looking to drop it about 1". Just trying to figure what springs to go with. I don't want it to be to low and ground out everywhere. Like I said before, I just got my RX-8. I had a 5.0 before and when I dropped it, I ran into all shorts of issues.
Old Aug 4, 2004 | 03:36 PM
Ophitoxaemia's Avatar
dizzy snake pilot
the 5.0 mustang has an unfortunate suspension design, not just the strut suspension in the front but the geometry is such that when you drop it the roll center goes really low, below the ground, and you get *more* lean, not less!
the rx8 has a much better suspension design and wont suffer the same problems.
james
Old Aug 4, 2004 | 05:50 PM
Steve_Kidd's Avatar
Cool, thanks James. I've looking through the forums and it seems like Mazdaspeed or Tein S Tech are the way to go. Does anyone know why the Tein springs are so much cheaper than the mazdaspeed. The mazda, eibach, RB, and others seem to be priced somewhat the same.
Old Aug 4, 2004 | 06:26 PM
robertdot's Avatar
Everything Mazdaspeed tends to be a little pricey. Don't take that as a sign of better quality. Everyone else in the field that gets talked about seems to be of equal or better quality.
Old Aug 4, 2004 | 06:44 PM
Kel Rx8's Avatar
you cant go wrong with tein
either s-tech or h-tech
im sure you can find a bunch of threads here of both springs.
Old Aug 4, 2004 | 07:56 PM
dizzy snake pilot
ive never heard of a spring failing, so i tend to think thats not the issue with quality. however springs with the same stated value can vary quite a bit in actual rate, and i think that is the biggest quality (or quality control) issue. if you are a fussy racer you might buy a few sets to find a set that matches. for the street i dont think it will matter if you stick to brand names.
ymmv,
james
Old Aug 5, 2004 | 03:46 PM
Steve_Kidd's Avatar
Cool, thanks guys.
Old Aug 5, 2004 | 11:31 PM
Redlinin 8's Avatar
whats lower,tein s-tech or h-tech?
theblinkof
Oct 4, 2023 05:24 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
