4 Channel Amp or Bose?
Old Aug 3, 2004 | 05:37 PM
mezzer's Avatar
How bad do aftermarket speakers sound with the factory Bose amps? I've researched the best I can. I just want to know if anyone replaced the factory Bose speakers but still use the factory amps. If so how does it sound? I hope I don't need a 4 channel amp on top of a sub amp because I don't want to lose anymore trunk space than I have to.
Old Aug 4, 2004 | 12:40 PM
DreRX8's Avatar
I don't think that it is possible-since Bose uses like 1/2 ohm or something--also--in most applications--BOSE speakers are powered by their own amps--is this the case in the RX8?
Old Aug 4, 2004 | 03:41 PM
mezzer's Avatar
Yeah, the rears which are 2ohm have an amp, the fronts are .5ohm have seperate amps in each door for them. It can be done but I'm 99% sure it will be a waste of time. Those amps in the doors are tiny so they won't do a thing at 4ohms. I just didn't want to buy two amps or one big amp. But I found the Soundstream TR800/5 will fit almost perfectly in the trunk indentation, so I won't be losing much more "useable" trunk space anyways. Thanks for the reply.
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
