BOSE POWER cable
Old Aug 1, 2004 | 12:59 PM
Juxagent's Avatar
Question BOSE POWER cable
I know the proper way to hook up an amp; ive done it many times in various cars.
I am curious however if i can tap into the power wire running into the bose amp, to hook up my rockford amp?
thanks in advance
Old Aug 2, 2004 | 02:44 PM
MrWigggles's Avatar
This should be in the Audio section.
Anyway the problem is that the complete Bose system uses a 20 AMP fuse. So it is already "tapped" out. Unless you are using a very small rockford amp, you are going to wind-up blowing a fuse if you use the same line.
-Mr. Wigggles
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
RenzoRx-8
Sep 9, 2015 02:38 PM
Tsurugi
Sep 7, 2015 08:27 PM
nivong
Sep 2, 2015 07:54 AM
