weight reduction
Old Jul 31, 2004 | 08:27 PM
micrx8's Avatar
weight reduction
how can I shave some weight without taking out the rear seats
Old Jul 31, 2004 | 08:32 PM
micrx8's Avatar
Talking weight reduction
or taking out the radio
jack 8-10 pounds
rear trunk insulation 1-2 pounds
plastic covers 2-3 pounds
what else thanks
Old Jul 31, 2004 | 08:35 PM
cgrx's Avatar
DRIVEN
Get smaller/light weight rims and tires.
Go on a diet ??
Replace rotors ( I think the ones available are lighter)
Intake
Exhaust
Old Jul 31, 2004 | 10:44 PM
Spazm's Avatar
~~> Next 10 miles
Bye bye AC.
Old Jul 31, 2004 | 11:43 PM
robertdot's Avatar
This has already been discussed at length: https://www.rx8club.com/showthread.p...t=shave+weight
Also, I don't think this is a DIY...
Old Aug 1, 2004 | 01:06 AM
D MENAC 7's Avatar
Moderator with a mycocardium
go on a diet, I heard the low carb works. :D This is the Do It Yourself forum, post in the correct place. please.
Old Aug 1, 2004 | 03:36 AM
Nubo's Avatar
Lubricious
How much weight are you looking to remove, and what do you think the benefit will be?
Old Aug 1, 2004 | 08:53 AM
micrx8's Avatar
thanks guy
I want to shave as much as I can
benefit: better acceleration
better braking
better handling
fuel economy
Old Aug 1, 2004 | 11:03 AM
RX-8 friend's Avatar
If you are good with your hands, cutting and bending metal, you can shave a few pounds (whatever they are) by replacing steel brackets with aluminum. I've done this on my RX-7 - e.g. bracket holding turbo output pipe (cross-over pipe) was about 1-2 lbs - replaced with an aluminum one I made with simple bar stock - it was less than 1/2 lb.
If you look hard enough you will find examples all over the car. I wouldn't remove sound insulation or other comfort items. The object to me is to make the car "better" (same drivability and comfort with less weight). Basically doing the things Mazda deemed too expensive or time consuming for the production car - to cut weight.
Be carefull you do not compromise safety. Leave the heavy parts that brace seat belts and the front crash absorbtion system. Stick with simple obvious things and you can get lots of weight out.
Old Aug 1, 2004 | 11:17 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yea do all that and get lighter seats too.
Old Aug 2, 2004 | 12:37 PM
Ophitoxaemia's Avatar
dizzy snake pilot
you arent going to notice 10-15 lbs. most of the stuff that significantly reduces weight also reduces the functionality of the car. the interior, air bags, air con, etc all have significant weight. radios arent heavy, but speakers are. if you live in a warm climate, there are small batteries that work fine (i have a 15lb odyssey).
replacing windows with lexan, although this is illegal.
if you stripped out an rx8, you could probably get 600+lbs off the car, and then you dont need the turbo anymore
james
Old Aug 2, 2004 | 02:50 PM
Dark8's Avatar
Ride Naked!
Somebody refresh my memory: Didn't GRM have an article about a year ago that compared un-sprung and sprung weight reductions and which gave the best performance gain for each pound shed?
I would look at lighter wheels, tires and rotors for the best bang for the buck to get rid of un-sprung and reciprocating weight to aid in acceleration and handling. But I also understand that ripping stuff off the car is a whole lot cheaper....
Old Aug 9, 2004 | 03:11 PM
j1mb0x99's Avatar
Caution!
Flywheel... don't forget the flywheel...
-JiM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
hufflepuff
May 30, 2016 10:45 AM
