Bose Amp
Old Jul 31, 2004 | 08:07 PM
Juxagent's Avatar
Bose Amp
I wanna add my two JL audio 12's with a rockford amp, and my question is this. Can i pull the power from the power cable going into the BOSE AMP instead of running it from the front battery; what problems do you forsee if any? I hate to go through the trouble of running 4 gauge wire through the car and getting it through the firewall, what a hassle.
I would use a dedicated ground wire from the frame and pull the remote from the amp as well.
what fo you think.
Old Aug 1, 2004 | 04:45 PM
mezzer's Avatar
It looks to me like the power wire for the Bose amp is #12, maybe #10. That is not gonna carry the load for any aftermarket amps.
Old Aug 1, 2004 | 06:41 PM
Juxagent's Avatar
what if i only use a 10 or 12 gauge wire, it might be underpowered but im not to worried about that; do you think it would work without problems?
Old Aug 1, 2004 | 07:33 PM
Choppy's Avatar
www.rx8club.com.au
I would not risk blowing your Bose AMP due to power swings. Its risky i would make the effort to run it through its actually not a very big job if you consider the amount of DIY on the forum.
Depending what amp you use might even consider running a bigger battery too.
Regards
Phillip
Old Aug 2, 2004 | 09:01 PM
mezzer's Avatar
Using the #12 Bose power wire won't underpower your new amp, your amp will pull what it needs, you'll just end up melting the insulation off of the power wire. Don't do it man.!
Old Aug 2, 2004 | 09:14 PM
mlino01's Avatar
look in the diy section running the power cable takes an hour at best and is easy with instructions
Old Aug 2, 2004 | 10:31 PM
Juxagent's Avatar
thanks guys; your right i guess i just saw it there and got lazy.
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
