Windshield wiper problems
Old Jul 29, 2004 | 12:49 PM
shelleys_man_06's Avatar
Not anymore
Unhappy Windshield wiper problems
I was driving home from downtown Houston today, and it started raining. Naturally, I turn on my windshield wipers, but instead of wiping smoothly across the windshield, they sort of vibrate across it, as if the glass were rubber. I recently applied a coat of Rain-X. Could that be the culprit? What is wrong with my windshield wipers?
Old Jul 29, 2004 | 12:58 PM
marcj1's Avatar
I have always rain-x'd my vehicles, including my 8, with no problem (just don't do the top 2" of the passanger window!).
Dumb thought, but this happens to me when it's misty rain.
Old Jul 29, 2004 | 01:01 PM
MTCD01's Avatar
You could try applying some rain-x to the blades as well.
My wipers also tend to skip a bit if there isn't enough water on the windshield (misting) so I usually add a little washer fluid to the mix before wiping.
Old Jul 29, 2004 | 01:15 PM
Atacdad's Avatar
Why?
Old Jul 29, 2004 | 03:53 PM
Not anymore
You may be right. I'll try that out and see what happens, because this is weird .
Old Jul 29, 2004 | 04:14 PM
marcj1's Avatar
Originally Posted by Atacdad
Why?
If you crack (open slightly) your window while its raining, the rain-x will cause/force the rain to enter the cockpit at a much more noticable rate than without. Leaving a couple of inches untreated will alleviate the issue.
In thinking about this I guess the curature of the window influences this--I mention only b/c I noticed the phenomena in my Jeep.
Old Jul 29, 2004 | 10:00 PM
BoxerGT2.5's Avatar
Just drive faster....you won't need wipers.....j/k.
Old Jul 29, 2004 | 10:55 PM
6speed8's Avatar
Why use Rain-X if you are going to use your wipers??? I know alot of people swear by Rain-X, but personally I just use the wipers.
The wipers are chattering because of a waxy buildup on either the glass or the wiper blade.
Old Jul 29, 2004 | 11:59 PM
Not anymore
That was my hypothesis. I used Rain-X because my windshield wipers went south after only 9,000 miles. I swear by Rain-X, but this is the first time this has ever happened to any car I've ever owned. Is there anything I can do in the meantime?
Old Jul 30, 2004 | 07:28 AM
6speed8's Avatar
Go to your Mazda dealer parts dept and get a set of 'blades' - just the rubber inserts - they cost a couple of dollars, and replace them. By the way I have 14k miles on my car and the wipers are still working great, which is very good for the use/abuse they go through in Florda.
Old Jul 30, 2004 | 07:50 AM
terbeaux's Avatar
Evil Wrongdoer
Try cleaning/wiping the blades with a cloth soaked in some IPA (isopropyl alcohol). Works for me.
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
