10 inch sub enclosure
Old Jul 28, 2004 | 04:38 PM
ammachama's Avatar
Just finished installing a sub in the back of the car!! Wanted to keep the trunck space and have use of the opening in the back seats - this is what I cam up with!! Still have a couple finishing touches to do - what do you think?
Attached Thumbnails 10 inch sub enclosure-car1.jpg   10 inch sub enclosure-car2.jpg
Old Jul 28, 2004 | 07:20 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
Looks great man. I like the amp rack especially. it is different than anything else i've seen in this car. good job. how does it sound?
Old Jul 28, 2004 | 07:53 PM
snowrydr01's Avatar
nice work, not too fancy, very functional for a small car
Old Jul 28, 2004 | 09:20 PM
DreRX8's Avatar
Actually I'm doing the same thing--however my amps are mounted in the depression in the bottom of the trunk--and I'm going with an 8in sub.
Old Jul 28, 2004 | 11:53 PM
ammachama's Avatar
it sounds pretty good - I screwed up some of the wires originally, but once I figured that out, no problems - I personally don't need anything too loud, but this can pound if I want it too!!
Old Jul 29, 2004 | 01:01 PM
bossnikon23's Avatar
stupid question, but were did u get the carpet to cover the box and amp rack..it matches perfectly...!! Great Job BTW~!
Old Jul 29, 2004 | 01:29 PM
ammachama's Avatar
HI - I just got it at a local car audio shop - from there install area - i think it's called salt and pepper - but there are 2 shades - you need the darker one - you will be abe to tell if you saw them!!
Old Jul 29, 2004 | 04:53 PM
mikeb's Avatar
100% Italian
very nice
I hardly use my trunk though
Old Jul 29, 2004 | 06:19 PM
Clemson, NOT Auburn
Can i ask, what is the cubic feet on the inside of youre box for that sub? would a box like that be able to be made for a JL 10W7? (1.25 cuft.) That is very space conserving and i need space in the trunk.
Old Jul 29, 2004 | 10:31 PM
ROTORTHUG's Avatar
that's sweet,simple but unique..
Old Jul 29, 2004 | 10:33 PM
Omicron's Avatar
Originally Posted by mikeb
very nice
Then that makes it a perfect place for a sub... :D
Old Jul 30, 2004 | 12:24 AM
Juxagent's Avatar
Are you by chance using a 2-ohm amp or i should say do you have to? Im also wondering if you get a clean signal off the bose system using the LOC. The bose system runs on funny voltages and uses a 2-ohm load.
let me know
thanks
Old Jul 30, 2004 | 01:13 AM
ammachama's Avatar
hi - unfortunately, I don't think its any more than.6 cubic feet - if that - if you know how to fibreglass a box, you can get more area by making the back sides of the box a perfect fit - but I still doubt it would be 1.25 - maby if you encloes the amp rack, it would increase the size aswell!!
Old Jul 31, 2004 | 10:54 AM
thank you!!
Old Jul 31, 2004 | 03:21 PM
truemagellen's Avatar
Attracts tree branches
you know what...there is no DIY or specific information on this...guess it is something you just 'know' I've been told...well I have no clue so I'm with you in that help is needed: )
I need it for the Bose system...it would be nice for the non-bose owners too
thanks
Old Aug 1, 2004 | 01:56 PM
ammachama's Avatar
hey - the way I hooked up the RCA cables was to splice into the rear speakers and get myself a high to low level converter - they are availble at any car audio shop and electronics shop. I paid $50 for mine beacause this is the place where I hear all the problems can happen(cutting out, etc), so I decided to pay more for it. The converter has RCA outputs which you just attach to your amp, or crossover, then you are pretty much ready to go.
Gound the amp somewhere in the trunck, run a power cable from the battery, and use the power adapter from the centre console as your remote wire - then you are set to go!!
have fun!!
Old Sep 9, 2004 | 01:15 AM
irfan's Avatar
ElusiveSasquatch
I have a box i used in my saab, i'll see if it fits .. its 2 infinity perfect kappa 10.1s and a jbl 600W amp.. i will splice into the 6x9s and run a line into the speaker level inputs.. my Q is.. where id u splice into? do the 6x9s in the rear shelf (BOSE system) get all of the lows, or are they filtered out?
Old Sep 12, 2004 | 05:19 PM
Liquid Rhino's Avatar
Keepin' It Real Since '79
Sweet setup... simple and clean!
Old Sep 13, 2004 | 01:59 PM
ammachama's Avatar
Hey - I don't think that the rear 6*9s are filtered, but I have no idea. That is where I spliced the signal from - if you have a high level input on your amp, you might as well try and use it, it should work out!!
post some pics!!
later
Old Sep 21, 2004 | 11:33 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
I may considerchanging my setup to somethinglike that b/c right now I have no spacein my trunk at all. Also I bet that single JL 10" sub probably hits harderthan my two Kenwood 12s do.
Heres a 1 year old pic (again for thoseof you who have probably seen it before) of the completely impractical butloud system in my car -- and yes my trunk still looks like this right now -- that is pretty much stuck in my trunk
Old Sep 23, 2004 | 10:17 AM
reddragonmd's Avatar
lol thats awesome. just plopped in there :D
theblinkof
Oct 4, 2023 05:24 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
duworm
Oct 1, 2015 04:57 PM
Rote8
Sep 22, 2015 03:43 PM
