Heat Question for Auto-X
Old Jul 27, 2004 | 08:29 PM
Dark8's Avatar
Ride Naked!
I come from tubo land where between runs you opened the hood and let the car idle for 5-10 minutes to let the turbo/intercooler/etc. cool down. I have heard that rotaries generate a lot of heat. The car is relatively new (+1000 miles) and I will be taking it easy until I get the hang of rear wheel drive and get at least 2000 miles on it.
So, the questions are: Is it beneficial to pop the hood and motor cover between runs? Is it good practice to let the car idle to let it cool down between runs for say 5 minutes or so? Or should I even be worried about the heat buildup?
Old Jul 27, 2004 | 09:40 PM
PUR NRG's Avatar
I don't worry but your mileage may vary. I figure as long as the engine temp gauge doesn't creep 1/4" beyond normal there's nothing to worry about.
________
Lovely Wendie99
Old Jul 27, 2004 | 10:04 PM
red_rx8_red_int's Avatar
I don't think it matters. That said, my last autox I lifted the hood between runs with the engine off, and had my best day.
Old Jul 28, 2004 | 12:07 PM
Ophitoxaemia's Avatar
dizzy snake pilot
cooling the intake of an EFI can result in substantial HP gains for that brief period it stays cool. i cant imagine opening the hood will by itself will make a different you could notice. but it doesnt hurt (as long as the designed airflow for the fan requires the hood to be closed- this i dont know)
james
Old Jul 28, 2004 | 02:07 PM
tpryor's Avatar
Bug sprayer full of alchohol, couple of bags of ice (for the intake runners).
Spray the alchohol on the radiator (if needed) and put a bag of ice on the intake runners between runs.
It can help.......
Old Jul 28, 2004 | 02:42 PM
PUR NRG's Avatar
tpryor, do you really do that between runs?
________
Free **** vides
Old Jul 28, 2004 | 03:01 PM
tpryor's Avatar
At Nationals, or at a National Tour, or at a Divisional event in Texas or Louisiana, yes I do. I even did this with the two Miata's before the 8.
When it doesn't really matter (local events, etc.), even I think it's over the top.
Old Jul 28, 2004 | 07:10 PM
epitrochoid's Avatar
Riot Controller
unless youre a seasoned auto x veteran, you'll be maxing out driving skill long before the motor has a complaint. i run down here in hot, humid florida and only the occasional riced out neon ever lifts a hood between runs.
Old Jul 28, 2004 | 11:34 PM
Dark8's Avatar
Ride Naked!
Thanks for the info.
Old Aug 16, 2004 | 05:41 PM
VividRacing.com's Avatar
I usually open the hood for a few min with the engine cover off inbetween runs. It gets freakin hot hear in Phx so I do what ever I can. Having the better raditator helps too.
Old Aug 23, 2004 | 12:52 AM
blksf8's Avatar
It can help.......
many people do this when racing. I used to do this when I ran 1/4 at Pomona years back and it helped.
Old Aug 29, 2004 | 05:41 PM
bmc's Avatar
bmc
I'd rather be auto-xing
Well, I know many "top dogs" use insulation wraps for their tires inbetween heats. I've seen a couple of Z06's use insulation fullly wrapped around the car. The idea behind fully wrapping the car is to use the engine's heat to keep the tires warm.
One of these days, I'll try that out. I have enough insulation wrap laying around from past "HoneyDo" projects, I should be able to wrap the entire car, three or four times around.
Brian
Old Aug 30, 2004 | 11:09 AM
dizzy snake pilot
some race tires you need to keep warm, although the newer ones work better at lower temps. these you often need to cool with water between runs. most street tires will need to be cooled with water.
james
Old Sep 7, 2004 | 12:43 AM
Butt Dyno's Avatar
Level 5 of The Pyramid
Is the stock temp gauge oil or water?
05rx8mazda
Nov 28, 2015 09:42 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
