XM Roady2 Ashtray Installation
Old Jul 26, 2004 | 09:14 PM
Boozehound's Avatar
Get Hooked
Cool XM Roady2 Ashtray Installation
This weekend, I decided to damn the consequences, get out the dremel and make my Roady2 fit - I was plenty tired of those vent clips bogarding my precious airconditioning...
Now for the Reader's Digest version of my mod:
I had to remove the rib that seperates the two halves of the module, trim the upper "lip" of the tray, remove the metal liner on the door, and do some other minor sculpting to make it fit. Once the rip, grind, and burn part was over, I sealed some of the larger holes with some extra ABS plastic and quick fix UV curable Bondo (I'm proud to say I've bondo'ed my 8...) Once that was said and done, it was time for some hole drilling for the wires into the compartment, and then I trimmed it out in adhesive backed felt from HobbyLobby. I'll throw up some pics, and if anyone's interested, I'll go ahead and describe what I did in more detail.
The first pic shows the rib and the metal liner removed.
The next pic (kind of a gap here, sorry), shows the rest of the trimming done on the upper lip with the bondo filler (white goop), and the outlet removed (just a torx screw to remove)
The third pic shows what it looked like trimmed out in felt before going to the car
Fourth is installed
Fifth shows the door closed over it
Just as a note - the Roady2 is a 6V unit, so I have the outlet underneath the ashtray module in the car, with the power adapter plugged in and everything wrapped in electrical tape.
IMO, it all looks pretty pimp and just needs the last touches for it to be exactly what I wanted.
Enjoy!
Attached Thumbnails XM Roady2 Ashtray Installation-1.jpg   XM Roady2 Ashtray Installation-2.jpg   XM Roady2 Ashtray Installation-3.jpg   XM Roady2 Ashtray Installation-dcp_1607.jpg   XM Roady2 Ashtray Installation-dcp_1606.jpg
Old Jul 28, 2004 | 10:24 PM
CPichot's Avatar
Thumbs up Very Nice Install
The picts look really good!
Where did you hide the antenna? any picts?
Are you using the built in FM modulator or directly connected?
How many hours of loving care did it take for your install?
I like it!!!! :D :D
Old Jul 29, 2004 | 07:46 AM
Frankenguy's Avatar
Nice work!
Old Jul 29, 2004 | 07:53 AM
Boozehound's Avatar
Get Hooked
My antenna's on the package tray in the back, held there using high temp double sided foam tape, and the wire is routed along the factory conduit (under the package tray in the trunk, along the side of the rear seat, over to the console, and up to the ashtray.
I'm modulating right now (hopefully one of the AUX inputs will pan out soon), and it doesn't sound too bad (like a good FM broadcast).
All in all, it took me the better part of Saturday to get it all done, and about 3 hours on Friday pulling out the back half of the interior to put the antenna back there.
Pics to follow of the antenna (and pics of the GPS antenna I've been talking about in other threads for some time)...
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
crimson809
Aug 14, 2016 10:03 PM
Zube6115
Sep 30, 2015 12:57 PM
FubarI33t
Sep 28, 2015 08:45 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
