Wheel Spacers
Old Jul 24, 2004 | 06:12 PM
BIU's Avatar
BIU
Wheel Spacers
I see there are wheel spacers from FEED that are 18mm fronts 23mm rears...
But they cost approx. 500 after shipping and such so i dont think its really worth it...
then i stumble across H&R's website and see their spacers which are significantly cheaper..... probably 200 for the whole set....
I have NO knowledge of offset, spacers.. blah blah blah...
So can anyone help me out and see which wheel spacers from H&R will fit the 8?
I have 18x8 buddyclub wheels with a +45 offset and im looking for a setup like FEED has.... with the rear being abit wider.
All help is appreciated.
Old Jul 24, 2004 | 08:28 PM
MrWigggles's Avatar
BIU,
To my knowledge H&R is not finished with their RX-8 spacers yet. I asked them about 3 months ago and they sounded like they were just starting to explore the option of the RX-8.
The FEED seem to be the only ones available at the moment but with your +45mm 8" wide wheels (5mm out further than stock) you are likely going to rub in the front or rear. (The FEED spacers take the stock wheel all the way out the very edge of the wheel well)
Here is what I would do and I think you will have almost no fender gap:
Mazdatrix sells hub-concentric 6.5mm spacers for their big brake kit. I would get a set of those spacers and put them on the rear. I would also use 245/40-18 tires on your 8" rims.
Versus stock you will have +5mm due to the rims you already have, +6.5mm for the mazdatrix spacer (use in rear only), and +10mm due to the wider tire. So in the rear you will be out +21.5 mm (7/8") further and in the front you will be out +15mm (3/5") further (no spacer).
All of this will be without any rubbing and you will retain your tire rotation ability. You will also have better agressive looks IMO and better performance depending on which 245/40 you go with.
-Mr. Wigggles
Old Jul 24, 2004 | 08:53 PM
BIU's Avatar
BIU
Thanks for every bit of your 2 cents... appreciate it!
now i think i need a week to read over your post about 500 times and try to digest what you just told me....lol i have no idea what it means
Now is there another way where i can do this without buying new tires?
will the Mazdatrix spacers only in the rear work?
Old Jul 24, 2004 | 11:07 PM
red_rx8_red_int's Avatar
OK, I also tried searching for wheel spacers, to no avail. But for a totally diferent reason. I autox my car as stock and the rules allow a .25 inch spacer. Doing all four corners will move the width an extra half an inch. It's not much but everything counts. I'm currently driving stock 225-45/18 and plan on changing to 245-40/18 this week, to gain the almost one inch tire width. I believe the extra 1/2 inch distance will also help marginally. Can I just palce a .25 washer behind the wheel on each lug bolt?
Old Jul 25, 2004 | 08:29 AM
BIU's Avatar
BIU
i have decided to get a pair of MazdaTrix's 6.5mm spacers to slap on the rear..
so along with my +45 offset Buddyclub wheels i will have an extra 5mm up front and an extra 11.5 in the rear..
that'd be enough to make a little improvement looks wise i guess...
Old Jul 26, 2004 | 11:34 AM
Kel Rx8's Avatar
if your not 1st your last
Talking
i have them from way back when i fit my 3rd geb rx7 wheels on my turboII rx7.
and i have them in my rx8 trunk now. but iffy about putting them on the rear.
maybe one day to just try it out but then im real close to rubbing
Old Jul 26, 2004 | 11:39 AM
thew's Avatar
Thews8
what about the handleing of the car after..
I think i just want to cram the widest meat i can uder the fenders..
I am concerd about how spacer will make the car handle ..
Old Jul 26, 2004 | 01:12 PM
BIU's Avatar
BIU
What wheels do you have right now?
Old Jul 27, 2004 | 08:49 AM
orbist's Avatar
beyond the ultraworld
Been running for 10K miles with 3mm spacers on all 4 corners, doesn't affect the handling at all.
Had to put them on as the inside curve of my rims was about 1mm from the brake calipers.
Old Jul 27, 2004 | 11:37 AM
thew's Avatar
Thews8
good to know Orbist ..
hey can you Orb me to Jamacia
Old Jul 27, 2004 | 03:18 PM
BIU's Avatar
BIU
Where'd you get the 3mm spacers?
i might just get some to add on top of mine so i will have 8mm up front and 14.5 in the rear..
Old Jul 28, 2004 | 08:26 AM
orbist's Avatar
http://www.trackstore.co.uk/wspacers.html
SP11
Not sure what the shipping to the US would be, but they are pretty light. About $5 a corner.
92trbolzr
May 18, 2025 09:04 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
