Flashes-can you get them flashbacked??Low end power loss...
Old Jul 21, 2004 | 08:45 PM
rboerio's Avatar
Unhappy Flashes-can you get them flashbacked??Low end power loss...
I got the "M" flash about a month ago. My low end power sucks. I have an AT. It seems as though from a complete stop, if I floor it, it seems to take 8-10 seconds to reach 60...In an AT RX-8 how fast should I be able to do 0-60?Does anyone else have this low end power loss? Can I go back to the "L" Flash-more low end power? Or could something be wrong? I did have my AC on and it was HOT out. Could this have an effect on its performance??
Old Jul 22, 2004 | 02:43 AM
Mr M's Avatar
Evolution of REvolution
Only way to flash back is to blank the PCM and reprogram with the as-built data provided by Mazda. Not many technicians know how to blank a PCM, although I'm sure many have managed it without trying. The dealer would have to blank their WDS and load it with an older software version too (I think, I'm pretty sure).
Call your dealer and start negotiating.
Old Jul 22, 2004 | 11:39 AM
amartin's Avatar
Do a search on "Burnt Coils" and verify yours aren't burnt.. mine were and I lost almost ALL power below 6k
Old Jul 22, 2004 | 06:20 PM
Mugatu's Avatar
Even My Dog Searches
I think some automatic owners have estimated that their autos take 8+ seconds to get to 60. it's that darn auto tranny matched to a rotary that's the problem.
Old Jul 22, 2004 | 08:40 PM
snap-on's Avatar
Re-ghosting the WDS might do the trick. The Dealer would have to reinstall his A-6 application disc then load a disc older than the 30.0 THEN load the C-2 calibration disc.
Each disc has language and license agreement prompts at the strangest intervals so walking away is not an option.
Btw this is about 6 hours of disc loading after which the WDS would need to be re-ghosted AGAIN to get it back to 32.4.
check your coils
Old Jul 22, 2004 | 09:41 PM
EatMyBanana's Avatar
My AT 8 and most post i have read , have seen a great MORE power after the M. This is the first i have read of a decress ? How many miles on your 8?
Old Jul 23, 2004 | 12:39 PM
09Factor's Avatar
Original Turbo 'd Auto !!
I did notice a pwer jump from Stock ECU to "L". For the owners that have had the "M" flash done the peakynesshas been smoothed between the 3500-6000 Rpm range. because of this I haven't had the "M" done yet.
With the AC. outdoor temp @ 105+ and 30% relitave humidity and a stopwatch. 0-60 in 6 sec. Shift @ 7000 rpm. Flat road.
ironj221
36
Jan 20, 2026 08:28 PM
WingleBeast
22
May 23, 2016 09:22 PM
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
Bill_Monteith
Aug 18, 2015 07:11 AM
