burnt coil question
Old Jul 21, 2004 | 06:38 PM
PHANTOR's Avatar
Question burnt coil question
Do burnt coils always burn out in pairs or can you only burn out #1? My number one is burned out and I am wondering if another is and it is not visible.
As well, can you swap #1 with any other coils to make it run smoother (eg.#3)?
It will take a while for mazda to get new coils in stock.
Thanx for any replies.
Remember to drive it like you stole it.
Old Jul 22, 2004 | 11:40 AM
amartin's Avatar
Just because its not visibly burnt doesn't mean its still working.. Mazda should check all 4...and replace as needed. You can verify burnt coils with an ohm meter-- do a search on 'burnt coils'..someone posted how to do it.
Old Jul 22, 2004 | 02:33 PM
DisneyDestroyer's Avatar
Careful, I bite!
Same with me, my trailing rear was burnt out, but not the trailing front. I asked the techs to test all four to confirm that the others were working correctly.
Old Jul 23, 2004 | 01:05 PM
PHANTOR's Avatar
yeah they are testing them on monday, can someone explain how exactly to test them myself without a oscilloscope. Also, maurice from canzoomer recommended using thermal epoxy to put small 1 inch heat sinks on the problem spot on the coils. This will dissipate the heat. Is the problem spot always, directly in front of the electrical plug on the coil?
Thanx for info
05TR1CH
Apr 18, 2023 04:56 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
tgaffner
Aug 20, 2015 10:55 AM
MolecularConcept
Aug 5, 2015 04:43 PM
Obivious
Jul 29, 2015 05:57 PM
