K&N Dyno Chart Fraud???
Old Jul 17, 2004 | 03:33 PM
RotorMotor04's Avatar
RX-8 "SE3P"
I did a search on this and could not find anything about it. The dyno run where they tested the K&N the temperature was 11 degrees cooler. I am not sure but wouldn't that make the engine perform better? Maybe not 9.5 HP better, but maybe 3 or 4 HP and that is why people have not seen much improvement with the 8.
Old Jul 17, 2004 | 04:47 PM
r0tor's Avatar
all dyno runs are corrected for ambient temp and pressure... if you look on the dyno you will see something called a correction factor (CF). The hp readings are multiplied by that correction factor to correct them to 59deg F and 1 atmosphere per SAE-J1349 specs.
Old Jul 17, 2004 | 06:07 PM
RX-8 "SE3P"
Thnaks for your insight, i was not accusing K&N of fruad, just wasn't clear on the temp thing. Thanks for clearing that up.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
05rx8mazda
Nov 28, 2015 09:42 AM
NotAPreppie
12
Sep 24, 2015 03:22 PM
ErwinN
Sep 23, 2015 09:29 PM
